[cfMesh] [Guide] How to mesh a propeller domain using cfMesh - AMI patch |
July 5, 2023, 20:50 |
Gabriel Felix
Rep Power: 6 |
Hi folks, I have been struggling to succesfully mesh a propeller domain with good volumetric and surface mesh quality. I initially started using snappyHexMesh, however it has several limitations when you go for high refining levels. I tried then using cfMesh, but I took a long time to use it correctly. Now I'm going to share the procedure I used. I used this setup for simulating a propeller that I was researching in my master's. With cfMesh I finally managed to have more control over the mesh and obtain more quality. This document below was the only one that was able to help me thorugh cfMesh. Without it I would not be able to use cfMesh on propellers. - Modelling of chemical batch reactor In my master's dissertation I wrote all the details of how I meshed and simulated the propeller. It is available in this link. There are two files in the docs folder: - Appendix with the details of simulation and meshing (which will be more helpful for you) - SetupOpenFOAM.pdf - Complete dissertation - FELIX, G. R. Experimental and Computational Investigation of Simulated Horn Ice Shapes on Small-Scale Propeller Performance Degradation. MSc Dissertation - ITA, 2022.pdf All the mesh elements, names, patches were based on the OpenFOAM propeller tutorial in order to make things easier for who is starting with propeller simulations. 1. Geometry The mesh domain consists in two regions: a rotating region, called rotor, which is a small cylinder that contains the propeller geometry; and a static cylinder, called stator, which enclosures the rotor region and represents the domain of the propeller flow, as shown in the figure below. The Arbitrary Mesh Interface (AMI) was used to couple the rotor and stator patches which share the same boundaries at their interface. Important: the stator must be hollow in the rotor region. You can do this by subtracting the inner cylinder from the outer cylinder in the CAD software. I suggest using SALOME or freeCAD. The SetupOpenFOAM.pdf shows the steps to generate the solids with SALOME. All the files mentioned below are available in Google Drive and github In the propeller_cfMesh.rar file 1.1 Stator I use two solids for meshing the stator mesh: - outerCylinder.stl (external domain for volumetric mesh) - innerCylinderSmall_slave.stl (internal cylinder in which the rotor region will be located) mesh with: # combine files Code:
cat innerCylinderSmall_slave.stl outerCylinder.stl > combined.stl Code:
surfaceFeatureEdges combined.stl combined.fms -angle 5 # mesh Code:
cartesianMesh checkMesh Code:
FoamFile { version 2.0; format ascii; class dictionary; location "mesh"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceFile "combined.fms"; //minCellSize 0.005; maxCellSize 0.1; //boundaryCellSize 0.005; // Refine region surfaceMeshRefinement { domain { surfaceFile outerCylinder.stl; additionalRefinementLevels 3; refinementThickness 50; } } localRefinement { "inneCylinderSmall_slave" { //cellSize 0.000125; additionalRefinementLevels 3; refinementThickness 50; } } 1.2 Rotor I use two solids for meshing the stator mesh: - innerCylinder.stl (is the same solid of innerCylinderSmall_slave) mesh with: # combine files Code:
cat propellerTip.stl innerCylinderSmall.stl > combined.stl Code:
FoamFile { version 2.0; format ascii; class dictionary; location "mesh"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceFile "combined.fms"; // minCellSize 0.0025; maxCellSize 0.01; //boundaryCellSize 0.05; // Refine region surfaceMeshRefinement { domain { surfaceFile innerCylinderSmall.stl; additionalRefinementLevels 1; refinementThickness 10; } } objectRefinements { box { type box; additionalRefinementLevels 2; centre (0.0 0.0 0.0); lengthX 0.05; lengthY 0.025; lengthZ 0.35; } } // Refine the patches within the mesh localRefinement { propellerTip { additionalRefinementLevels 4; // cellSize 0.001; } } // // Add inflation layers to the patches // boundaryLayers // { // //nLayers 3; // thicknessRatio 1.1; // allowDiscontinuity 1; // maxFirstLayerThickness 0.5; // patchBoundaryLayers // { // propellerTip // { // nLayers 5; // } // } // optimiseLayer 1; // optimisationParameters // { // nSmoothNormals 5; // maxNumIterations 5; // featureSizeFactor 0.3; // reCalculateNormals 1; // relThicknessTol 0.1; // /*nSmoothNormals 15; // maxNumIterations 15; // featureSizeFactor 0.1; // relThicknessTol 0.001;* meshQualitySettings { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 65; //- Max skewness allowed. Set to <0 to disable. maxSkewness 2; } Or just run Allrun.pre that is located in the rotor folder 1.3 Merge stator and rotor meshes In the "combined" folder I use the following commands to merge the meshes Code:
