compiler problem?
Old   May 25, 2009, 10:39
Default compiler problem?
thomasduerr is on a distinguished road
Hi folks,
I have a quick question about the recompilation of OF solvers:
I have all OF-1.5 installed and everything is running perfectly. However now I wanted/had to change some pieces of the code, when I want to recompile the solver using the wclean/wmake combination I receive an error message
>wclean
>wmake
Making dependency list for source file tractionDisplacement/tractionDisplacement FvPatchVectorField.C
Making dependency list for source file solidDisplacementFoam.C
SOURCE=tractionDisplacement/tractionDisplacementFvPatchVectorField.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-s tyle-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/acrobat /OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -ItractionDisplacement /lnInclude -IlnInclude -I. -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/Ope nFOAM/lnInclude -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Uni x/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tractionDisplacementFvPat chVectorField.o
SOURCE=solidDisplacementFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -Itr actionDisplacement/lnInclude -IlnInclude -I. -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/acrobat/we be_ol/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/solidDisplacementFoam.o
readSolidDisplacementFoamControls.H: In function ‘int main(int, char**)’:
readSolidDisplacementFoamControls.H:3: warning: unused variable ‘nCorr’
readSolidDisplacementFoamControls.H:4: warning: unused variable ‘convergenceTolerance’
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -IlnInclude -I. -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/acrobat/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC Make/linux64GccDPOpt/tractionDisplacementFvPatchVectorField.o Make/linux64GccDPOpt/solidDisplacementFoam.o -L/home/acrobat/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/acrobat/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/solidDisplacementFoam
/home/acrobat/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../lib64/libstdc++.so: file not recognized: File format not recognized
collect2: ld returned 1 exit status
make: *** [/home/acrobat/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/solidDisplacementFoam] Error 1
Can someone please help me here? I also tried to recompile the full code from source files but also get errors.....
Thanks a lot for your help,
Regards,
Thomas
thomasduerr is offline   Reply With Quote
Old   May 27, 2009, 03:43
Rishi .
hellorishi is on a distinguished road
Hi Thomas,
Can you post the output of foamInstallationTest ?
Did you download correct binaries-- i.e. 32 or 64 bit according to your machine?
Rishi
hellorishi is offline   Reply With Quote
Old   May 28, 2009, 02:39
Gijsbert Wierink
gwierink is on a distinguished road
Hi Thomas,
Does the solver without any changes (re)compile? Try to compile the original solver to see if it is a compiler or lib issue. If not, it looks like there are some code lines incorrect or incomplete. In the latter case, can you share what you are trying to do, just to check the code?
Regards,
Gijsbert
gwierink is offline   Reply With Quote
Old   May 28, 2009, 08:24
Hi guys,
thanks a lot for your posts!
I managed to solve it by downloading precomiled binaries of gcc-4.2.1 from the web.
Then I adjusted the folders 100% as in the ThirdParty gcc-4-3-1 and changed the settings.sh to source gcc 421 and it works....!
I don't have a clue why it does not work with 4.3.1 on workstations but 4.2.1 solves it!
Thanks a lot again
Thomas
compiler, installation, recompilation
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
