[OpenFOAM.org] error while using wmake - undefined reference to .. GLIBCXX_3.4.21
Old   June 28, 2023, 10:18
Default error while using wmake - undefined reference to .. GLIBCXX_3.4.21
Dmitry
complete.basis is on a distinguished road
Hello, everyone!
I am a newbie experiencing problems while installing a custom solver reactingCanteraFoam on a system (CentOS Linux release 7.6.1810 (Core) , IntelOne API 2021.4.0, OpenFOAM.org v7). I would be thankful for any help!
What i've done:
1) I downloaded solver from https://github.com/ZhangYanTJU/reactingCanteraFoam
This solver solver calls Cantera to update T psi mu alpha D in OpenFOAM
2) I installed libcantera in a dedicated environment as it is stated on cantera.org. (I installed version 2.5.1 because it is written that this solver has been tested with this version):
conda create --name ct-dev
conda install--channel cantera/label/dev libcantera-devel=2.5.1
conda activate ct-dev
conda install make cmake scons pkg-config
3) Changed Make/options:
-I/home4/pstorage2/mian1/.conda/envs/ct-dev/include
/home4/pstorage2/mian1/.conda/envs/ct-dev/lib/libcantera_shared.so
4) run wmake:
I've got a lot of errors like this:
/home4/pstorage2/mian1/.conda/envs/ct-dev/lib/libcantera_shared.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::rfind(char, unsigned long) const GLIBCXX_3.4.21'
see full log in attach.
It seems to me, that wmake is looking at wrong compiler settings or smth like this. Any suggestions how to fix it?
Thanks in advance,
Dmitry
complete.basis is offline   Reply With Quote
centos 7, glibcxx_3.4.21, wmake
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) toolpost OpenFOAM Installation 15 September 21, 2012 09:38
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
Installing OpenFOAM-1.5-dev on a cluster ZKM OpenFOAM Installation 4 December 25, 2010 15:59
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
