[OpenFOAM.com] 3.0+ on Windows ---- How do I run tutorials?
Like Tree6Likes
Old   January 17, 2016, 17:39
Default 3.0+ on Windows ---- How do I run tutorials?
Kai
ssboss is on a distinguished road
Hello all
I am a novice OpenFoam user, used it a couple of times running on linux VMs in the past and am familiar with how to navigate around files in linux environment. I recently tried to run the newly released OpenFOAM in Windows by ESI, downloaded from here:
http://www.openfoam.com/releases/install-windows.php
First of all, installation wasn't smooth but thanks to the post by pgh here:
http://www.cfd-online.com/Forums/ope...m-windows.html
I manage to install successfully. Now, my question is, I am confused with the whole workingDir scene in this version of OpenFoam. I understand it is running OF in another virtual machine which explains why I cannot navigate the files in my windows, but I cannot seem to understand how to 'copy tutorial files to workingDir', which is stated from the user guide document. Can someone please help me on getting started with running OF?
Running Windows 7 64bit, plenty of RAM and hard drive space, should not have any issues here, hardware virtualization and the powershell thing is all good, installation successful. Thank you very much.
ssboss is offline   Reply With Quote
Old   January 21, 2016, 05:26
Kai
anyone can help explain the whole structure of workingDir ?
Old   February 3, 2016, 10:42
Default Similar problem with tutorials
Jack_Landis's Avatar
Jack_Landis is on a distinguished road
Hi everyone,
I'm new in using OpenFoam and have a similar problem...How can I find the tutorials?
Thank you!
Jack_Landis is offline   Reply With Quote
Old   March 3, 2016, 05:55
Default openfoam3.0+ installation
kalyan chakravarthi
chakram is on a distinguished road
I have installed openfoam 3+ , but after that i cannot able to see the tutorials in the openfiam. can u please suggest how to get those tutorials and i am basic learner
chakram is offline   Reply With Quote
Old   March 7, 2016, 03:41
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Openfoam installation is in /opt/OpenFOAM
The location of tutorial can be found by running the command
echo $FOAM_TUTORIAL
You need to copy tutorial in workingDir folder .
Go inside the workingDir and then you can use following command to copy tutorial.
cp -ar $FOAM_TUTORIALS .
You can then run openfoam tutorial from terminal
pgh is offline   Reply With Quote
Old   October 19, 2016, 05:31
Joakim
joxen is on a distinguished road
echo $FOAM_TUTORIAL
I use Windows 7 and the release OpenFOAM.v1606. I've manage to copy the file to my workingDir by using $FOAM_TUTORIAL and I can run the tutorials but my question is how to I edit the settings of each case?
I know that the simple answer is "in a texteditor" but the problem is I can't find the files in Windows environment?. Do I need to transfer the files from Linux to Windows to be able to edit the settings?
I've checked the folder where OpenFOAM is installed at C:/ and there are no file of relevance to my problem there. The path in the Linux-environment is: /op/OpenFOAM/OpenFOAMv.1606/tutorials....
but how do I find it in Windows?
I've worked with Linux before but this is the first time I use a Virtual Machine.
joxen is offline   Reply With Quote
Old   October 19, 2016, 06:35
pgh
Pawan Ghildiyal
Hi Joxen
Note that C:\User\joxen (Assuming joxen is your username ) is mounted drive which is same as workingDir from command prompt . Any folder which is there in workingDir , will be visible inside C:\User\joxen ..
Thanks
Pawan
Old   November 5, 2016, 15:22
Francesco Saverio Ciani
ciaci88 is on a distinguished road
I am using windows 10 with the release OpenFOAM.v1606, and maybe I am having the same problem.
I am trying to search the folders of the tutorials but I cannot find it in the c:/ of windows. I have tried to type this commands to see directly from openfoam which is the path:
[ofuser@default ~]$ cd $FOAM_TUTORIALS
[ofuser@default tutorials]$ pwd
/opt/OpenFOAM/OpenFOAM-v1606+/tutorials
My problem is that I cannot find this path in my computer. It is the first time that I am using this program and maybe the explanation is that I don't have to search this folder on windows but on the virtual machine. Anyone has solved the problem? thanks in advance
shreeyansh likes this.
ciaci88 is offline   Reply With Quote
Old   November 6, 2016, 15:17
pgh
Pawan Ghildiyal
Hi
This path "/opt/OpenFOAM/OpenFOAM-v1606+/tutorials" can only be accessed via
command line from shell of container . If you want to locate in your c drive , you need
to copy this in your c drive .
Do following from your container's bash shell
cd workingDir
cp -ar $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity .
