[OpenFOAM.com] Cannot connect to X server using docker on OSX |
March 16, 2016, 09:16 |
Federica Gioia
I am trying to install openFoam on Mac OS X 10.10.5 (http://www.openfoam.com/download/install-binary.php) by using Docker-toolbox. I can do without problems all the suggested steps, but then, when I try to run the example included in the installation guide, I cannot open paraFoam, since it returns the following error:
paraview: cannot connect to X server I have also installed XQuartz but it doesn't seem to help much! |
March 21, 2016, 05:48 |
#2 | |
Ruben Di Battista
Rep Power: 13 |
- fabiorehm.com/blog/2014/09/11/running-gui-apps-with-docker/ |
March 29, 2016, 07:45 |
Pawan Ghildiyal
Rep Power: 10 |
I was able to use Quartz to launch paraFoam in Mac but In Mac using XQuartz affect performance of GUI i.e it took long time . It would be better if you install paraview separately and use it . http://www.paraview.org/download/
March 30, 2016, 06:00 |
#4 | |
Ruben Di Battista
Rep Power: 13 |
For better performances there's also: x2go. There is a port also on macports, I don't know on Homebrew. If you can install the server on the Docker it should perform better than X11 forwarding (ssh -X ...) |
May 7, 2016, 22:19 |
#5 | |
LD
Rep Power: 10 |
How does one go about using paraview with docker? How do I locate the file I need to open in paraview since the docker files are not visible in Finder? I can't seem to locate the docker files in Finder. When I open Paraview, what file should I be opening? This answers seems to help: http://stackoverflow.com/questions/3...n-os-x-part-ii But, I am still not sure how to go about getting the cd function to work to get me to the folder. Scenario 1: When I type open -a paraview foam.foam within the docker shell, I still get the error: bash: open: command not found Scenario 2: When I open a new terminal tab and type in the commands from the website, I get this error: "ERROR: In /Users/kitware/buildbot-slave/paraview-bigmac-osx-shared-release_opengl2_osx10_7_qt4_superbuild/build/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 8483 vtkPOpenFOAMReader (0x7ff5ae360a50): /Users/LibinDaniel/foam.foam contains no timestep data. ERROR: In /Users/kitware/buildbot-slave/paraview-bigmac-osx-shared-release_opengl2_osx10_7_qt4_superbuild/build/paraview/src/paraview/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkPVCompositeDataPipeline (0x7ff5ae3679a0): Algorithm vtkPOpenFOAMReader(0x7ff5ae360a50) returned failure for request: vtkInformation (0x7ff5ae369b30) Debug: Off Modified Time: 191113 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1" Last edited by libindaniel2000; May 8, 2016 at 15:03. |
May 9, 2016, 05:02 |
Pawan Ghildiyal
Rep Power: 10 |
Hi..
1.Scenario 1: is not good for you. 2. You need to create foam.foam file inside the testcase that you are runnning . See below explanation Looks OpenFOAM is for running the case i.e meshing and doing simulation . Paraview is for post-processing . You need to run case in via docker terminal box i.e OpenFOAM via docker terminal box only. Lets suppose you copied mkdir -p $FOAM_RUN run cp -r $FOAM_TUTORIALS/incompressible/icoFoam/cavity . cd cavity blockMesh icoFoam This will create a folder with name OpenFOAM in your home directory i.e /Users/daniel (assuming daniel is your username ) . Go inside the folder docker-v3.0+(if you are using latest script that i have provided) and then inside run directory and your cavity folder is in same location. When you launch paraview , you need to browse to this folder and open a.foam (i.e assuming your created a.foam file using command touch a.foam inside the cavity folder.) Note:I added new script which can be found in this link (name of script is installOpenFOAM_MAC_pgh.gz which help in resolving some issue related to file read/write permission in MAC http://www.cfd-online.com/Forums/ope...not-found.html |
May 9, 2016, 17:46 |
#7 | |
LD
Rep Power: 10 |
November 1, 2016, 22:10 |
[OS X Yosemite 10.10.5] [docker]Cannot connect to X server
#8 | |
Siyu Chen
Rep Power: 9 |
Hi pgh,
I am a beginner to OpenFOAM. How to open paraView through docker? For now, I don't find the direct solution. What I did is create a new "test.foam" file in the same folder, and open it using paraView. But is there a way that I can just use "paraFoam" to open the paraView? Thanks. Siyu Quote:
November 2, 2016, 03:47 |
#9 |
Pawan Ghildiyal
Rep Power: 10 |
hi Siyu
Right now , in Mac , we suggest to use paraview . . paraFoam is same as paraview but has some additional capability . Since you are beginner , i think it should not make much difference to you To use paraFoam is mac, right now is a bit complicated and graphics wise experience is not good . Thanks Pawan |
November 2, 2016, 07:25 |
#10 | |
Siyu Chen
Rep Power: 9 |
Thanks Pawan!
October 13, 2021, 04:51 |
ParaView Opening Error Mac ( docker)
#11 |
zink
Rep Power: 10 |
I am using macOS Big Sur v.11.4 and using docker to run openFOAM v1906. However, when I type paraFoam in the bash, the following error appears. OpenFOAM is running fine but I cannot load ParaVEW. I have preview running spepratley file. But I cannot load my case. Any help in this regard will be highly appreciated. QXcbConnection: Could not connect to display host.docker.internal:0. Aborted Regards, |
October 13, 2021, 14:31 |
#12 |
Mark Olesen
Rep Power: 40 |
If you use a newer openfoam-docker starter
specifying the '-X' option should do. https://develop.openfoam.com/packagi...penfoam-docker However you should be using a native (osx) version of paraview and not be using 'paraFoam' with docker |
docker-toolbox, osx, paraview, xquartz |
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker | u2berggeist | OpenFOAM Installation | 1 | July 10, 2018 02:58 |
error: connect failed | destroy | FLUENT | 7 | March 18, 2018 14:59 |
[OpenFOAM.com] v1606+ Install pb with Docker on OSX El Capitan | BPich | OpenFOAM Installation | 3 | October 10, 2016 18:52 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
[General] Mac Os x system can't connect to X server when using ssh to access Linux system | Ivy Zhou | ParaView | 2 | September 30, 2013 10:21 |
