OpenFOAM 2.2.0 installation on scientific-linux
Like Tree1Likes
  • 1 Post By linnemann
Old   March 16, 2013, 08:30
Exclamation OpenFOAM 2.2.0 installation on scientific-linux
Harshawardhan
kulkarni Harshawardhan is on a distinguished road
I got this error while installing OF 2.2.0 on scintific Linux (cluster)
Kindly help
readSolidDisplacementFoamControls.H: In function ‘int main(int, char**)’:
readSolidDisplacementFoamControls.H:3: warning: unused variable ‘nCorr’
readSolidDisplacementFoamControls.H:5: warning: unused variable ‘convergenceTolerance’
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/tractionDisplacementFvPatchVectorField.o Make/linux64GccDPOpt/solidDisplacementFoam.o -L/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \
-lfiniteVolume -lOpenFOAM -ldl -lm -o /home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidDisplacementFoam
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make[2]: *** [/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidDisplacementFoam] Error 1
make[2]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidDisplacementFoam'
make[1]: *** [solidDisplacementFoam] Error 2
make[2]: Entering directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
Making dependency list for source file tractionDisplacementCorrection/tractionDisplacementCorrectionFvPatchVectorField.C
Making dependency list for source file solidEquilibriumDisplacementFoam.C
make[2]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
SOURCE=tractionDisplacementCorrection/tractionDisplacementCorrectionFvPatchVectorField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o
SOURCE=solidEquilibriumDisplacementFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/solidEquilibriumDisplacementFoam.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o Make/linux64GccDPOpt/solidEquilibriumDisplacementFoam.o -L/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \
-lfiniteVolume -lOpenFOAM -ldl -lm -o /home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam
make[2]: *** [/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam] Error 1
make[1]: *** [solidEquilibriumDisplacementFoam] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis'
make: *** [stressAnalysis] Error 2
make: Target `application' not remade because of errors.
kulkarni Harshawardhan is offline   Reply With Quote
Old   March 20, 2013, 13:38
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Means that something went wrong long before this error.
You need to break the compilation just after the first error or output to a log file so its possible to scroll back to the first error.
./Allwmake > make.log 2>&1
Your other options is to use my precompiled images just uploaded on the centFoam project.
http://sourceforge.net/projects/centfoam/
wyldckat likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
installation of open foam, scientific linux
OpenFoam installation environment error (using CAELinux) vahid_paris OpenFOAM Installation 1 November 22, 2011 15:11
OpenFoam Installation in Redhat Enterprise linux 5 sahm OpenFOAM Installation 78 November 1, 2011 15:22
OpenFoam 2.0.1 installation shailesh.nitk OpenFOAM Installation 4 October 4, 2011 08:50
OpenFOAM Installation rclprice OpenFOAM Installation 1 July 21, 2011 16:31
Some Query on Installation of OpenFoam lzgwhy OpenFOAM Installation 1 July 15, 2009 03:20
