[OpenFOAM.org] OpenFOAM Mac OS Mavericks
Old   January 2, 2015, 03:53
Exclamation OpenFOAM Mac OS Mavericks
Julian Ruiz
JulianRuiz is on a distinguished road
Hello there, I'm trying to install OpenFOAM 2.2.2 on Mavericks. I've done everything listed in this tutorial:
https://openfoamwiki.net/index.php/I...nFOAM_Building
But when i run ./Allwmake 2>&1 | tee logName.log, i have some issues.
Error .log File (Image)
Someone help me please. This is my log file. Thanks!
Julian.log.zip
JulianRuiz is offline   Reply With Quote
Old   January 2, 2015, 08:53
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
as the error is in CGAL interface, what is version number of CGAL library on your system? As 2.2.2 is rather old CGAL could change API in the newer versions, so you get compilation error.
alexeym is offline   Reply With Quote
Old   January 2, 2015, 12:37
Julian Ruiz
Sorry but i don't know to much. Where can i find the cgal version?. I installed cgal with macports.
Old   January 2, 2015, 13:01
Julian Ruiz
Originally Posted by alexeym View Post
I found this: cgal seems to have been updated (port version: 4.5, new version: 4.5.1)
Last edited by JulianRuiz; January 3, 2015 at 00:40. Reason: message quote mistake
Old   January 5, 2015, 00:27
Default Problem not solved
Julian Ruiz
Hello there, i applied a new patch. Now my problems are:
ERROR: ParaView not found in
make[2]: *** [/Users/Julian/OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOpt/bin/surfaceFeatureExtract] Error 1
make[1]: *** [surfaceFeatureExtract] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [surface] Error 2
make: Target `application' not remade because of errors.
make[2]: *** [/Users/Julian/OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOpt/bin/fireFoam] Error 1
make[1]: *** [fireFoam] Error 2
make: *** [combustion] Error 2
make[2]: *** [/Users/Julian/OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOpt/bin/SRFSimpleFoam] Error 1
I don't know what to do. Help please . I need OpenFOAM to compile LIGGGHTS (CFDEM)
THKS!
Old   January 5, 2015, 06:33
Alexey Matveichev
You can start by posting full log-file (as the part you've posted lacks the reason for the error). Also, as the tutorial you're referencing contains lots of links to the patches, you can specify what patch did you use.
Old   January 5, 2015, 09:05
Julian Ruiz
Hi alexeym!
I applied a SurfaceCGALfix patch posted here (#54):
http://www.cfd-online.com/Forums/ope...ac-os-x-3.html
With that patch some errors disappeared.
My last log file:
Julian.log.zip
Thks!
Old   January 5, 2015, 12:08
Alexey Matveichev
errors in your log-file:
g++-mp-4.6 ... -L/opt/local/lib -L/opt/local/lib -L/opt/local/lib -lboost_thread-mt -lmpfr -L/opt/local/lib -llapack -latlas -lgfortran -lblas -lCGAL -lmeshTools -ledgeMesh -ltriSurface -lsampling -lOpenFOAM -ldl   -lpthread -lm -o .../OpenFOAM/OpenFOAM-2.2.2/platforms/darwinIntel64Gcc46DPOp
ld: library not found for -latlas
collect2: ld returned 1 exit status
You don't have Atlas library installed. Guess, LAPACK_LIB variable contains this value. It is set in OpenFOAM-2.2.2/applications/utilities/surface/surfaceFeatureExtract/Allwmake script. Try installing Atlas using Macports. Or remove -latlas from the variable.
Same thing with surfaceFind utility.
Undefined symbols for architecture x86_64:
  "Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::v
olMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&
, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo con
st&, Foam::word const&)", referenced from:
      _main in fireFoam.o
  "Foam::compressible::turbulenceModel::typeName", referenced from:
      _main in fireFoam.o
Problem with Make/options file for fireFoam utility, certain libraries are missing from EXE_LIBS line.
