[OpenFOAM.com] starting problem on mac: "xhost: command not found"
Like Tree2Likes
Old   May 6, 2016, 09:51
Evan
k13113y is on a distinguished road
[root@eba8e7f5a175 cavity]# echo $FOAM_RUN
/root/OpenFOAM/ofuser-v3.0+/run
[ofuser@eba8e7f5a175 cavity]$ echo $FOAM_RUN
/home/ofuser/OpenFOAM/ofuser-v3.0+/run
...It worked? I'm sorry for the confusion I literally don't know why its working all of a sudden.
k13113y is offline   Reply With Quote
Old   May 6, 2016, 09:54
Evan
It seems to have happened when I downloaded the new version of virtual box
Old   May 6, 2016, 10:08
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Launch docker terminal box i)delete old container by running following command "docker rm -f of_v3.0_plus"
ii) run this command "docker ps -a " to see there is no container now
iii) unzip the latest script that i have provided and put in /C/Users
and use this command
docker-machine ssh default $HOME/installOpenFOAM_MAC_pgh $HOME
You will be login as docker (There is no ofuser involved in it)
then follow rest of instruction
File Type: gz installOpenFOAM_MAC_pgh.gz (684 Bytes, 17 views)
pgh is offline   Reply With Quote
Old   May 6, 2016, 10:41
Evan
Here's what happened when I followed your last comment.
taylor:~ myusername$ ./startOpenFoam+_MAC
of_v3.0_plus
bash-4.1$ whoami
whoami: cannot find name for user ID 1000
bash-4.1$ mkdir -p $FOAM_RUN
bash-4.1$ run
//so it was able to make the directory
bash-4.1$ export DISPLAY=my.ip
bash-4.1$ export LIBGL_ALWAYS_INDIRECT=y
bash-4.1$ paraFoam
Created temporary 'cavity.OpenFOAM'
paraview: cannot connect to X server my.ip
But it couldn't open the graphical interface like before for some reason
Old   May 6, 2016, 10:49
pgh
Pawan Ghildiyal
I am not using paraFOAM from docker container. I will suggest to download paraview seprately for MAC and then work on it .
http://www.paraview.org/download/
Also did you add display variable as suggested earlier in your command i.e in script (Note just need to add -e DISPLAY=${displayVar} in script . and rerun it after deleting old container
docker run -ti .... -e DISPLAY=${displayVar} --workdir
Old   May 6, 2016, 11:14
Evan
I've now installed paraview and made the change to the script. My script reads:
docker run -it -d --name ${containerName} --user=${user} -e USER=${username} -e DISPLAY=${displayVar} --workdir -e QT_X11_NO_MITSHM=1 -e HOME=/home/docker/Users --workdir="/home/docker/Users" --volume="${home}:/home/docker/Users" -v=/tmp/.X11-unix:/tmp/.X11-unix ${imageName} /bin/bash --rcfile /opt/OpenFOAM/OpenFOAM-v3.0+/etc/bashrc
However now I can't even run the container:
taylor:~ myusername$ ./startOpenFOAM+_MAC
Error response from daemon: No such container: of_v3.0_plus
Error: failed to start containers: of_v3.0_plus
Error: No such container: of_v3.0_plus
Old   May 6, 2016, 11:31
pgh
Pawan Ghildiyal
remove --workDir that is highlightred above
k13113y likes this.
Old   May 6, 2016, 12:01
Evan
Andd we have lift off! Thank you my friend, I am now running programs as user1000 and not as root
Old   May 7, 2016, 14:58
Florida
azaria is on a distinguished road
Dear ugh,
I am back again, I used your latest script but I get the password incorrect. See below:
Merons-MacBook-Pro:~ ban$ ./startOpenFOAM+
of_v3.0_plus
bash-4.1$ su user
su: user user does not exist
bash-4.1$ su ofuser
Password:
su: incorrect password
bash-4.1$
I used the password ofuser2015 and Ofuser2015. Both did not work.
When I used the latest attached script I do not need to change users "Name".
any clue?
thanks,
Azaria
azaria is offline   Reply With Quote
Old   May 7, 2016, 15:39
pgh
Pawan Ghildiyal
Hi Azaria
1)Before launching script, make sure to run command docker rm -f of_v3.0_plus
to make sure you have deleted old container.
2. )please note that with latest script you do not need to login as ofuser..
3) command "echo $USER", will throw user name as docker.. check this please
4) run this command "mkdir -p $FOAM_RUN" and see whether there is permission issue .
5)Login as root ie su root and use password 0fuser2015 ...
Old   May 8, 2016, 11:13
Florida
Dear pgh,
I have run the cavity tutorial successfully. Thank you so much.
Azaria
Old   May 13, 2017, 18:26
bbita is on a distinguished road
Hi Pawan,
I am new to OpenFoam. I installed OPENFOAM for windows-v1612+. I am trying to run the first tutorial. I am in workingDir but when I enter" cp -ar $FOAM_TUTORIALS/incompressible/icoFoam/cavity/cavity ." I receive the error of permission denied. Please advise.
Thanks
bbita is offline   Reply With Quote
Old   May 14, 2017, 22:32
I finally solved the issue. uninstall the whole thing, activate windows module installer, check for updates for windows and reinstall the openFoam and the problem resolved.
pgh likes this.
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 03:05
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
injection problem Mark New FLUENT 0 August 4, 2013 01:30
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
