Wmake problem
Like Tree1Likes
  • 1 Post By mbeaudoin
Old   March 16, 2005, 21:55
Default Hello I have problem about
Chalothon Thumthae
thumthae is on a distinguished road
Hello
I have problem about "wmake" ,
at folder --> /OpenFOAM/OpenFOAM-1.1/applications/solvers/incompressiblee/turbFoam
I type > wmake
and it not pass, it show
/home/nonyon/OpenFOAM/OpenFOAM-1.1/applications/wmake/wmake: line 140: make: command not found
/home/nonyon/OpenFOAM/OpenFOAM-1.1/applications/wmake/wmake: cannot make, file Make/linuxOpt/objectFiles was not created successfully
after that I test open shell scrib wmake, the command at the line 140 is .....
make -f $WM_DIR/MakefileFiles allFiles
what happen to wmake and/or make command?
please help me to correct this problem
Torn
thumthae is offline   Reply With Quote
Old   March 17, 2005, 03:16
Default It says that make is not insta
Hrvoje Jasak
It says that make is not installed on your system or not visible in your path.
Try typing:
which make
and if not found, you will need to have it installed at your system. You can get a free version from Gnu and compile it yourself.
http://www.gnu.org/software/make/
Enjoy,
Hrv
Hrvoje Jasak
Old   April 19, 2007, 13:21
Default Not directly related to the cu
Mattijs Janssens
mattijs is on a distinguished road
Not directly related to the current thread but I've put a few tips about wmake on the Wiki
at http://openfoamwiki.net/index.php?title=Wmake&rcid=2824
mattijs is offline   Reply With Quote
Old   August 7, 2007, 07:32
Default Hi everybody When i want to
Marhamat Zeinali
marhamat is on a distinguished road
Hi everybody
When i want to update the solvers by using ./Allwmake i recieve the below messages(i.e):
SOURCE_DIR=.
SOURCE=simpleFoam.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels -I/root/OpenFOAM/OpenFOAM-1.3/src/transportModels -I/root/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/simpleFoam.o
/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/zeroGradientFvPatchField. C:141: error: expected constructor, destructor, or type conversion before 'is'
/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/zeroGradientFvPatchField. C:141: error: 'you' does not name a type
/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/zeroGradientFvPatchField. C:143: error: 'either' does not name a type
/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/zeroGradientFvPatchField. C:147: error: 'without' does not name a type
make: *** [Make/linuxGcc4DPOpt/simpleFoam.o] Error 1
+ wmake turbFoam
make: Nothing to be done for `allFiles'.
make: `Make/linuxGcc4DPOpt/dependencies' is up to date.
SOURCE_DIR=.
SOURCE=turbFoam.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels -I/root/OpenFOAM/OpenFOAM-1.3/src/transportModels -I/root/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/turbFoam.o
make: *** [Make/linuxGcc4DPOpt/turbFoam.o] Error 1
+ wmake boundaryFoam
SOURCE_DIR=.
SOURCE=boundaryFoam.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/root/OpenFOAM/OpenFOAM-1.3/src/turbulenceModels -I/root/OpenFOAM/OpenFOAM-1.3/src/
Best regards
Marhamat
marhamat is offline   Reply With Quote
Old   August 7, 2007, 07:41
Default You've got garbage in file /ro
Hrvoje Jasak
You've got garbage in file /root/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude/zeroGradientFvPatchField. C on line 141. get rid of it.
BTW, why are you running as root?
Hrv
Hrvoje Jasak
Old   August 7, 2007, 08:57
Default Thanks alot Ok,i will change
Marhamat Zeinali
Thanks alot
Ok,i will change it .
