September 22, 2008, 04:28 |
I'm installed open foam on Ubu
Francesco Tonolli
I'm installed open foam on Ubuntu 8.04, but when i try to star parafoam, I obtain this message of error:
paraview: error while loading shared libraries: libQtAssistantClient.so.4: cannot open shared object file: No such file or directory thanks for all yours aid. Francesco |
September 22, 2008, 05:18 |
Hi
You need to install qt4.
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
You need to install qt4.3.5, which you can get by searching in Synaptic Package Manager. When it is install please follow the README to compile Parafoam /Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
September 22, 2008, 05:55 |
Thanks Niel,
but i'm not an a
Francesco Tonolli
Thanks Niel,
but i'm not an abitual user in Linux, can you tell me where and what exactly i must download (the file name) Thanks again Francesco |
September 22, 2008, 07:08 |
libqt4-dev
Rep Power: 37 |
libqt4-dev
September 23, 2008, 10:38 |
I've installed libqt4-dev 4.3.
Francesco Tonolli
I've installed libqt4-dev 4.3.4, the only avaible for ubuntu 8.04
When I try to compile paraview obtain: francy@francy-desktop:~/OpenFOAM$ cd ThirdParty/ francy@francy-desktop:~/OpenFOAM/ThirdParty$ rm -rf ParaView3.3-cvs/platforms/ francy@francy-desktop:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -- Check for working C compiler: /home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- Check for working C compiler: /home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- broken CMake Error: The C compiler "/home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc" is not able to compile a simple test program. It fails with the following output: /usr/bin/make -f CMakeFiles/cmTryCompileExec.dir/build.make CMakeFiles/cmTryCompileExec.dir/build make[1]: Entering directory `/home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp' /home/francy/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux/bin/cmake -E cmake_progress_report /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec.dir/testCCompiler.o /home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -o CMakeFiles/cmTryCompileExec.dir/testCCompiler.o -c /home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/C MakeTmp/testCCompiler.c /home/francy/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i6 86-pc-linux-gnu/4.3.1/cc1: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory make[1]: *** [CMakeFiles/cmTryCompileExec.dir/testCCompiler.o] Error 1 make[1]: Leaving directory `/home/francy/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/CMakeFiles/ CMakeTmp' make: *** [cmTryCompileExec/fast] Error 2 CMake will not be able to correctly generate this project. -- Configuring done make: *** No targets specified and no makefile found. Stop. done What i've to do?? Thanks at all Francesco |
September 23, 2008, 13:25 |
Do the same, as with qt. Go to
Rep Power: 37 |
Do the same, as with qt. Go to Synaptic Package Manager and search for mpfr.
Get libmpfr-dev and the manager will suggest the additional needed packages. From there on, you should be set to go. / Niels
May 8, 2009, 06:57 |
Julian Krick
Thanks ngi,
I had the same problem as francy, followed your instructions and the compiling of paraview3.3 works. It's still running, so I do not know if the compiling of PV3FoamReader will work...
grid generation: ICEM CFD 13.0 solver: CFX 13.0 |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 20:16 |
Ubuntu Vs Fedora | Vinayender | Main CFD Forum | 1 | August 11, 2008 12:55 |
Fluent & Ubuntu 7.1 | Charles | FLUENT | 6 | April 1, 2008 00:13 |
Ubuntu 7.10 and Fluent | Gibbon | FLUENT | 1 | November 13, 2007 02:08 |
Fluent 6.3 on Ubuntu 7.04 | adas | FLUENT | 1 | March 20, 2007 19:31 |