It will copy the cavity tutorial inside c\user\francis . assuming francis is your
user name
shreeyansh and bbita like this.
Old   November 6, 2016, 18:11
Default A suggestion...
Hi!
OpenFOAM has been written for Linux. I tried to use it on Windows but I had lots of problems and finally I decided to install it on Ubuntu. So my suggestion is to use it on Ubuntu, it is simplier.
Omnia per ipsum facta sunt,
et sine ipso factum est nihil,
quod factum est
Old   November 10, 2016, 06:37
Derek Neilson
Derek is on a distinguished road
I was nearing the same point. I uninstalled the ESI OpenFoam package and tried the CFD Support OpenFoam package instead. It seems much easier to use, and comes with Midnight Commander which is very helpful. I tried the ESI-Docker-Oracle VM combo for two weeks, and learned ALOT, but it was just too hard to follow along and learn.
Derek is offline   Reply With Quote
Old   July 2, 2017, 07:19
anonymous
mech thermal is on a distinguished road
hello sir , i installed openfoam 1612+ on windows , i am absolute beginner in openfoam when i am trying to copy tutorial by command , openfoam terminal says that cp: cannot stat `TUTORIALS': No such file or directory
also in C:\Program Files (x86)\ESI\OpenFOAM\1612\Windows\Scripts , there is of_v1612plus_centos66.tar file , it has opt/OpenFoam folder but not any folder named tutorials. i reinstall v1612+ .. three times but same problem ...
C:\WINDOWS\system32>"C:\Program Files (x86)\ESI\OpenFOAM\1612\Windows\Scripts\of_start_c ontainer.exe" -Arguments "C:\Program Files\Docker Toolbox\;C:\Program Files\Git\bin"
Starting "default"...
Machine "default" is already running.
of_plus_1612
[ofuser@default ~]$ mkdir -p $FOAM RUN
[ofuser@default ~]$ cp -r $FOAM TUTORIALS $FOAM RUN
[ofuser@default ~]$
mech thermal is offline   Reply With Quote
Old   July 2, 2017, 12:15
anonymous
Hi
cd workingDir
user name
of_plus_1612
[ofuser@default ~]$
Old   July 3, 2017, 07:30
pgh
Pawan Ghildiyal
Follow these steps
cd workingDir
cd cavity
blockMesh
icoFoam
mech thermal likes this.
Old   July 3, 2017, 08:28
LThomes is on a distinguished road
of_plus_1612
[ofuser@default ~]$
I think you missed the underscore in "$FOAM TUTORIALS", you have to type $FOAM_TUTORIALS and create the $FOAM_RUN directory. Linux doesn't deal very well with white spaces, so it's better not to use them.
LThomes is offline   Reply With Quote
Old   July 3, 2017, 10:39
anonymous
Follow these steps
cd workingDir
cd cavity
blockMesh
icoFoam
Thank you Sir.. i do it and it works now...
Old   July 3, 2017, 10:42
anonymous
Thank you .Sir ..
Old   September 6, 2017, 09:58
Lenzo
lenzo is on a distinguished road
I have the same problem!
I have followed the procedure explained in openfoam foundation, for windows. And I had no problem in installing it.
But, I dont' know where it is placed in windows!
I have tried to run an example (pitzDaily). Once it has concluded I run a search throughout the computer. And apparently I have found it!
it is placed in C:users\<myname>\AppData\Local\lxss\home\<myUserIn Linux>\OpenFoam\<user>-4.1\run
Thus, I went there, I found the case, with all the folders of the diferent timesteps. And inside the run I placed another case.
But, If i check it from the bash, when I try to see all cases inside run, there is only pitzDaily...
It is so frustrating! Someone could help me of how to copy cases into my workingDir?
Thank you in advance
lenzo is offline   Reply With Quote
Old   September 6, 2017, 10:28
pgh
Pawan Ghildiyal
Hi
Which operating system are you using i.e Windows7 or Windows 10 and which OpenFOAM version are you installing . ?
Old   September 7, 2017, 02:30
Lenzo
Hi
Windows 10. And OF 4.1. The one of openfoam.org foundation, not openfoam.com
How to run other tutorials included in OpenFOAM? BhaluBear OpenFOAM Running, Solving & CFD 8 May 21, 2016 10:19
How to run the tutorials' problems? ranasa OpenFOAM Running, Solving & CFD 2 July 24, 2014 15:10
How to run su2 on windows and use multicore hedley SU2 1 June 24, 2014 20:44
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Help, can't stop solver run...Windows OS ben akih CFX 2 November 13, 2006 10:05