Best Regards
Marhamat
Old   September 19, 2007, 11:19
Default Hi everybody~ I have some pr
Hyunchang Lee
hyunchang is on a distinguished road
Hi everybody~
I have some problem in wmake.
whenever I run it in every source code,
an error like below happen.
lee@pcblue:~/OpenFOAM/lee-1.4.1/applications/parabolicVelocity> wmake
SOURCE=parabolicVelocityFvPatchVectorField.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/parabolicVelocityFvPatchVectorField.o
In file included from /nfs/home/lee/OpenFOAM/linux/gcc-4.2.1/bin/../lib/gcc/i686-pc-linux-gnu/4.2.1/.. /../../../include/c++/4.2.1/i686-pc-linux-gnu/bits/c++config.h:41,
from /nfs/home/lee/OpenFOAM/linux/gcc-4.2.1/bin/../lib/gcc/i686-pc-linux-gnu/4.2.1/.. /../../../include/c++/4.2.1/string:45,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/string.H:47,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/word.H:43,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/patchIdentifier.H:3 8,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/polyPatch.H:50,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvPatch.H:39,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvPatchField.H: 45,
from /nfs/home/lee/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/fvPatchFields.H :30,
from parabolicVelocityFvPatchVectorField.H:44,
from parabolicVelocityFvPatchVectorField.C:27:
/nfs/home/lee/OpenFOAM/linux/gcc-4.2.1/bin/../lib/gcc/i686-pc-linux-gnu/4.2.1/.. /../../../include/c++/4.2.1/i686-pc-linux-gnu/bits/os_defines.h:44:22: error: features.h: No such file or directory
The error message is much more long and they look all similar to me.
so, I'll appreciate any hint from you.
thank you in advance.
Hyunchang
hyunchang is offline   Reply With Quote
Old   September 19, 2007, 12:12
Default Hello, Your workstation is
Martin Beaudoin
mbeaudoin will become famous soon enough
Your workstation is missing a few RPMs for software development.
On my Centos 4.4 systems, the file features.h is located in /usr/include.
This file was provided by a RPM called glibc-headers-2.3.4-2.25.
If you are using SuSE or some other Unix flavor, the name of the RPM might vary a bit, but do you get the point.
So verify your workstation installation first in order to get a valid software development platform.
Martin
mbeaudoin is offline   Reply With Quote
Old   September 20, 2007, 04:25
Default Thank you, Martin. I'll try
Hyunchang Lee
Thank you, Martin.
I'll try to verify my workstation.
Hyunchang
Old   September 20, 2007, 05:57
Default Martin, It works now. many tha
Hyunchang Lee
Martin, It works now. many thanks~
I'm using SUSE 10.2 and search the RPM glibc in SUSE homepage and installed 2 RPMs.
Hyunchang
Old   December 2, 2008, 01:03
Default Hello! I have a similar pro
  #11
Daniel Langmayr
xdanielx is on a distinguished road
Hello!
I have a similar problem like Chalothon:
at folder -->
"/home/dani/OpenFOAM/OpenFOAM-1.5/tutorials/MRFSimpleFoam/MRFSimpleFoam"
I write wmake and get the following error message:
"/home/dani/OpenFOAM/OpenFOAM-1.5/wmake/wmake: line 202: make: command not found"
However, when i use "which wmake" it finds the file in
"/home/dani/OpenFOAM/OpenFOAM-1.5/wmake/wmake"
I have no idea how to proceed. Any help is appreciated.
Thanks in advance,
Daniel
xdanielx is offline   Reply With Quote
Old   December 2, 2008, 16:11
Default Hello Daniel, Make sure you
  #12
Martin Beaudoin
Hello Daniel,
Make sure you have the "make" RPM package installed on your system.
Martin
andrejssab likes this.
Old   December 3, 2008, 09:30
Default Hello Martin, Thank you ve
  #13
Daniel Langmayr
Hello Martin,
Thank you very much...that helped;)
All the best, daniel
Wmake ccm26ToFoam compilation problem under Ubuntu x64 810 kprzysowagmailcom OpenFOAM Installation 7 November 6, 2009 04:33
Wmake problem interFoam solver feijooos OpenFOAM Running, Solving & CFD 4 December 8, 2008 11:01
Problem about wmake turbFoam williamscn OpenFOAM Running, Solving & CFD 3 September 19, 2007 11:55
Minor wmake problem for x86_64 when compiling everything using existing gcc WM_COMPILER%3dbb hoogland OpenFOAM Installation 0 August 13, 2007 08:58
Wmake clock skew detectedis this causing a problem york OpenFOAM Running, Solving & CFD 2 July 10, 2007 23:43
