December 7, 2020, 20:40 |
Compiling OF in cluster
Federico Zabaleta
Rep Power: 10 |
Hi, I am trying to compile OFv2006 in the PSC Bridges supercomputer. i Follow the instructions provided in the official website (https://develop.openfoam.com/Develop...r/doc/Build.md) but I get the following errors:
When I source the /etc/config.sh/setting I get the following Code:
gcc: error: unrecognized command line option ‘--showme:link’ Code:
wmake mpi gcc: error: unrecognized command line option ‘--showme:compile’ Ctoo: UOPwrite.C In file included from UOPwrite.C:33:0: PstreamGlobals.H:42:17: fatal error: mpi.h: No such file or directory #include <mpi.h> ^ compilation terminated. Thanks a lot of the help. |
December 15, 2020, 04:19 |
#2 | |
Mark Olesen
Rep Power: 40 |
If you are using INTELMPI, you need to specify this. Either in the etc/bashrc (the WM_MPLIB value), or provide the same in a prefs.sh file. The '--showme:compile' bits are used for SYSTEMOPENMPI (the default). If your cluster has it, you might also consider using spack for your installation. |
December 15, 2020, 12:11 |
#3 | |
Federico Zabaleta
Rep Power: 10 |
Compile OpenFOAM libraries ln: OpenFOAM/lnInclude ln: OSspecific/POSIX/lnInclude found <sys/inotify.h> -- enabling inotify for file monitoring. wmake libo (POSIX) wmake dummy (mpi=INTELMPI) wmake dummy wmake mpi (mpi=INTELMPI) wmake mpi Making dependency list for source file PstreamGlobals.C Making dependency list for source file UPstream.C Making dependency list for source file UIPread.C Making dependency list for source file UOPwrite.C g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -isystem /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -Wno-deprecated-declarations -fpermissive -iquote. -IlnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -c UOPwrite.C -o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UOPwrite.o g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -isystem /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -Wno-deprecated-declarations -fpermissive -iquote. -IlnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -c UIPread.C -o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UIPread.o g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -isystem /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -Wno-deprecated-declarations -fpermissive -iquote. -IlnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -c UPstream.C -o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UPstream.o g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -isystem /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -Wno-deprecated-declarations -fpermissive -iquote. -IlnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -c PstreamGlobals.C -o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/PstreamGlobals.o g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -isystem /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -Wno-deprecated-declarations -fpermissive -iquote. -IlnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UOPwrite.o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UIPread.o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UPstream.o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/PstreamGlobals.o -L/home/zabaleta/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32OptINTELMPI/lib \ -L/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib -lmpi -o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/mpi/libPstream.so /bin/ld: cannot find -lmpi collect2: error: ld returned 1 exit status make: *** [/home/zabaleta/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/mpi/libPstream.so] Error 1 Thanks for all the help! |
December 15, 2020, 12:23 |
#4 | |
Mark Olesen
Rep Power: 40 |
After sourcing your updated OpenFOAM etc/bashrc, you should also verify that the directories listed by the $MPI_ARCH_PATH actually contain an include/ and a lib/ or lib64/ directory AND that these also contain the mpi.h, mpi.so etc. They are probably there, but could also be in a parallel path. In the meantime, while you are busy digging, you can kick off an OpenFOAM compilation of everything else. Just change the WM_MPLIB to "dummy" to skip over the mpi bits. You can come back later and change it back to INTELMPI, or whichever mpi flavour you have and rebuild. Since this second pass only rebuilds the MPI bits, it will typically run through in a couple (1-3) of minutes, with most of the time being spent examining all of the things that it does not need to rebuild. Don't give up, you'll soon get there. |
December 15, 2020, 12:57 |
#5 | |
Federico Zabaleta
Rep Power: 10 |
Sorry if this is a silly question, but when you say change WM_MPLIB to "dummy" do you mean: Code:
>export WM_MPLIB=dummy If I do that a just get a similar error Code:
