[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..."
Old   July 1, 2009, 10:54
Default groovyBC: problems compiling: "flex: not found" and "undefined reference to ..."
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Maybe its the right time and place to put some questions about groovyBC into a separate thread instead of posting them into other threads about transient boundary condition.
First I have to say, I'm talking about two different computers with two different errors:
First one (running Kubuntu 9.04)
rm: Entfernen von „Make/linux64GccDPOpt/PatchValueExpressionLexer.C“ nicht möglich: No such file or directory
/bin/sh: flex: not found
mv: Aufruf von stat für „*.c“ nicht möglich: No such file or directory
g++: Make/linux64GccDPOpt/PatchValueExpressionLexer.C: No such file or directory
g++: no input files
make: *** [Make/linux64GccDPOpt/PatchValueExpressionLexer.o] Fehler 1
Second one
(running OpenSUSE 10.3)
Make/linux64GccDPOpt/groovyBCPointPatchFields.o: In function `Foam::getFvPatch(Foam::pointPatch const&)':
groovyBCPointPatchFields.C:(.text+0x33): undefined reference to `typeinfo for Foam::fvMesh'
groovyBCPointPatchFields.C:(.text+0x66): undefined reference to `Foam::fvMesh::boundary() const'
groovyBCPointPatchFields.C:(.text+0xa3): undefined reference to `typeinfo for Foam::fvMesh'
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Fehler 1
So, any ideas whats wrong?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   July 1, 2009, 11:39
Assistant Moderator
Bernhard Gschaider
Good thinking
flex is not installed on that machine. And if that is missing you'll probably have to install bison too
Second one (running OpenSUSE 10.3)
[/QUOTE]
That's a strange one. There seem to be some very essential things to be missing from libOpenFOAM.so OR the .so is missing. Did anything every get successfully compiled on that machine?
Bernhard
Old   July 1, 2009, 12:26
sega's Avatar
Sebastian Gatzka
Actually not. I'm always struggling to compile OpenFOAM related things on this machine. Even funkySetFields did not work...
I'm working with this machine at the university, but as far as I know there has been big trouble to compile OpenFOAM 1.5.x at all...
Old   July 1, 2009, 16:09
Assistant Moderator
Bernhard Gschaider
Sorry. Then it is not a groovyBC-problem per se. From the error message my first guess would be that it can't link to the OpenFOAM library because
  1. it is not there
  2. it is of a different architecture (32/64-bit? the file-command is your friend when it comes to determining whether your .o and the .so in question fit)
  3. they are not off the same ABI (incompatible) because the c++-compiler was changed in the meantime to a much higher version
My personal recommendation: try recompiling one of the standary-applications (interFoam for example). If that doesn't work either then remove all binary stuff from that OF-version and recompile from scratch
You're on your own. Good luck
Old   July 1, 2009, 16:59
sega's Avatar
Sebastian Gatzka
  1. it is not there
Thanks for your answer. Of course I'm stuck with this. Despite I'm not that new to linux I have to make sure of what you mean, when you are talkin about
  • OpenFOAM library. What do you mean by that?
  • .o or .os files. How are they related to the system architecture?
    What about the find-command in this case?! What should I search?
  • What is ABI at all?
  • and how can I check the current C++ compiler version?
Old   July 2, 2009, 04:56
Assistant Moderator
Bernhard Gschaider
I don't know either, some of the time
libOpenFOAM.so
for instance on my system
file $FOAM_LIBBIN/libOpenFOAM.so
prints something like
libOpenFOAM.so: ELF 64-bit LSB shared object, AMD x86-64, version 1 (SYSV), not stripped
If for instance you look at a .o file with
file example.o
the output should be similar:
example.o: ELF 64-bit LSB relocatable, AMD x86-64, version 1 (SYSV), not stripped
http://en.wikipedia.org/wiki/Applica...nary_interface
The ABIs of g++ are usually downward compatible. But if your OpenFOAM was compiled with a NEWER version of g++ than you are currently using (strange things happen)
which g++
g++ -v
But honestly: a recompile of your OF-installation seems to me to be the easiest solution in your case
Old   November 6, 2009, 08:28
Arne Stahlmann
Arnoldinho is on a distinguished road
I have also started using OpenFOAM for some of my simulations. When trying to use the groovyBC condition and testing the Demo cases coming with the boundary condition, I always get the following error, which is independent of the demo I am running (circulatingSplash, pulsedPitzDaily, groovywaveTank):
// using new solver syntax:
nuTilda
solver PBiCG;
preconditioner DILU;
tolerance 1e-08;
relTol 0;
Reading g
cannot open file
file: /home/stahlmann/OpenFOAM/OpenFOAM-1.6/src/groovyBC/Demos/circulatingSplash/constant/g at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
There is of course no g file. Do you have any ideas? I'm using Ubuntu 9.04 64-bit and OpenFOAM 1.6.
