[swak4Foam] groovyBC elevated inlet. pos() issue
Old   June 22, 2011, 06:37
Default groovyBC elevated inlet. pos() issue
grjmell is on a distinguished road
I've got an issue with groovyBC. It makes my run crash instantly. I'm using twoPhaseEulerFoam and I have an elevated inlet (see pic), the inlet is above a wall. I want to put a logarithmic velocity profile onto that inlet. I've implemented it in groovy heres the code.
    myinlet
        type            groovyBC;
        variables      "u_f=0.0239;z0=0.0000333;K=0.41;vel=(u_f/K)*log((pos().z)/z0)*normal();";
        valueExpression "-vel";
This works, if the inlet goes from the bottom to the top, however it seems that when it is elevated then there is an issue with pos().z, it makes my run crash instantly with this error. When i take pos().z out, it works again, so it is not a problem with groovyBC as such. I know i need to account for pos().z not starting at zero for my profile but it should nevertheless work?
Starting time loop
Courant Number mean: 0 max: 0
Max Ur Courant Number = 0
deltaT = 0.000598802
Reading/calculating field UaMean
Reading/calculating field UbMean
Reading/calculating field alphaMean
Reading/calculating field pMean
fieldAverage: starting averaging at time 0
Time = 0.000598802
DILUPBiCG:  Solving for alpha, Initial residual = 1.48592e-17, Final residual = 1.48592e-17, No Iterations 0
Dispersed phase volume fraction = 0.135285  Min(alpha) = 0  Max(alpha) = 0.6
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3   in "/lib/libm.so.6"
#4  log in "/lib/libm.so.6"
#5  Foam::log(Foam::Field<double>&, Foam::UList<double> const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#6  Foam::log(Foam::UList<double> const&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#7  parserPatch::PatchValueExpressionParser::parse() in "/home/gjm1v07/OpenFOAM/gjm1v07-1.7.1/lib/linux64GccDPOpt/libswak4FoamParsers.so"
#8  Foam::PatchValueExpressionDriver::parse(std::string const&) in "/home/gjm1v07/OpenFOAM/gjm1v07-1.7.1/lib/linux64GccDPOpt/libswak4FoamParsers.so"
#9  Foam::CommonValueExpressionDriver::evaluateVariable(Foam::word const&, Foam::string const&) in "/home/gjm1v07/OpenFOAM/gjm1v07-1.7.1/lib/linux64GccDPOpt/libswak4FoamParsers.so"
#10  Foam::CommonValueExpressionDriver::addVariables(Foam::string const&, bool) in "/home/gjm1v07/OpenFOAM/gjm1v07-1.7.1/lib/linux64GccDPOpt/libswak4FoamParsers.so"
#11  Foam::CommonValueExpressionDriver::addVariables(Foam::List<Foam::string> const&, bool) in "/home/gjm1v07/OpenFOAM/gjm1v07-1.7.1/lib/linux64GccDPOpt/libswak4FoamParsers.so"
#12  Foam::groovyBCFvPatchField<Foam::Vector<double> >::updateCoeffs() in "/home/gjm1v07/OpenFOAM/gjm1v07-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so"
#13  Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensionSet const&) in "/opt/openfoam171/applications/bin/linux64GccDPOpt/twoPhaseEulerFoam"
#14
#15  __libc_start_main in "/lib/libc.so.6"
#16
Floating point exception
grjmell is offline   Reply With Quote
Old   June 22, 2011, 23:11
Assistant Moderator
Bernhard Gschaider
    myinlet
        type            groovyBC;
If pos().z<=0 anywhere, then it will fail (unless you unset FOAM_SIGFPE - then you will get NaN in these places - also not a good solution)
Old   June 23, 2011, 03:53
Thanks Bernhard. I get it.
Old   January 23, 2013, 06:56
immortality's Avatar
Ehsan
immortality is on a distinguished road
dear bernhard
How can i unset FOAM_SIGFPE to find where NANs are occuring?
Thanks.
immortality is offline   Reply With Quote
Old   January 23, 2013, 07:02
Ehsan
another question occured! At my case that is similar to what Greg said i have set pos().y=0 at starting.i don't figure out it.does it have any problem?why?
Old   January 23, 2013, 08:11
Assistant Moderator
Bernhard Gschaider
Originally Posted by immortality View Post
dear bernhard
Thanks.
The answer is in your question:
unset FOAM_SIGFPE
But that only makes the solver run and calculate garbage. Doubt that this will help you much
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 23, 2013, 08:14
Assistant Moderator
Bernhard Gschaider
PLEASE be more specific. One can only GUESS what you mean. Of course pos().y==0 can be a problem. For instance if you calculate the logarithm of it
groovybc, twophaseeulerfoam
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
[swak4Foam] groovyBC interFoam splitted inlet -- massflowrate FerdiFuchs OpenFOAM Community Contributions 1 October 1, 2014 07:51
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
[swak4Foam] groovyBC, coupling inlet with velocity at specific point location olivierG OpenFOAM Community Contributions 6 June 23, 2012 08:44
