[swak4Foam] groovyBC - k-profile
Old   January 5, 2010, 06:46
Question groovyBC - k-profile
heavy_user is on a distinguished road
Hi Folks,
I am using groovyBC to implement a profile for different variables.
I successfully implemented a profile for velocity and for epsilon on different two different inlets.
But when I try do do the same for k (using k-epsilon-model) it crashes right away...i tryed to brake it down to find the problem and I am stuck right now...
When I do :
inlet-gas
type fixedValue;
value uniform 0.000138;
it works fine.
when I do:
inlet-gas
type groovyBC;
it crashes..
it says:
Courant Number mean: 2.78199e-12 max: 8.8507e-11
DILUPBiCG: Solving for Uy, Initial residual = 0.429436, Final residual = 4.56534e-17, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.999302, Final residual = 3.52628e-16, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 7.09251e-10, Final residual = 7.09251e-10, No Iterations 0
GAMG: Solving for p, Initial residual = 0.00208143, Final residual = 2.05939e-05, No Iterations 122
time step continuity errors : sum local = 1.5495e-15, global = -9.94268e-17, cumulative = 2.50625e-17
GAMG: Solving for p, Initial residual = 0.216801, Final residual = 0.0020369, No Iterations 20
time step continuity errors : sum local = 7.73954e-16, global = -2.65297e-17, cumulative = -1.4672e-18
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#7 main in "/home/itvns/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/buoyantBoussinesqPisoFoam"
#8 __libc_start_main in "/lib64/libc.so.6"
#9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating exception
is this a bug or am I doing something wrong??
thx for your help!
regards
heavy_user is offline   Reply With Quote
Old   January 5, 2010, 09:52
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by heavy_user View Post
when I do:
inlet-gas
type groovyBC;
it crashes..
<snip>
Depends on how you see it
What happens is that it implicitly gets expanded to
inlet-gas
    type            groovyBC;
valueExpression "0";
fractionExpression "1";
and value is only used as a first guess from then on it becomes 0 which is somthing that should not happen to k.
So you should write
inlet-gas
     type            groovyBC;
valueExpression "0.000138";
to get what you want
Bernhard
gschaider is offline   Reply With Quote
Old   January 5, 2010, 10:22
Hi Bernhard,
thx a lot for the answer...this way it works...BUT i am still confused...
The wiki says:
"valueExpression String with the value to be used if a Dirichlet-condition is needed. Defaults to zero"
Which i associated with assigning a "value". Since Dirichlet- gives the value at the boundary(!?).
--Whats the diference between "value" and "valueExpression"??
Somehow in the files for U and epsilon it works only defining:
"type, variables and valueExpression"
-- why is k different??
I ran into that problem since i am trying to have a profile matching experimental data.
I fittet spline to the data and used groovyBC to bring it on..
it should look like this:
type groovyBC;
variables
"MEAN2=0.92;r=sqrt(pos().x*pos().x+pos().y*pos().y );fact2=(-5.9481+21.679*r-33.885*r*r+30.097*r*r*r-16.745*r*r*r*r+6.0916*r*r*r*r*r-1.4707*r*r*r*r*r*r+0.23356*r*r*r*r*r*r*r-0.023442*r*r*r*r*r*r*r*r+0.001348*r*r*r*r*r*r*r*r* r-3.3838e-05*r*r*r*r*r*r*r*r*r*r);vel2=MEAN2*(-30.547+94.958*r-126.17*r*r+96.051*r*r*r-46.331*r*r*r*r+14.823*r*r*r*r*r-3.1929*r*r*r*r*r*r+0.45829*r*r*r*r*r*r*r-0.042037*r*r*r*r*r*r*r*r+0.0022294*r*r*r*r*r*r*r*r *r-5.2003e-05*r*r*r*r*r*r*r*r*r*r);";
valueExpression "r>1 ? (3/2)*(fact2*fact2*vel2*vel2) : 0.00002";
(at least this works for epsilon and U)...
How can i make it run?
I cant use:
value "r>1 ? (3/2)*(fact2*fact2*vel2*vel2) : 0.00002";//doesnt like it!
If I do
value 0.12345;
it is running fine, but i dont know what is goin on(which boundary is used)...
thx again!
regards!
Old   January 5, 2010, 14:19
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
The wiki says:
That's always the problem with documentation: it is clear to the documenter, but not to everyone else .....
In other words: I don't blame anybody if he feels like improving that Wiki-page, but I won't do it, because I understand it
In one sentence: valueExpression is used to calculate value.
value is always there. valueExpression is defined by groovyBC
Because you defined value there if I remember it correctly
type groovyBC;
variables
I cant use:
If I do
value 0.12345;
thx again!
regards!
a) Impressive. Would be less impressive if you used pow(r,3) etc
b) "value 0.12345;" is only there as a placeholder before valueExpression is computed for the first time (which should be before any equation is solved). Basically it is only there to keep paraFoam happy (because that usually doesn't know about grovvy)
Bernhard
Old   January 7, 2010, 04:46
Lightbulb
Bernhard
a) -> I will do so, thx!
b) -> thats the information I have been looking for, thank you soo much!!!!!
I might add this information to the wiki, if you dont mind...
But thats a thing I dont understand..since you have been able to create groovyBC, i suppose you dont need it.
So mostly other people will benefit from it. But without a more detailed documentation it is not as usefull as it could be..but it should be measure up the efford you put in it..
best regards
Old   January 7, 2010, 12:33
Default tracing errors...(call me alice)
Hi Folks (and special greetings to Bernhard ),
i have spend a lovely day with OF and groovyBC tracing errors..and now I am kind of stuck...again...