Arne
Arnoldinho is offline   Reply With Quote
Old   November 8, 2009, 05:06
matej forman
matejfor is on a distinguished road
I'm not very familiar with groovyBC, but I guess you're using 1.6.x which reads the gravitational acceleration from file in <case>/constant/g file. In previous versions the file was called different. So the only thing you have to do is to look into tutorials of your OpenFOAM installation and copy the g file to your case and check the vector of gravity is heading to where you want.
good luck
matej
matejfor is offline   Reply With Quote
Old   November 9, 2009, 05:04
Assistant Moderator
Bernhard Gschaider
Matej is right. It doesn't look like a problem with groovyBC, but like one of the usual 1.5/1.6-tranhsition problems
Bernhard
Old   January 7, 2010, 04:36
Michael
farbfilm is on a distinguished road
I think I need some help with the compilation of the groovybc!!
When I'm trying to do 'wmake libso', I get the following error:
michael@wopl:~/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/fields/fvPatchFields/derived/groovyBC> wmake libso
SOURCE=PatchResult.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -IMake/linux64GccDPOpt  -I/home/michael/OpenFOAM/OpenFOAM-1.6.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/michael/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/michael/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/PatchResult.o
In file included from PatchResult.C:34:
PatchResult.H:47:19: error: Field.H: No such file or directory
PatchResult.C:35:20: error: vector.H: No such file or directory
PatchResult.C:36:20: error: tensor.H: No such file or directory
PatchResult.C:37:24: error: symmTensor.H: No such file or directory
PatchResult.C:38:29: error: sphericalTensor.H: No such file or directory
PatchResult.H:62: error: ‘string’ does not name a type
PatchResult.H:86: error: ‘Field’ was not declared in this scope
PatchResult.H:86: error: expected primary-expression before ‘>’ token
PatchResult.H:86: error: expected primary-expression before ‘,’ token
PatchResult.H:86: error: expected primary-expression before ‘bool’
PatchResult.H:86: error: variable or field ‘setResult’ declared void
PatchResult.H:89: error: expected initializer before ‘<’ token
PatchResult.H:93: error: ISO C++ forbids declaration of ‘string’ with no type
PatchResult.H:93: error: ‘string’ declared as an ‘inline’ field
PatchResult.H:93: error: expected ‘;’ before ‘&’ token
In file included from PatchResult.H:105,
PatchResultI.H:40: error: variable or field ‘setResult’ declared void
PatchResultI.H:40: error: ‘Field’ was not declared in this scope
PatchResultI.H:40: error: expected primary-expression before ‘>’ token
PatchResultI.H:40: error: ‘val’ was not declared in this scope
PatchResultI.H:40: error: expected primary-expression before ‘bool’
PatchResultI.H:50: error: expected constructor, destructor, or type conversion before ‘<’ token
PatchResultI.H:75: error: expected initializer before ‘&’ token
PatchResult.C: In constructor ‘Foam::PatchResult::PatchResult()’:
PatchResult.C:46: error: class ‘Foam::PatchResult’ does not have any field named ‘valType_’
PatchResult.C:47: error: ‘NULL’ was not declared in this scope
PatchResult.C: In copy constructor ‘Foam::PatchResult::PatchResult(const Foam::PatchResult&)’:
PatchResult.C:55: error: class ‘Foam::PatchResult’ does not have any field named ‘valType_’
PatchResult.C:56: error: ‘NULL’ was not declared in this scope
PatchResult.C: In member function ‘void Foam::PatchResult::uglyDelete()’:
PatchResult.C:82: error: ‘valType_’ was not declared in this scope
PatchResult.C:82: error: ‘pTraits’ was not declared in this scope
PatchResult.C:82: error: ‘scalar’ was not declared in this scope
PatchResult.C:82: error: ‘::typeName’ has not been declared
PatchResult.C:83: error: expected type-specifier before ‘scalarField’
PatchResult.C:83: error: expected `>' before ‘scalarField’
PatchResult.C:83: error: expected `(' before ‘scalarField’
PatchResult.C:83: error: ‘scalarField’ was not declared in this scope
PatchResult.C:83: error: expected primary-expression before ‘>’ token
PatchResult.C:83: error: expected `)' before ‘;’ token
PatchResult.C:84: error: ‘vector’ has not been declared
PatchResult.C:85: error: expected type-specifier before ‘Field’
PatchResult.C:85: error: expected `>' before ‘Field’
PatchResult.C:85: error: expected `(' before ‘Field’
