Cannot find lOpenFOAM
Old   June 6, 2006, 15:19
Default Hello, I am trying to buid
Daniel Tourde - Caelae.se
danieltourde is on a distinguished road
I am trying to buid OpenFOAM 1.3 from source on a stock Gentoo Linux box (gcc 4.1.1, glibc 2.4, X11R7). I just follow blindly and stupdly the installation procedure provided with the source code and I get the following errors (a few time before it stops to build):
SOURCE_DIR=.
SOURCE=foamInfoExec.C ; g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter
-Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30
-I/home/ted/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I.
-fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/foamInfoExec.o
/home/ted/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir
/home/ted/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/foamInfoExec
g++ -m32 -Dlinux -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3
-fPIC -pthread Make/linuxGcc4DPOpt/foamInfoExec.o
-L/home/ted/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt \
-lOpenFOAM -liberty -o
/usr/lib/gcc/i686-pc-linux-gnu/4.1.0/../../../../i686-pc-linux-gnu/bin/ld:
cannot find -lOpenFOAM
collect2: ld returned 1 exit status
make: ***
[/home/ted/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/foamInfoExec]
Error 1
Any idea? Help...
Daniel
danieltourde is offline   Reply With Quote
Old   June 7, 2006, 03:38
Default > cannot find -lOpenFOAM s
Mattijs Janssens
seems something has gone wrong earlier when building the OpenFOAM library. Good luck.
Old   June 19, 2006, 08:07
Default Hi there, I have waited a whi
theof
Hi there,
I have waited a while before posting this but now I am really blocked. I have just recompile OF-1.3 on linux suse 10, gcc-4.0.2. All the libraries compiled fine, libOpenFOAM included. When I want to compile the libPVFoamReader, it first compiles the libvtkFoam then I get the previous "cannot find -lOpenFOAM". I am trying to link with paraview-2.5 compiled with cmake-2.4.2. Any suggestion?
Theophane
Old   June 20, 2006, 04:57
Default All is explained on the wiki p
theof
All is explained on the wiki page. Thanks for having documented it!
Old   June 8, 2007, 08:15
Default exactly in which part ?
O R
arkangel is on a distinguished road
arkangel is offline   Reply With Quote
Old   March 28, 2008, 03:56
Default Hi, I tried to compile a dev v
John Deas
johndeas is on a distinguished road
Hi, I tried to compile a dev version of OpenFOAM (from svn), on a RHEL 5, using the compiler provided with the latest stable version of OpenFOAM. However, I get this linking error :
g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/kivaToFoam.o -L/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/lib/linuxGccDPOpt \
-lOpenFOAM -ldl -lm -o /home/flurec/temp/dev/OpenFOAM-1.4.1-dev/applications/bin/linuxGccDPOpt/kivaToFo am
/usr/bin/ld: cannot find -lOpenFOAM
make[3]: *** [/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/applications/bin/linuxGccDPOpt/kivaToF oam] Error 1
make[3]: Leaving directory `/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/applications/utilities/mesh/conversion /kivaToFoam'
make[2]: *** [kivaToFoam] Error 2
make[2]: Target `application' not remade because of errors.
make[2]: Leaving directory `/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/applications/utilities/mesh/conversion '
make[1]: *** [conversion] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/applications/utilities/mesh'
make: *** [mesh] Error 2
make: Target `application' not remade because of errors.
Is there something that need to be fixed in a path ?
johndeas is offline   Reply With Quote
Old   March 28, 2008, 04:10
Default May I add that, if I am in the
John Deas
May I add that, if I am in the src directory, and type wmake libso OpenFOAM, it reports an up to date libOpenFOAM.so
Old   March 28, 2008, 04:13
Default go to ../OpenFOAM-1.4.1/src
O R
and issue this command
%wmake libso OpenFOAM
It will tell you more information why OpenFoam cannot be built
Old   March 28, 2008, 04:20
Default this file exist /home/flur
O R
this file exist
/home/flurec/temp/dev/OpenFOAM-1.4.1-dev/lib/linuxGccDPOpt/libOpenFOAM.so
Old   March 28, 2008, 05:37
Default Yes, it exists. I am checking
John Deas
Yes, it exists. I am checking all the paths in the various bashrc to understand why it is not taking into account.