  "Foam::incompressible::turbulenceModel::typeName", referenced from:
      _main in SRFSimpleFoam.o
ld: symbol(s) not found for architecture x86_64
Same thing as #2.
Other parts of OpenFOAM should be usable. If you can live without those utilities and solvers, you can proceed with building LIGGGHTS.
Old   January 6, 2015, 11:44
Julian Ruiz
      _main in fireFoam.o
      _main in fireFoam.o
Same thing as #2.
Hi alexeym, thanks for you patience.
I have some questions.
#1: I builded atlas using macports. My console looks like this:
Attachment 36370
But i noticed that atlas is using gcc4.9. But when i biulded OpenFOAM it's using gcc4.6. Do i have to configure atlas to work with other gcc version?
#2 & #3: You said that my library is missing. I'm not an expert building things in terminal. So could you be more specific please, what i have to do?. I'll appreciate that.
I'll be using LIGGGHTS (CFDEM) to simulate two-phase flow into hydrocyclone. if you think that i have problems with other solvers that matter in this case, tell me please.
Here it is my log file after building atlas.
Julian.log.zip
I''ll be waiting for your answer.
Old   January 6, 2015, 12:08
Alexey Matveichev
Attachment 36370 was lost somehow. Any way errors caused by absent Atlas disappeared from log-file. Ether you can leave everything as it is, or you can try to check if atlas port has gcc46 variant and build it with gcc46.
The only errors I was able to find in attached log file is of the following type:
  "Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&)", referenced from:
      _main in fireFoam.o
      _main in fireFoam.o
Usually this is caused by absent -lcompressibleTurbulenceModel in Make/options. For example here's relevant part of Make/options for fireFoam:
EXE_LIBS = \
    -lcompressibleRASModels \
    -lcompressibleLESModels \
    -lODE
On OS X usually you have to add -lcompressibleTurbulenceModel before -lcompressibleRASModels. I.e. Make/options should be something like:
EXE_INC = \
EXE_LIBS = \
    -lcompressibleTurbulenceModel \
    -lODE
This addition is necessary for fireFoam and SRFSimpleFoam.
As I've never built/used LIGGGHTS I can't tell you what problems you can encounter with it. Maybe you'll need to add -lincompressibleTurbulenceModel to Make/options of the solver and library.
Old   January 6, 2015, 13:13
Julian Ruiz
I'll let atlas work under defautl gcc version (not 4.6, i'll try to change it if i have problems with LIGGGHTS).
These lines
EXE_INC = \
EXE_LIBS = \
-lODE
i have to run them with terminal or copy and pasty into sort kind of file. Sorry but i didn't understand that part.
Old   January 6, 2015, 14:27
Alexey Matveichev
You have to go to $FOAM_APP/solvers/combustion/fireFoam, open Make/options file in editor and add '-lcompressibleTurbulenceModel \' line before '-lcompressibleRASModels \'. Then you run wmake in $FOAM_APP/solvers/combustion/fireFoam folder (it's rather strange that this change is not a part of the patches you've applied).
So in terminal it should be something like
$ cd $FOAM_APP/solvers/combustion/fireFoam
$ sed -i~ 's/-lcompressibleLESModels/& -lcompressibleTurbulenceModel/g' Make/options
$ wmake
Do the same thing with SRFSimpleFoam. Though, if you're not planning to use these two solvers I'm not quite sure these edits worth doing.
