[waves2Foam] Compilation error: cannot find -lwaves2Foam
Like Tree1Likes
  • 1 Post By katiuskas
Old   March 21, 2022, 12:46
Unhappy Compilation error: cannot find -lwaves2Foam
Pere
katiuskas is on a distinguished road
Dear all,
I am having problems installing waves2Foam on my system (Ubuntu 20.04, running on Windows 10 via WSL). I have OpenFoam v2012. Following the waves2Foam manual, I first installed the required third-party dependencies (that is gfortran, git, SVN and GSL). However, I get this error when running the ./Allwmake command in /applications/utilities/waves2Foam, during the solver compilation step:
/usr/bin/ld: cannot find -lwaves2Foam
/usr/bin/ld: cannot find -lwaves2FoamGABC
/usr/bin/ld: cannot find -lwaves2FoamSampling
collect2: error: ld returned 1 exit status
I attach a partial log of the compilation since I think the errors are just for the PRE-PROCESSING and SOLVER compilation. A similar case was presented by bknorris (waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712), but I tried what lppferreira suggests with no success.
Has anyone experienced something similar or knows a workaround? Thanks!
**Edit**
I've found the same issue here -Can't find libraries for waves2Foam installation-, but unfortunately the proposed solution did not work for me.
katiuskas is offline   Reply With Quote
Old   March 22, 2022, 06:05
Default Problem update
Pere
I have the feeling that the error may be originated already in the LIBRARY compilation, which occurs before PRE-PROCESSING and SOLVER. During the LIBRARY compilation, I get four different errors (see attached file for an example, full log was too long):
/usr/bin/ld: cannot find -lgfortran
Old   March 29, 2022, 07:35
Smile Found a solution
Pere
Dear all,
After some days of investigation, I think I found a solution. The error comes from waves2Foam not finding the gfortran library (libgfortran.so). Turns out waves2Foam is not looking for it in the right directory, so going into waves2Foam/src/waves2Foam/Make/options.220 one should add the following at the end of the file (also do the same for the options.220 file located inside the waves2FoamGABC/Make folder):
LIB_INC = \
-I$(GFORTRAN_PATH) \
Where $GFORTRAN_PATH is the path to the folder containing the library libgfortran.so, in my case /usr/lib/gcc/x86_64-linux-gnu/9/. I had thus to run the following line:
export GFORTRAN_PATH = /usr/lib/gcc/x86_64-linux-gnu/9/
Personally, I found out about this solution at a later time so I did not try it. Thus, I cannot ensure this will work, but it should be equivalent to what I ended up doing. What I did instead was to create a link for the libgfortran.so file into the OpenFoam library folder, which waves2Foam automatically checks. In my case:
ln -s  /usr/lib/gcc/x86_64-linux-gnu/9/libgfortran.so /opt/OpenFOAM/OpenFOAM-v2012/platforms/linux64Gcc63DPInt32Opt/lib
After that, just go to the waves2Foam folder, run ./Allwmake and you’re done. This error does not seem to be caused by the WSL compatibility, since it also appears in another installation I tried on CentOS. Thus, I hypothesize it has more to do with the OpenFOAM version, in this case v2012.
Hope this can help someone
Echofox likes this.
Old   May 12, 2023, 04:15
Thumbs up
Echofox is on a distinguished road
Thank you! It works and helps me a lot!
Echofox is offline   Reply With Quote
2012, compilation, error, waves2foam, windows
[OpenFOAM.com] Can't find libraries for waves2Foam installation Bulb44 OpenFOAM Installation 3 September 14, 2021 10:17
[OpenFOAM.org] RHEL 7.8 Issues installing ParaView - Third Party install not creating OpenMPI browny OpenFOAM Installation 2 April 24, 2021 05:18
Cannot find functionObject file residuals vava10 OpenFOAM Pre-Processing 2 November 14, 2020 12:21
[swak4Foam] swak4Foam compilation can't find -lOpenFOAM BobR OpenFOAM Community Contributions 4 August 10, 2015 14:49
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 stephie OpenFOAM Installation 16 April 23, 2015 16:18