I am also updatding my gcc to the one distributed with at http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/release/ and thus I would like to clean all the executable. Is it possible to run something like wclean globally, or do I have to automate something to launch wclean in every directory where wmake is called ?
Old   March 28, 2008, 05:55
Default wcleanAll ...
  #11
John Deas
wcleanAll ...
Old   March 28, 2008, 09:09
Default After changing the gcc version
  #12
John Deas
After changing the gcc version, I wanted to clean/rebuild my installation with :
foam
wcleanAll
src
rm -rf */platforms
foam
Allwmake
However some librairies are not build. If I try wmake libso triSurface, I get
readSTLASCII.C:234:23: error: FlexLexer.h: no such file or directory
and various errors like
readSTLASCII.C:5079: error: â does not name a type
Old   March 31, 2008, 05:06
Default I installed flex and zlib (to
  #13
John Deas
I installed flex and zlib (to get zlib.h) from repositories even if I understood that they were built in the Allwmake process. If I type which flex, I get /usr/bin/flex, whereas I think I should have got something inside OpenFOAM path, had everything been setup properly. There were no warnings for the one-two hour compilation time before I left for weekend.
However, to my horror when I came back today, I saw I still have compilation errors. I found in the last compilation directives before it stopped compiling warnings like this one:
"readKivaGrid.H:232: warning: deprecated conversion from string constant to â"
and, readKivaGrid.H contains:
char* kivaPatchNames[nBCs] =
"piston",
"valve",
"liner",
"cylinderHead",
"axis",
"wedge",
"inflow",
"outflow",
"presin",
"presout",
"symmetryPlane",
"cyclic"
whith }; being at line 232
however, there were no errors, but warnings. The error message was:
make[3]: Leaving directory `/home/flurec/temp/OpenFOAM/OpenFOAM-1.4.1-dev/applications/utilities/mesh/conve rsion/kivaToFoam'
make[2]: Leaving directory `/home/flurec/temp/OpenFOAM/OpenFOAM-1.4.1-dev/applications/utilities/mesh/conve rsion'
Also, if I type wmake libso kivaToFoam, I get
"libNULL.so is up to date"
My hypothesis is that the flex version from my repository is not uptodate (package 2.5.4a-41.fc6), but still, I do not understand why the one supplied with openFOAM in not the one used (and why I had to install zlib-devel to get zlib.h which is supplied in OF by the way). The latter has been built, I can found a flex executable in : applications/utilities/miscellaneous/foamFlex
I am really motivated to get OF built from development version, however I am limited in my understanding of what is currently going on.
Old   March 31, 2008, 05:29
Default update: I should not have writ
  #14
John Deas
update: I should not have written wmake libso reaKiva, if I go the kivaToFoam directory and type wmake, I get :
FOAM_APPBIN/kivaToFoam is up to date.
also, if I type which foamFlex++, I get one which is inside FOAM_APPBIN
Old   March 31, 2008, 07:00
Default It is written in the Install-I
  #15
jas
Joerg Schenkel
jas is on a distinguished road
It is written in the Install-Instruction that
you have to install the OPENFOAM direct into the HOME.
So if I´m right
should look like
/home/OpenFOAM-1.4.1-dev/lib/linuxGccDPOpt/libOpenFOAM.so
jas is offline   Reply With Quote
Old   March 31, 2008, 08:30
Default I modified two variables to ta
  #16
John Deas
I modified two variables to take into account that I did not install in the home:
export WM_PROJECT_INST_DIR=/home/flurec/temp/$WM_PROJECT
export WM_PROJECT_USER_DIR=/home/flurec/temp/$LOGNAME-$WM_PROJECT_VERSION
Using similar settings, the stable binary version of OpenFOAM worked (and I was able to compile my owm solvers). But maybe I should ajust other variables to compile the core of OpenFOAM librairies ?
find the example about VOF tjuwsz FLUENT 0 May 10, 2006 04:45
where i can find? khalil khanagarayah Main CFD Forum 0 March 4, 2003 11:03
where i can find atique-ur-rehman Main CFD Forum 2 March 2, 2003 10:40
where i can find? S. Sulaksana Main CFD Forum 0 January 18, 2003 04:01
where i can find? sulaksana Main CFD Forum 0 September 13, 2002 05:22