Old   January 6, 2015, 14:47
Julian Ruiz
I run the code posted above, ending with this message:
Salida guardada del terminal.txt
Old   January 6, 2015, 14:58
Alexey Matveichev
This time it's another library. Here's contents of Make/options from my installation:
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/fvOptions/lnInclude \
    -I${LIB_SRC}/meshTools/lnInclude \
    -I${LIB_SRC}/sampling/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/compressible/turbulenceModel \
    -I$(LIB_SRC)/lagrangian/distributionModels/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/solid/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/solidChemistryModel/lnInclude \
    -I$(LIB_SRC)/combustionModels/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/solidProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/solidMixtureProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/liquidProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/properties/liquidMixtureProperties/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/thermophysicalFunctions/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/SLGThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/radiationModels/lnInclude \
    -I$(LIB_SRC)/regionModels/regionModel/lnInclude \
    -I$(LIB_SRC)/regionModels/surfaceFilmModels/lnInclude \
    -I$(LIB_SRC)/regionModels/pyrolysisModels/lnInclude \
    -I$(LIB_SRC)/lagrangian/basic/lnInclude \
    -I$(LIB_SRC)/lagrangian/intermediate/lnInclude \
    -I$(LIB_SRC)/ODE/lnInclude
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -lspecie \
    -lfluidThermophysicalModels \
    -lsolidProperties \
    -lsolidMixtureProperties \
    -lthermophysicalFunctions \
    -lreactionThermophysicalModels \
    -lSLGThermo \
    -lchemistryModel \
    -lsolidChemistryModel \
    -lcombustionModels \
    -lregionModels \
    -lradiationModels \
    -lsurfaceFilmModels \
    -lpyrolysisModels \
    -lregionCoupling \
    -llagrangianIntermediate \
    -llagrangian \
    -lODE
Compare it with yours, add missing "-l..." lines (this time open file in editor), run wmake.
Old   January 6, 2015, 15:23
Julian Ruiz
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -lspecie \
    -lsolidProperties \
    -lSLGThermo \
    -lchemistryModel \
    -lregionModels \
    -lradiationModels \
    -lpyrolysisModels \
    -lregionCoupling \
    -llagrangian \
    -lODE
I the directory
i opened the Make/options file with sudo nano .Make/options (or vi .Make/options) but this file is empty, it seems is a new directory.
Old   January 6, 2015, 22:02
Julian Ruiz
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -lspecie \
    -lsolidProperties \
    -lSLGThermo \
    -lchemistryModel \
    -lregionModels \
    -lradiationModels \
    -lpyrolysisModels \
    -lregionCoupling \
    -llagrangian \
    -lODE
hi alexeym, finally i found the file (make/options). it looks like this:
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -lcompressibleLESModels -lcompressibleTurbulenceModel -lcompressibleTurbulenceModel -lcompressibleTurbulenceModel \
    -lspecie \
    -lsolidProperties \
    -lSLGThermo \
    -lchemistryModel \
"options" 55L, 2308C
What do you think?.
Old   January 7, 2015, 02:10
Alexey Matveichev
Obviously your EXE_LIBS line is shorter than mine. Backup your file, copy-paste mine, try to compile.
But again, you don't need fireFoam to compile LIGGGHTS. Maybe it's better to try to compile that solver instead fireFoam.
Old   January 7, 2015, 06:07
Julian Ruiz
Hi alexeym!
fireFoam doesn't matter. I'm worry about compressible solvers
i't shouldn't be this:
My EXE_LIBS
i'll change that part, copy and paste your EXE_LIBS for:
then run wmake
will it make the difference?
Old   January 7, 2015, 07:37
Alexey Matveichev
You've got several -lcompressibleTurbulenceModel in your options cause you've run sed command several times.
I've noticed that options content you posted is truncated. Post whole file, please.
Answering your question: no it will not make any difference.
Also, a) as you can see, all compressible solvers were built without any problems, b) LIGGGHTS uses incompressible turbulence models (as far as I can see by the options file in their git repository).
Old   January 7, 2015, 10:26
Julian Ruiz
Hi alexeym
My file only has this content:
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -lspecie \
    -lsolidProperties \
    -lSLGThermo \
    -lchemistryModel \
Do you think that i'll not have troubles building LIGGGHTS with these errors?
How can i fix this:
is it necessary?
error, mac, mavericks, openfoam 2.2.2, problems
Getting Started with OpenFOAM wyldckat OpenFOAM 25 August 14, 2022 13:55
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 08:51
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