gcc=/usr/lib64/ccache/gcc clang=/usr/lib64/ccache/clang mpirun=/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/bin/mpirun make=/bin/make cmake=/bin/cmake wmake=/home/zabaleta/OpenFOAM/OpenFOAM-v2006/wmake/wmake m4=/bin/m4 flex=/bin/flex compiler=/usr/lib64/ccache/g++ g++ (GCC) 4.8.5 20150623 (Red Hat 4.8.5-36) ======================================== 2020-12-15 12:55:05 -0500 Starting compile OpenFOAM-v2006 Allwmake Gcc system compiler linux64GccDPInt32Opt, with INTELMPI mpi ======================================== built wmake-bin (linux64Gcc) Skip ThirdParty (no directory) ======================================== Compile OpenFOAM libraries ln: OpenFOAM/lnInclude ln: OSspecific/POSIX/lnInclude found <sys/inotify.h> -- enabling inotify for file monitoring. wmake libo (POSIX) wmake dummy (mpi=INTELMPI) wmake dummy wmake mpi (mpi=INTELMPI) wmake mpi g++ -std=c++11 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -isystem /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/include -Wno-old-style-cast -Wno-unused-local-typedefs -Wno-array-bounds -Wno-deprecated-declarations -fpermissive -iquote. -IlnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OpenFOAM/lnInclude -I/home/zabaleta/OpenFOAM/OpenFOAM-v2006/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UOPwrite.o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UIPread.o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/UPstream.o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/build/linux64GccDPInt32OptINTELMPI/src/Pstream/mpi/PstreamGlobals.o -L/home/zabaleta/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32OptINTELMPI/lib \ -L/opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib -lmpi -o /home/zabaleta/OpenFOAM/OpenFOAM-v2006/platforms/linux64GccDPInt32Opt/lib/mpi/libPstream.so /bin/ld: cannot find -lmpi collect2: error: ld returned 1 exit status |
December 15, 2020, 15:33 |
#6 | |
Mark Olesen
Rep Power: 40 |
Nope that's not going to do it (actually you can see that from the wmake with the mpi=INTELMPI information). Lets go for the heavy-handed solution. Edit your etc/bashrc (or etc/prefs.sh) and change WM_MPLIB to have "dummy". Source the OpenFOAM etc/bashrc again. To test that it worked (or not), just try recompiling some mpi bits. For example, src/Pstream/Allwmake Should be ok. BTW: you were almost there with your first approach, but you would have also need the FOAM_MPI variable. The direct approach (edit the file) seems to be safer until you get a better idea of how things work. Cheers, /mark |
December 15, 2020, 15:38 |
Mark Olesen
Rep Power: 40 |
@fedez91 - thinking of your experience, wmake for v2012 will get two additional options:
ENH: add wmake -show-mpi-compile, -show-mpi-link options - useful for diagnosing which MPI paths and flags are being used when setting up for a new MPI configuration. You will still need to figure if things make sense, but at least this way you can easily see what OpenFOAM is looking for when using a particular MPI. |
January 12, 2021, 15:08 |
#8 | |
Federico Zabaleta
Rep Power: 10 |
When I checked the intel mpi installed in the cluster, I cannot find mpi.so. I think it was replaced with something else. In particular, I see the following in the instalation folder Code:
>ls /opt/intel/compilers_and_libraries_2020.4.304/linux/mpi/intel64/lib/ debug libmpicxx.a libmpicxx.so.12 libmpicxx.so.12.0.0 libmpifort.so libmpifort.so.12.0 libmpijava.so libmpijava.so.1.0 mpi.jar release_mt debug_mt libmpicxx.so libmpicxx.so.12.0 libmpifort.a libmpifort.so.12 libmpifort.so.12.0.0 libmpijava.so.1 libmpi_shm_heap_proxy.so release So I guess mpi.so was replaced with libmpicxx.so I tried to create a soft link to libmpicxx.so called mpi.so in $WM_PROJECT_DIR/libs and added that to $LD_LIBRARY_PATH hoping that the compiler finds mpi.so there and goes directly to libmpicxx.so but it didn't work. I guess I am close to solving the problem but I don't know how to continue . Any help appreciated! |
January 19, 2021, 12:31 |
#9 |
Federico Zabaleta
Rep Power: 10 |
I was able to compile the code using OpenMPI, but not IntelMPI.
All I had to do was to change WM_MPLIB = SYSTEMOPENMPI and then load OpenMPIfor gcc compilers module using: Code:
>load module mpi/gcc_openmpi Thanks for all the help. Last edited by fedez91; January 19, 2021 at 18:57. |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
Compiling on RHEL6 cluster: cannot find mixtureKEpsilon.H | pbachant | OpenFOAM Installation | 2 | September 3, 2014 18:06 |
Error while compiling OpenFOAM on Redhat cluster | feiqunali | OpenFOAM Installation | 3 | October 13, 2013 03:30 |
Compiling on ROCKS Cluster 5.4.3 | ciberbob1987 | OpenFOAM Installation | 8 | February 25, 2012 19:21 |
Compiling UDF on a cluster | Adya | FLUENT | 1 | December 14, 2009 11:30 |
