GIT Compile of 15x on OpenSUSE 11 problems
Old   January 30, 2009, 11:09
Default Hi, I'm really new to Linux
Chris Davies
chrisd is on a distinguished road
I'm really new to Linux and I have been trying to compile the GIT version (on OpenSUSE v11.0 x64)
I have installed the binary version to check it all works – The tutorial and paraView run fine
I then download the GIT version using the command:
git clone git://repo.or.cz/OpenFOAM-1.5.x.git
Then place the OpenFOAM-1.5.x directory into my /home/chris/OpenFOAM directory
Change the entry in $HOME/.bashrc
From
. $HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
To
. $HOME/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc
Update the update the environment variables using:
. $HOME/.bashrc
At this point there is no error and the shell prompt appears (although it does not create a chris-1.5.x directory like it does for the binary install – I'm not sure if it is supposed to)
After a machine restart – upon opening the terminal I get the following errors before the prompt.
bash: /home/chris/OpenFOAM/OpenFOAM-dev/bin/foamCleanPath: No such file or directory
bash: /home/chris/OpenFOAM/OpenFOAM-dev/etc/settings.sh: No such file or directory
bash: /home/chris/OpenFOAM/OpenFOAM-dev/etc/aliases.sh: No such file or directory
bash: /home/chris/OpenFOAM/OpenFOAM-dev/etc/apps/paraview3/bashrc: No such file or directory
bash: /home/chris/OpenFOAM/OpenFOAM-dev/etc/apps/cint/bashrc: No such file or directory
I have tried running the ./Allwmake script (which compiles ok) before restarting – but it still gives the same terminal error after a restart and non of the OpenFOAM commands work
Thanks in advance for any help
chrisd is offline   Reply With Quote
Old   January 30, 2009, 11:37
Default In the etc/bashrc file, remove
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
In the etc/bashrc file, remove the '#' comment character so the line reads:
export WM_PROJECT_VERSION=1.5.x
Alternatively, export this before sourcing the file.
Maybe you should submit a bug report.
olesen is offline   Reply With Quote
Old   January 30, 2009, 12:25
Default Yep, thanks a lot I uncomme
Chris Davies
Yep, thanks a lot
I uncommented it and updated the variables and that seems to have solved the problem.
Compile problems on ubuntu 810 with gcc432 deepblue17 OpenFOAM Bugs 10 March 2, 2009 07:32
Star-CCM+ running in openSUSE Thiago Siemens 6 January 20, 2009 09:23
Problems while compiling OpenFOAM15 with OpenSuse 103 coompressor OpenFOAM Installation 3 November 7, 2008 00:57
Fluent does not work on openSUSE 11.0 Stanislav Sviderek FLUENT 1 July 28, 2008 17:21
OpenSuSE maybe OT alberto OpenFOAM 13 December 13, 2006 07:54
