[foam-extend.org] 3.2 Error: disk quota exceeded and files cannot be found |
May 8, 2016, 15:07 |
Lee
Rep Power: 10 |
Hello all,
I am now trying to install foam-extend-3.2 in Ubuntu 14.04, however, I cannot successfully get it installed. The compressed file 'log.make' is in the attachment. There are a lot errors regarding disk quota exceeded and files cannot be found at the end of the log.make file. It is really strange since my disk does have enough space. Thanks in advance. Best Lee |
May 25, 2016, 06:56 |
chariton christou
Rep Power: 12 |
Hi Lee,
I am experiencing similar problems. Have you resolved this issue? |
May 25, 2016, 11:17 |
Lee
Rep Power: 10 |
Hi Chariton,
I preciously downloaded foam-extend-3.2 to my ''$HOME'' directory, which is actually my network drive accessible from all engineering computers for students (only 10GB), that is why there existed a lot of ''disk quota exceeded'' messages in the log.make file. My measure is that I made a directory out of my ''home'' directory under the root directory and complied foam-extend-3.2 there. In this way, after changing the installation directory in the bashrc file, I successfully installed foam-extend-3.2. Best Regards, Lee |
May 25, 2016, 11:23 |
chariton christou
Rep Power: 12 |
Hi Lee,
I got what you meaning. The problem is not your quota, but the quota of the other users that can actually access the directory. I will try to install it as a root. Thanks again |
Number of files allowed on disk exceeded, not so much in terms of space | adhiraj | OpenFOAM | 1 | September 1, 2013 13:35 |