cp -r stator/constant/polyMesh constant/ mergeMeshes . rotor -overwrite topoSet -dict system/createInletOutletSets.topoSetDict createPatch -overwrite checkMesh topoSet -dict system/createAMIFaces.topoSetDict Code:
FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name boundaryFaces; type faceSet; action new; source patchToFace; patch outerCylinder; } { name outletFaces; type faceSet; action new; source faceToFace; set boundaryFaces; } { name inletFaces; type faceSet; action new; source faceToFace; set boundaryFaces; } { name outletFaces; type faceSet; action subset; source normalToFace; normal (0 -1 0); cos 0.3; // Tolerance (max cos of angle) } { name inletFaces; type faceSet; action subset; source normalToFace; normal (0 1 0); cos 0.3; // Tolerance (max cos of angle) } ); Code:
FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Patches to create. patches ( { //- Master side patch name AMI1; patchInfo { type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI2; transform noOrdering; } constructFrom patches; patches (innerCylinderSmall); } { //- Slave side patch name AMI2; patchInfo { type cyclicAMI; matchTolerance 0.0001; neighbourPatch AMI1; transform noOrdering; } constructFrom patches; patches (innerCylinderSmall_slave); } { name inlet; patchInfo { type patch; } constructFrom set; set inletFaces; } { name outlet; patchInfo { type patch; } constructFrom set; set outletFaces; } ); Code:
FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name rotor; type cellZoneSet; action new; source setToCellZone; sourceInfo { set region1; } } ); Or just run Allrun.pre that is located in the combined folder Now the mesh is finished. You will now be able to run the simulation checkMesh output: Code:
Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology outerCylinder 11776 11960 ok (non-closed singly connected) propellerTip 76004 75386 ok (closed singly connected) AMI1 19840 19698 ok (closed singly connected) AMI2 3608 3538 ok (closed singly connected) inlet 1918 1973 ok (non-closed singly connected) outlet 1918 1973 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... CellZone Cells Points VolumeBoundingBox rotor 414383 497558 0.018764 (-0.2 -0.075 -0.199799) (0.2 0.075 0.199799) 2.0 Simulation You can now use the run folder to run the simulation # Copy the mesh from combine folder to run folder Code:
cp -r ../mesh/combine/constant . Code:
rhoSimpleFoam Important Download the files to understand more deeply the process. More details are available in the SetupOpenFOAM.pdf and Modelling of chemical batch reactor files Last edited by gabrielfelix; July 12, 2023 at 09:01. |
October 18, 2023, 16:58 |
Morteza
Rep Power: 8 |
Hello and thank you for sharing your experience.
I have a question regarding interpolation at the interface between the static and rotating blocks of the mesh. It is known that for an acceptable interpolation, the two patches at the interface should be similar in terms of grid topology (number, shape and location of cells). Otherwise, the AMI-weights reported by openfoam during running the sliding mesh case will differ significantly from 1, which eventually leads to divergence. Now, in your case, the inneCylinderSmall_slave and inneCylinderSmall patches have been created from two different meshDict files, with different cell sizes. The question is, does it result in similar grid distribution/count? Furthermore, in OpenFoam_Report.pdf that you have given a link for, these two patches do not have even close number of cells (cylinders with nFaces = 1376 in page 11, versus CYLINDER with nFaces = 18856 in page 12). Shouldn't this lead to convergence problems for AMI interpolation? |
April 2, 2024, 20:28 |
#3 | |
Gabriel Felix
Rep Power: 6 |
ami, cfmesh, mesh, openfoam, propeller |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 06:58 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
