Ld problems with openfoam
Old   May 1, 2008, 12:23
Default Hello I am trying to compil
srinath
srinath is on a distinguished road
Hello
I am trying to compile openfoam on ubuntu-fiesty fawn.
I am using gcc-4.1, and have followed the instructions on the openfam website and README exactly. But i get these strange ld errors.
I would appreciate it if someone could help me with this.
Regards
Srinath
Errors are below
`.L1705' referenced in section `.rodata' of globalMeshData.o: defined in discarded section `.gnu.linkonce.t._ZN4Foam4ListINS_5tokenEEC2ERKS2_ ' of globalMeshData.o
collect2: ld returned 1 exit status
make: *** [/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so] Error 1
.L945' referenced in section `.rodata' of surfaceFeatures.o: defined in discarded section `.gnu.linkonce.t._ZN4Foam4ListINS_5tokenEEC2ERKS2_ ' of surfaceFeatures.o
`.L954' referenced in section `.rodata' of surfaceFeatures.o: defined in discarded section `.gnu.linkonce.t._ZN4Foam4ListINS_5tokenEEC2ERKS2_ ' of surfaceFeatures.o
`.L955' referenced in section `.rodata' of surfaceFeatures.o: defined in discarded section `.gnu.linkonce.t._ZN4Foam4ListINS_5tokenEEC2ERKS2_ ' of surfaceFeatures.o
`.L956' referenced in section `.rodata' of surfaceFeatures.o: defined in discarded section `.gnu.linkonce.t._ZN4Foam4ListINS_5tokenEEC2ERKS2_ ' of surfaceFeatures.o
make: *** [/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libmeshTools.so] Error 1
+ wmake libso finiteVolume
/usr/bin/ld: cannot find -lmeshTools
make: *** [/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so] Error 1
+ cd MGridGenGamgAgglomeration
+ ./Allwmake
`/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libIMlib.so' is up to date.
`/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libMGridGen.so' is up to date.
`/home/srinath/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libMGridGenGAMGAgglomer ation.so' is up to date.
+ wmake libso sampling
/usr/bin/ld: cannot find -lfiniteVolume
srinath is offline   Reply With Quote
Old   May 2, 2008, 07:49
Default Hi Srinath, A short questio
Philippose Rajan
philippose will become famous soon enough
Hi Srinath,
A short question.... which version of GNU GCC are you using for compiling OpenFOAM?
If you are using GCC-4.2.2 as asked for in the OpenFOAM "buildinstructions.txt", are you sure you sourced the .bashrc file after you made the required changes to it ?
Personally, thats one of the most common things that hit me.... forgetting to source the latest .bashrc.
I have resorted to always closing the console and opening a new one (so that the .bashrc gets sourced, and all the changes are activated), before finally starting the actual OpenFOAM compilation with the "./Allwmake" script.
Probably you could check with a "gcc --version" on the console to make sure you are actually using the version of gcc you think you are using.
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Problems with installation of OpenFoam sheyer OpenFOAM Installation 8 July 28, 2008 03:45
[General] OpenFoam - problems MateuszZb ParaView 8 July 21, 2008 16:16
Confused by Problems when reinstalling OPenFoam 13 jin_xu OpenFOAM Installation 2 June 2, 2008 20:53
OpenFOAM 141 gccicoFoamnsd problems sippycup OpenFOAM Installation 1 August 29, 2007 08:59
Problems in Compiling OpenFOAM in IRIX lakeat OpenFOAM Installation 0 June 7, 2007 21:44
