[swak4Foam] A problem of groovyWaveTank
Old   August 1, 2011, 04:34
Default A problem of groovyWaveTank
bojiezhang
bojiezhang is on a distinguished road
hello everyone:
when I run the case groovyWaveTank (http://idisk.mac.com/egpaterson-Publ...ovyWaveTank.gz), it says error
" --> FOAM FATAL IO ERROR:
keyword PIMPLE is undefined in dictionary "/home/host/OpenFOAM/OpenFOAM-2.0.0/swak4Foam/Examples/groovyBC/groovyWaveTank/system/fvSolution".
I have downloaded swak4Foam and compiled it well and I do not know how to solve it, please help me, thank you in advance!
bojiezhang
bojiezhang is offline   Reply With Quote
Old   August 1, 2011, 04:57
Pablo Higuera
Phicau is on a distinguished road
Hi
just change word "SIMPLE" to "PIMPLE" in your fvSolution dictionary.
Phicau is offline   Reply With Quote
Old   August 1, 2011, 05:09
bojiezhang
Dear Phicau,
Thank you for your reply! There is no SIMPLE in the fvSolution dictionary.The whole content is:
PISO
momentumPredictor no;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
nGammaCorr 1;
nGammaSubCycles 3;
cGamma 1;
pdRefCell 0;
pdRefValue 0;
pRefProbe
fields (pd);
probeLocations ((0.51 0.51 0.51));
But when I change PISO to PIMPLE , the error like this:
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
cannot find file
file: /home/host/OpenFOAM/OpenFOAM-2.0.0/swak4Foam/Examples/groovyBC/groovyWaveTank/0/p_rgh at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
can you help me?
bojiezhang
Old   August 1, 2011, 05:59
Pablo Higuera
Sorry, I meant PIMPLE instead of PISO...
Old   August 1, 2011, 06:07
bojiezhang
Reading field p_rgh
cannot find file
FOAM exiting
Old   August 1, 2011, 06:14
Pablo Higuera
Do you have p_rgh file (which provides the BCs for pressure) in the 0 directory?
Old   August 1, 2011, 06:28
bojiezhang
no, just have the file "pd", and the fvsolution also use the name pd as below:
pd GAMG
tolerance 1e-8;
relTol 0.05;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration false;
nCellsInCoarsestLevel 10;
agglomerator faceAreaPair;
mergeLevels 1;
pdFinal PCG
preconditioner
type GAMG;
tolerance 1e-8;
relTol 0;
nVcycles 2;
nPreSweeps 0;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
tolerance 1e-8;
relTol 0;
maxIter 20;
Old   August 1, 2011, 06:35
Pablo Higuera
Then I guess you will have to rewrite certain things of your case in order for it to work, since it seems it is from a very old OF version.
Take a look at damBreak tutorial case and modify consistently the files.
Old   August 1, 2011, 06:36
bojiezhang
I use the swak4Foam in the openfoam 2.0.0, not in the openfoam-extended, does it matter?
Old   August 1, 2011, 06:40
bojiezhang
But the file version which written is 2.0
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object pd;
Old   August 1, 2011, 09:25
Assistant Moderator
Bernhard Gschaider
The problem you're experiencing have got to do with the face that the waveTank-case was set up for OF and 1.5 and interFoam went through some changes since then. The best thing would be to compare the dambreak-case for 1.5 and 2.0 and apply the same changes you see there to the waveTank
Old   August 1, 2011, 10:01
bojiezhang
Thank you very much, I know it now! But I have another question, I defined the alpha1 inlet like:
inlet
type groovyBC;
valueExpression "(pos().y<=A*cos(-w*time())) ? 1 : 0";
variables "l=1.56;A=0.01;g=vector(0,-9.81,0);k=2*pi/l;w=sqrt(k*mag(g));";
timelines ();
but it does not work, and says that
"--> FOAM Warning :
From function groovyBCFvPatchField<Type>::groovyBCFvPatchField(c onst fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict)
in file groovyBCFvPatchField.C at line 119
No value defined for alpha1 on inlet therefore using 40{0}
No value is defined in the inlet boundary and the value is set to be zero at last, I do not know how to modify it, can you help me? Thank you in advance!
Old   August 1, 2011, 10:16
Assistant Moderator
Bernhard Gschaider
inlet
type groovyBC;
timelines ();
"--> FOAM Warning :
Just add a
value uniform 0;
line or so to the BC. This warning is only of consequence if another groovyBC uses alpha1 before that BC is evaluated for the first time. Very unlikely that this will happens, that's why it is only a warning
Bernhard
Old   August 1, 2011, 10:58
bojiezhang
Originally Posted by gschaider View Post
Just add a
value uniform 0;
Bernhard
Yeah, it does work, thank you very much! But if I add "value uniform 0" to the inlet boundary, when the wave begins to transmit, it is not like wave and the phenomenon is strange. If I add "value uniform 1" to it, the phenomenon in the boundary is not true! Do you have any advice? Thank you!
Old   August 1, 2011, 12:11
Assistant Moderator
Bernhard Gschaider
Not familiar enough with interFoam to say when which BC is evaluated. Maybe setting the value with funkySetBoundaryCondition to be consistent with the evaluated value at t=0 may help
Old   August 1, 2011, 23:51
bojiezhang
OK! Thank you very much! I will try it later!
Old   August 9, 2011, 05:12
idefix is on a distinguished road
I have the same problem now. How did you solve yours?
idefix is offline   Reply With Quote
Old   August 9, 2011, 05:14
Here´s the error massage:
cannot find file
file: /OpenFOAM/test/0.001/p_rgh at line 0.
FOAM exiting
Old   December 19, 2018, 13:35
Default PLEASE HELP Similar Problem
  #19
Justine
JBrake is on a distinguished road
I am running a model, similar to the propeller tutorial, where I have a cyclic AMI between a cylinder and the rest of the domain. I get the following error when running:
--> FOAM FATAL ERROR:
cannot find file "/home/jbrakefi/OpenFOAM/olaFlow/My_olaFlow/dynamic_OWSC/0.01/p_rgh"
From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 505.
FOAM exiting
I have tried searching for answers on this forum and elsewhere with no luck so far. I don't know where to begin to troubleshoot this one.
JBrake is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