PatchResult.C:85: error: ‘Field’ was not declared in this scope
PatchResult.C:85: error: ‘vector’ was not declared in this scope
PatchResult.C:85: error: expected primary-expression before ‘>’ token
PatchResult.C:85: error: expected `)' before ‘;’ token
PatchResult.C:86: error: ‘tensor’ has not been declared
PatchResult.C:87: error: expected type-specifier before ‘Field’
PatchResult.C:87: error: expected `>' before ‘Field’
PatchResult.C:87: error: expected `(' before ‘Field’
PatchResult.C:87: error: ‘Field’ was not declared in this scope
PatchResult.C:87: error: ‘tensor’ was not declared in this scope
PatchResult.C:87: error: expected primary-expression before ‘>’ token
PatchResult.C:87: error: expected `)' before ‘;’ token
PatchResult.C:88: error: ‘symmTensor’ has not been declared
PatchResult.C:89: error: expected type-specifier before ‘Field’
PatchResult.C:89: error: expected `>' before ‘Field’
PatchResult.C:89: error: expected `(' before ‘Field’
PatchResult.C:89: error: ‘Field’ was not declared in this scope
PatchResult.C:89: error: ‘symmTensor’ was not declared in this scope
PatchResult.C:89: error: expected primary-expression before ‘>’ token
PatchResult.C:89: error: expected `)' before ‘;’ token
PatchResult.C:90: error: ‘sphericalTensor’ has not been declared
PatchResult.C:91: error: expected type-specifier before ‘Field’
PatchResult.C:91: error: expected `>' before ‘Field’
PatchResult.C:91: error: expected `(' before ‘Field’
PatchResult.C:91: error: ‘Field’ was not declared in this scope
PatchResult.C:91: error: ‘sphericalTensor’ was not declared in this scope
PatchResult.C:91: error: expected primary-expression before ‘>’ token
PatchResult.C:91: error: expected `)' before ‘;’ token
PatchResult.C:92: error: expected primary-expression before ‘bool’
PatchResult.C:92: error: expected `)' before ‘bool’
PatchResult.C:93: error: expected type-specifier before ‘Field’
PatchResult.C:93: error: expected `>' before ‘Field’
PatchResult.C:93: error: expected `(' before ‘Field’
PatchResult.C:93: error: ‘Field’ was not declared in this scope
PatchResult.C:93: error: expected primary-expression before ‘bool’
PatchResult.C:93: error: expected `)' before ‘bool’
PatchResult.C:93: error: expected `;' before ‘bool’
PatchResult.C:95: error: ‘WarningIn’ was not declared in this scope
PatchResult.C:96: error: ‘endl’ was not declared in this scope
PatchResult.C:97: warning: deleting ‘void*’ is undefined
PatchResult.C:100: error: ‘valType_’ was not declared in this scope
PatchResult.C:101: error: ‘NULL’ was not declared in this scope
PatchResult.C: In member function ‘void Foam::PatchResult::operator=(const Foam::PatchResult&)’:
PatchResult.C:109: error: ‘FatalErrorIn’ was not declared in this scope
PatchResult.C:111: error: ‘FatalError’ was not declared in this scope
PatchResult.C:111: error: ‘abort’ was not declared in this scope
PatchResult.C:115: error: ‘valType_’ was not declared in this scope
PatchResult.C:115: error: ‘const class Foam::PatchResult’ has no member named ‘valType_’
PatchResult.C:118: error: ‘NULL’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/PatchResult.o] Error 1
Can somebody help me??
I'm using OpenFOAM 1.6.x and Bison 2.3
Cheers Michael
farbfilm is offline   Reply With Quote
Old   January 7, 2010, 10:51
Michael
Well, I think I have another problem with my installation...
Old   January 8, 2010, 02:36
matej forman
Yep. It looking at the topmost error, the shell does not know anything about your foam installation. Have you checked the foamInstallationTest ? Your comp. does not see the src I would say. Always look at the topmost error first .
good luck
matej
Old   February 17, 2010, 09:30
Gijsbert Wierink
gwierink is on a distinguished road
Hi Michael,
Besides the OF installtion issue you mentioned, on the groovyBC wiki it says that groovyBC is know to work with Bison 2.4.1. Maybe you need to have a look at that as well ...
Regards, Gijs
gwierink is offline   Reply With Quote
wmake problems during custom utility compilation palazi88 OpenFOAM Programming & Development 11 August 13, 2018 20:52
OF211: ThirdParty and /src compiled, but not /applications... vkrastev OpenFOAM Installation 8 October 18, 2012 15:53
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) toolpost OpenFOAM Installation 15 September 21, 2012 09:38
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 03:43
Compiling new Solver with wmake lin123 OpenFOAM 3 April 13, 2010 14:18
