MultiphaseInterFoam damBreak4phaseFine case
Old   April 12, 2007, 17:38
Default Hi, I ran the damBreak4phas
Pei-Ying Hsieh
hsieh is on a distinguished road
I ran the damBreak4phaseFine case in OpenFOAM-1.4 tutorial, ran stopped with an error. Error messages attached.
Pei
oil volume fraction, min, max = 0.1255 0 1
smoothSolver: Solving for alphamercury, Initial residual = 0, Final residual = 0, No Iterations 0
mercury volume fraction, min, max = 0.0423611 0 1
air volume fraction, min, max = 0.749001 0 1
smoothSolver: Solving for alphawater, Initial residual = 0, Final residual = 0, No Iterations 0
water volume fraction, min, max = 0.0831387 0 1
smoothSolver: Solving for alphaoil, Initial residual = 0, Final residual = 0, No Iterations 0
--> FOAM FATAL IO ERROR : expected 'true' or 'false', found on
file: /home/phsieh/OpenFOAM/phsieh-1.4/run/tutorials/multiphaseInterFoam/damBreak4phas eFine/system/fvSolution::pd::cacheAgglomeration at line 60.
From function operator>>(Istream&, bool&)
in file primitives/bool/boolIO.C at line 72.
FOAM exiting
phsieh@kevin:~/OpenFOAM/phsieh-1.4/run/tutorials/multiphaseInterFoam>
hsieh is offline   Reply With Quote
Old   April 12, 2007, 18:25
Default Looks like FoamX thinks it is
Mattijs Janssens
mattijs is on a distinguished road
Looks like FoamX thinks it is a Switch instead of a bool or vice versa. You'll have to edit it by hand for now.
mattijs is offline   Reply With Quote
Old   April 12, 2007, 19:44
Default Hi, Mattijs, I did not use
Pei-Ying Hsieh
Hi, Mattijs,
I did not use FoamX. I basically did blockMesh to generate the mesh, then, ran the case as is in the tutorials. What will I have to change to run this case? So many new stuffs in this new version!
Pei
Old   April 12, 2007, 19:50
Default Hi, Mattijs, Got it! I nee
Pei-Ying Hsieh
Hi, Mattijs,
Got it! I need to change from "on" to "true" and "off" to "false".
Pei
MultiphaseInterFoam virginie_e OpenFOAM Running, Solving & CFD 1 July 21, 2009 03:37
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Possible bug in multiphaseInterFoam msrinath80 OpenFOAM Bugs 16 March 25, 2008 20:09
Problems with tutorialcase multiphaseInterFoam damBreak4phaseFine jfb OpenFOAM Bugs 2 February 29, 2008 06:20
MultiphaseInterFoam question msrinath80 OpenFOAM Running, Solving & CFD 0 September 17, 2007 14:45
