[swak4Foam] groovyBC or parabolicVelocity + time
Old   February 14, 2011, 10:12
Default groovyBC or parabolicVelocity + time
Rickard
Rickard.Solsjo is on a distinguished road
Hi
I was trying to get the hang of groovyBc and the parabolic inlet velocity condition.
Im looking for an opinion on whether one or the other is better combined with a time restriction.
Putting it more clearly
At the moment I use timeVaryingUniformFixedValue with a ramp and outOfBounds clamp.
This is running okay, however I want to change the profile over the area so that it leaves my patch with a certain angle, 21.5degrees.
Can groovyBC and parabolic injection be combined with the time-extent? If so, how?
Appreciate the help!
R
Rickard.Solsjo is offline   Reply With Quote
Old   February 14, 2011, 10:34
Assistant Moderator
Bernhard Gschaider
Originally Posted by Rickard.Solsjo View Post
Hi
R
Yep. Search for "timeline" on http://openfoamwiki.net/index.php/Contrib_groovyBC
Old   February 14, 2011, 12:43
Rickard
Thx
this timeline would simply be e.g.
--> "name of timeLine file"
(t(start)
t2
t(end)
Old   February 14, 2011, 13:22
Assistant Moderator
Bernhard Gschaider
Thx
(t(start)
t2
t(end)
It's the same format as for timeVaryingUniform. Have a look at the example case (groovyBC) that uses it
Bernhard
Old   February 15, 2011, 04:16
Rickard
Ofc I looked at it. It says something about timevaryinguniform, however it only related to the "usual" conditions. I've been trying to find the original documentation of this without success. As I said above I've used timeVaryingUniformFixedValue before.
The only example of timelines at the contrib wiki are
timelines ();
or sth like
timelines (
file... impulse
without specifying the impulse input.
Thx
R
Old   February 15, 2011, 05:20
Assistant Moderator
Bernhard Gschaider
timelines ();
or sth like
timelines (
file... impulse
Thx
R
That is in the example files. If you feel it should be on the Wiki page feel free to extend it
Bernhard
Old   February 15, 2011, 05:24
Rickard
I didn't mean to be disrespectful, groovyBC is a wonderful tool.
My only concern was that the timelines input wasn't extended enough, so I dont know what the input file looks like
Regards
R
Old   February 15, 2011, 07:25
Default one more question..
Rickard
Mr GschaiderMay I ask yet another question.
At the moment I just have a mean velocity leaving the patch in the axial direction without any radial components.
I would like to create a boundary condition where the flow is leaving the patch at a certain angle relative to the center axis with a speed thats Ucos(theta) where U is the velocity where the angle theta=0.
My gridstructure is cartesian, so my question is if I have to calculate all of the x,y,z components or is multiplying a vector depending on the angle to the scalar velocity-value simply enough? Can groovyBC handle this?
I hope you understand my question
Regards
R
Old   February 15, 2011, 08:30
Assistant Moderator
Bernhard Gschaider
Regards
R
Not a problem.
Don't know how good groovyBC actually is (I'm biased) but its a lot better than the documentation
As you mentioned above that you'd already used timeVaryingUniform I assumed that you were familiar with the file format for those files
If you think that that the file should be on the Wiki page feel free to add it
Old   February 15, 2011, 08:42
Assistant Moderator
Bernhard Gschaider
Regards
R
I don't quite understand what you're trying to achive. But if it can be expressed with the usual vector operations (keep in mind that the operators & and ^ are inner and cross-product for vectors) then it can be done.
But I only help with problems with groovyBC. Not with vector arithmetics
Old   February 15, 2011, 10:33
Rickard
so basically, it is something like this that i want to achieve
patch jet
type groovyBC;
variables: "Uz=150;rmax=0.0005;r=sqrt(pow(pos().x,2)+pow(pos( ).y,2));thetaMax=0.9825;theta=thetaMax*r/rmax";
"(r<=0.5) ? U=Uinlet:U=vector(0,0,0);" <-- is this included into the variables?
value: Uinlet="Uz*cos(theta)*vector(0,0,1)+Uz*sin(theta)* vector(0,1,0)*Uz*sin(theta)*vector(1,0,0):Uinlet=v ector(0,0,0)";
I appreciate the help
Old   March 27, 2018, 02:00
Default combining parabolic inlet velocity profile with time varying velocity vector values
  #12
Jawahar
jawapasu is on a distinguished road
patch jet
type groovyBC;
I am trying to do something similar to yours. can you help me out? pls refer to the title of this msg. I have posted a thread.
jawapasu is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 10:54
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
