OF Installation Problem - Gcc Error
Old   April 8, 2009, 15:42
Default OF Installation Problem - Gcc Error
Daniel Pilatti
Daniel Pilatti is on a distinguished road
Hello!
I am starting using Linux SO, so I have a problem during the installation of OpenFOAM 1.5.
Below are the errors:
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version :
Minimum required: 4.2.0
gcc
WARNING: Conflicting installations:
OpenFOAM settings : /home/daniel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
current path :
CRITICAL ERROR
gzip 1.3.12 /usr/bin/gzip
tar 1.20 /bin/tar
icoFoam
OpenFOAM settings : /home/daniel/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam
current path :
CRITICAL ERROR
Checking networking...
Action Result Crit
Pinging_localhost Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
OpenFOAM 1.5 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
The foam installation contains 2 critical error(s).
So, please, in this case what can I do?
Daniel Pilatti is offline   Reply With Quote
Old   April 11, 2009, 00:40
Daniel Pilatti
In Portuguese...
Preciso saber como se instala o Gcc 4.3.1.
Obrigado!
Old   April 11, 2009, 14:32
Gijsbert Wierink
gwierink is on a distinguished road
Hi Daniel,
The error message says you do not have any gcc c++ compiler:
         User version    :
What linux distribution do you use? In Fedora you can install it with
yum install gcc gcc-c++
Or install gcc with the package manager, Synaptic in Ubuntu.
Regards,
Gijsbert
gwierink is offline   Reply With Quote
Old   April 12, 2009, 09:17
Daniel Pilatti
Thanks the relply Gijsbert!
Unfortunatelly, I am using Mandriva One Linux Ditstribution so the line comands in the most part of the Forum doesn't work in my linux.
Is there a way to install Gcc compiler on Mandriva or I must install Ubuntu Linux?
Att.
Daniel
Old   April 12, 2009, 10:55
Gijsbert Wierink
Hi Daniel,
You should be able to install gcc on any linux system, although there may be small differences between distributions. Mandriva has a package manager, where you can just type "gcc" and it will install it with dependencies. Via the command line the following command should work (but I must admit I am not very familiar with Mandriva ):
urpmi gcc
or maybe like this:
urpmi gcc gcc-c++
Probably you have to do this in root. Hope this helps.
Regards, Gijsbert
Old   April 14, 2009, 10:51
Daniel Pilatti
Thanks Gijsbert!
I will try to execute the code that you have wrote.
Case it doesn't work, i will install another distribution of linux!
Att.
Daniel
Old   April 16, 2009, 16:04
Daniel Pilatti
Well,
The problem whith GCC compiler continuous in my pc. The "foamInstallationTest" don't recognize that the Linux (Ubuntu and Mandriva, in my case) has the GCC compiler activated.
Att.
Daniel
Old   April 16, 2009, 16:25
Martin Romagnoli
martinr is on a distinguished road
Hi Daniel,
The foamInstallationTest says that OpenFoam is waiting for gcc executable file in the cited path " /home/daniel/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc", Can you see the gcc executable file in the cited path?
Martin
martinr is offline   Reply With Quote
Old   April 17, 2009, 00:02
Daniel Pilatti
that's it Martin!
Does not exist the directory /home/.../linux/bin/gcc, but exist /home/.../linux64/bin/gcc.
So, in /OpenFOAM/bashrc archive I found the information I have to change.
But I still have 1 Fatal error -> No remote shell available.
And 1 Critical Error -> gcc ...figure
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
Att.
Daniel
Old   April 17, 2009, 09:25
Martin Romagnoli
Hi Daniel,
Is your machine 64 bits? I ask that because you say that .../linux64/.. folder exists.
Regarding gcc critical error, OF is waiting for gcc executable file in /bin/ folder and you have it at /usr/bin/, I think you should modify the path in /OpenFOAM/OpenFOAM-1.4.1/.bashrc .
The remote shell problem might be due to ssh program. Have you installed it?
Martin.
Old   April 17, 2009, 10:50
Daniel Pilatti
Martin,
I'm going to proceed the changes that you have proposed.
And answering your question: Yes, my machine is 64bits.
And you are wright...yes, I have to reinstall the remote shell, using synaptic packages.
Thank You.
Att.
Daniel
Old   April 19, 2009, 22:07
Daniel Pilatti
So,
If help for someone:
I solved the second critical error in my installation:
I have just added a single comand in line 77 of the OF bashrc file:
"export WM_COMPILER_DIR=/usr"
And I solved the remote shell problem, by reinstalling the ssh in the synaptics packages.
Now the foamInstallationTest shows me no error!
Thanks For All!
Att.
Daniel
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
user defined function cfduser CFX 0 April 29, 2006 10:58
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 14:14
