FoamX libssl problem on redhat enterprise
Old   June 21, 2007, 05:06
Default Hi, I installed OF 1.4 withou
Fabian Braennstroem
braennstroem is on a distinguished road
I installed OF 1.4 without admin rights on a redhat enterprise systems which worked fine, except running FoamX:
nsd: error while loading shared libraries: libssl.so.0.9.7: cannot open shared object file: No such file or directory
OpenSSL is installed and there exists 'libssl.so.0.9.7a', which is hopefully the same!? Is there a way to set any environment to the existing one? Would be nice, if anybody has an idea...
Regards!
Fabian
braennstroem is offline   Reply With Quote
Old   June 21, 2007, 05:33
Default The same issue is present on F
Alberto Passalacqua
The same issue is present on Fedora. On OpenSUSE 10.2 there're libssl.so.0.9.8 and libssl3.so and FoamX works OK. The first library should be the one used by FoamX.
The lib is in /usr/lib
Where does Red Hat places it? Try creating a symbolic link named libssl.so.0.9.7 to libssl.so.0.9.7a in /usr/lib.
With kind regards,
Alberto
Alberto Passalacqua
Old   June 21, 2007, 06:35
Default Hi Alberto, thanks for your
Fabian Braennstroem
Hi Alberto,
thanks for your help. The file is located in /lib, but I have no admin rights to create a symbolic link. Does there exist a different approach?
Regards!
Fabian
Old   June 21, 2007, 06:52
Default I'm not sure if it works, but
Alberto Passalacqua
I'm not sure if it works, but try to create a symbolic link to the library in the same directory where FoamX is. It should search for the library also there.
Regards,
A.
Alberto Passalacqua
Old   June 21, 2007, 07:25
Default No, that does not work. In add
Fabian Braennstroem
No, that does not work. In addition to that I tried to set LD_LIBRARY_PATH to new link directory, but that does not work neiter...
Strange!?
Regards!
Fabian
Old   June 21, 2007, 09:00
Default Hi, the admin had time (str
Fabian Braennstroem
the admin had time (strange!?) and created a link...
Thanks anyways!
Greetings!
Fabian
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
FoamX problem richardhsieh OpenFOAM Installation 4 September 17, 2007 22:41
Installation of OpenFOAM14 on Redhat Enterprise 14 gtg627e OpenFOAM Installation 2 July 23, 2007 10:37
FoamX problem joegi OpenFOAM Installation 8 November 5, 2006 06:06
[OpenFOAM] Has anyone had luck with paraFoam on RedHat Enterprise AMD64 platform sek ParaView 9 August 29, 2006 12:28
