DynamicMesh not buils using icc 100 in sgi altix 4000
Old   October 24, 2007, 09:40
Default Hi Foamers I am trying to
O R
arkangel is on a distinguished road
Hi Foamers
I am trying to build OpenFOAM for our sgi-altix 4000 using the icc 10.0 compiler and the sgi - mpi libraries
I modified the rules to point to our libraries and compilers , well all seem to be OK . until I reach the part to build the dynamicMesh lib.so, from there all other libraries that depend on it cannot be build (the compilation of other libraries seems to continue without problems though)
the error I get is :
/home/cluster/a2815ag/opt/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/FieldFi eldFunctions.C(832): error: no instance of overloaded function "Foam::outer" matches the argument list
argument types are: (Foam::pointPatchField<foam::vector>, const Foam::pointPatchField<foam::scalar>, const Foam::pointPatchField<foam::vector>)
PRODUCT_OPERATOR(outerProduct, *, outer)
detected during:
instantiation of "void Foam::outer(Foam::FieldField<field,>::type> &, const Foam::FieldField<field,> &, const Foam::FieldField<field,> &) [with Field=Foam::pointPatchField, Type1=Foam::scalar={Foam::doubleScalar={double}}, Type2=Foam::vector]" at line 952 of "/home/cluster/a2815ag/opt/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Geomet ricFieldFunctions.C"
instantiation of "void Foam::outer(Foam::GeometricField<foam::outerproduc t<type1,>::type, PatchField, GeoMesh> &, const Foam::GeometricField<typer,> &, const Foam::GeometricField<type1,> &) [with Type1=Foam::scalar={Foam::doubleScalar={double}}, Type2=Foam::vector, PatchField=Foam::pointPatchField, GeoMesh=Foam::pointMesh]" at line 952 of "/home/cluster/a2815ag/opt/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Geomet ricFieldFunctions.C"
instantiation of "Foam::tmp<foam::geometricfield<foam::outerproduct <type1,>::type, PatchField, GeoMesh>> Foam::operator*(const Foam::GeometricField<typer,> &, const Foam::GeometricField<type1,> &) [with Type1=Foam::scalar={Foam::doubleScalar={double}}, Type2=Foam::vector, PatchField=Foam::pointPatchField, GeoMesh=Foam::pointMesh]" at line 815 of "motionSmoother/motionSmoother.C"
compilation aborted for motionSmoother/motionSmoother.C (code 2)
make: *** [Make/linuxIA64IA64DPOpt/motionSmoother.o] Error 2
Any idea waht can be wrong ? or as long as i dont use nothing related with dynamic meshing Can I continue using OF for building standard solvers ?
Thanks
arkangel is offline   Reply With Quote
OF on Altix Itanium2 machine skabilan OpenFOAM Installation 0 December 14, 2007 04:04
Some one help!!! Write Cp location for dynamicmesh Endee FLUENT 0 July 11, 2007 05:42
MotionUy and DynamicMesh with OF14 bfa OpenFOAM Running, Solving & CFD 2 July 10, 2007 06:52
Installation on an SGI Altix eviled OpenFOAM Installation 0 March 31, 2007 04:34
Compilation on SGI Altix using intel compiler markusuhlmann OpenFOAM Installation 5 July 19, 2006 03:49