I am dealing with an error that tells me that groovyBC doesnt like negative expressions like sqrt(-value), which i can understand, i dont like them either..
#4 Foam::sqrt(Foam::UList<double> const&) in "/home/itvns/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
I use:
type groovyBC;
variables "MEAN2=9.2;R=0.0026;r=(sqrt(pos().x*pos().x+pos(). y*pos().y))/R;vel2=MEAN2*(-29.547 + 94.958 * r - 126.17 * pow(r,2) + 96.051 * pow(r,3) - 46.331 * pow(r,4) + 14.823 * pow(r,5) - 3.1929 * pow(r,6) + 0.45829 * pow(r,7) - 0.042037 * pow(r,8) + 0.0022294 * pow(r,9) - 5.2003e-05 * pow(r,10));";
value uniform 0.053;
valueExpression " r>2 && r<3 ? sqrt(vel2*vel2*vel2)/(2*R*0.1) : 35663 ";
I fittet a spline to experimental Data (which is used for vel2).
Since there seesm to be negative expression where it should not be i finally checked the spline i fitted with xmgrace and xmgrace came up with a different curve. (see attachment, I am saving this fun for tomorrow)
But if I specify a region "r>2 && r<3 "in which the spline should give certainly positive values I still end up with a negativ value.
At the moment I can see only three possebilities for that:
1. xmgrace (or its user) messed up worse than it shows on graphs
2. funkyBC does strange things solving the equation for r
3. "r>2 && r<3 " doesn not work limiting the range where it uses the
equation
either way i am screwed...any ideas how to unscrew me??
regards
Old   January 7, 2010, 12:48
...one more question, just curious about it..
Is it possible that groovyBC doesnt like "z" ???
When I did (for testing things):
type groovyBC;
variables "z=0.053;";
valueExpression " z";
he says :
Parser Error at "1.1" :"syntax error, unexpected 'z'"
but when I do:
type groovyBC;
variables "g=0.053;";
valueExpression " g";
it works...(yes we had a looot of fun today )...
Old   January 11, 2010, 05:01
Assistant Moderator
Bernhard Gschaider
Would I mind? Au contraire. That is the idea behind the Wiki. Every improvement of that page is welcome
Old   January 11, 2010, 05:12
Assistant Moderator
Bernhard Gschaider
I'm afraid the answer is: yes (and x and y as well)
type groovyBC;
he says :
but when I do:
type groovyBC;
The problem is that z is used for getting the z-component of a vector (for instance U.z) and therefor is a "special" symbol for the parser (this is a shortcoming of the grammar that was inherited from funkySetFields)
I'll have a look at it when I find time and should I then remember it (the process of remembering would be aided by a report at https://sourceforge.net/apps/mantisb...e_status_id=90)
Bernhard
Old   January 11, 2010, 05:29
Assistant Moderator
Bernhard Gschaider
I use:
type groovyBC;
equation
OK. That's a tricky one. The problem is that when groovy evaluates (a ? b : c) it evaluates the whole b and c. Then it evaluates a and according to that picks values from b or c. The problem with that approach is that it is
a) inefficient
b) leads to that kind of unexpected error
The only way to work around that would be to rewrite groovy so that it does some kind of lazy-evaluation on a per-face basis and that would be a major rewrite (which would make cases that don't use conditionals inefficient). So it is quite unlikely to happen
The other possibility would be to issue a warning and "fix" negative values before feeding them into sqrt (and similar functions).
As a quick fix I would suggest in your case ANOTHER variable (sorry) vel2pos which you set to 0 if vel2 is negative.
Bernhard
Old   January 11, 2010, 11:00
Bernhard
, i knew it ...
Bernhard
no prob, I love your tool and will use the little "workarround" with the extra variable...
I added some things to wiki, plz check if you like it that way...
regards
Old   May 26, 2010, 10:41
Default help about groovyBC
  #12
Joseph
tamsilian is an unknown quantity at this point
Hi sir/madam
i simulated polymer in extruder(screw mill) by ViscoElastic fluidFoam,Jovani. According to my geometry, velocity vectors in boundary condition are changed .As result i should code variables condition in 0File>> U>> movingWalls.do you know that GroovyBC was compiled to OpenFoam as defualt or i have to compile it?and how to compile groovyBC to OpenFoam v.1.6?if you coded one geometry by groovyBC this is thanksful to sent it me by tamsilian@gmail.com. Could u help me?if you need more information about my geometry please request me.
Thanks in advanced your help
tamsilian is offline   Reply With Quote
Old   May 26, 2010, 10:56
Originally Posted by tamsilian View Post
Hi sir/madam
Hi Tamsilian,
the answer to most of your questions is here:
http://openfoamwiki.net/index.php/Contrib_groovyBC
if you have any further questions...I will try to help...
regards
[swak4Foam] groovyBC - inlet profile at complex terrain potac OpenFOAM Community Contributions 2 January 3, 2017 19:18
[swak4Foam] Problem with fully developed velocity profile groovyBC in 2D axi-sym mesh harshad88 OpenFOAM Community Contributions 7 July 24, 2014 14:28
[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong? vitorspadeto OpenFOAM Community Contributions 4 June 19, 2014 15:31
[swak4Foam] parabolic velocity profile with fluctuations (groovyBC?) newOFuser OpenFOAM Community Contributions 17 July 15, 2013 17:27
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
