[swak4Foam] groovyBC
Old   March 26, 2012, 11:57
Default groovyBC
Maike
mugi is on a distinguished road
I try to set up a depth dependent Temperature Gradient for a case in OpenFOAM with groovyBC.
FLOOR
type groovyBC;
variables "ypos=pos().y;";
valueExpression "(ypos-7300)*(-0.025)+273";
when I run the case, I get the following in the output of the first written timestep:
FLOOR
type groovyBC;
refValue nonuniform List<scalar>
283
(... here are 283 correct values);
refGradient uniform 0;
valueFraction uniform 1;
value nonuniform List<scalar>
283
(... here are the same 283 values);
gradientExpression "0";
fractionExpression "1";
timelines (
why is it written in refValue and value? I use a Temperature reference Value and define it elsewhere, to calculate the density... But this one I don't need.
Then there is a further problem, no clue if it's connected...
The field phi gets a completly wrong number of points for the internal field and several nan. The field U gets the right number of points in the internal field but as well a lot of nan... Does someone have an idea about this?
Cheers,
Maike.
mugi is offline   Reply With Quote
Old   March 26, 2012, 16:49
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
FLOOR
type groovyBC;
FLOOR
type groovyBC;
283
283
timelines (
value is used by almost ever BC and the actual value on the patch
refValue is something used by the mixed-BC (which groovyBC inherits from) to set that value-value (see the mixed-BC in the UserGuide to see what that actually means)
groovyBC sets the refValue from the valueExpression.
So all three depend on each other (the wonder of inheritance) The only reason that value and refValue are the same is because your fractionExpression is "1" (see the mixed-docu and you'll be enlightened)
With "wrong number" you mean "different from the internalField in T". That is because phi is a surfaceField and all other fields are volumeFields. So this is no problem.
phi and U depend on each other so the NaN are no surprise. Most likely there is a problem during the solution of the Momentum/Continuity-equations.
gschaider is offline   Reply With Quote
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
