How to install the OpenFoam in the cluster. Please help me!
Old   November 24, 2009, 13:19
Default How to install the OpenFoam in the cluster. Please help me!
xinguang cui
flying is on a distinguished road
Hey foamers:
I hope all of you are fine. But I am really depressed by setting up openfoam in the cluster.
There is gcc4.4.1 and openmpi 1.3.3 in the cluster.
I should use all of the complier in the cluster. I am not allowed to use any complier in the thirdparty when the code is run in multi-nodes.
So, I need to compile the openfoam with the compile in cluster.
I have to set up in my home directory by myself.
First question, Are gcc 4.4.1 and openmpi 1.3.3 enough for compile openfoam 1.5?
Second question, if it is enough , how do I do it?
I have changed the complier option and mpi setting up option. As follows
# WM_COMPILER_INST = OpenFOAM | System
WM_COMPILER_INST=OpenFOAM (Orginal)
WM_COMPILER_INST=System (changed)
case "$WM_MPLIB" in
OPENMPI)
mpi_version=openmpi-1.2.6
# export MPI_HOME=$WM_THIRD_PARTY_DIR/$mpi_version
export MPI_HOME=$WM_THIRD_PARTY_DIR/$mpi_version (orginal)
# export MPI_ARCH_PATH=$MPI_HOME/platforms/$WM_OPTIONS (orginal
export MPI_ARCH_PATH=/opt/openmpi/1.3.3/gcc-4.4.1 (changed)
It could compile. But there is some error information as follows:
Note: ignore spurious warnings about missing mpicxx.h headers
+ wmake libso mpi
Making dependency list for source file OPwrite.C
could not open file ompi/mpi/cxx/pmpicxx.h for source file OPwrite.C
could not open file ompi/mpi/cxx/constants.h for source file OPwrite.C
could not open file ompi/mpi/cxx/functions.h for source file OPwrite.C
could not open file ompi/mpi/cxx/datatype.h for source file OPwrite.C
could not open file ompi/mpi/cxx/exception.h for source file Opwrite.C
Who would like to give me some idea about it?
Thanks and best wishes!
flying is offline   Reply With Quote
Old   November 25, 2009, 04:54
Franco Marra
francescomarra is on a distinguished road
Dear flying,
it is difficult for me to help you. I was able to install OpenFOAM 1.6.x on my cluster based on the Rocks distribution. I chosen to adopt the compiler and mpi distributed in OpenFOAM/Third_party.
I think you should mention the OS which is running on your cluster.
Regards,
Franco
francescomarra is offline   Reply With Quote
Old   November 25, 2009, 05:08
xinguang cui
There are so many thanks for your reply. At least I know how other person has done it.
OS: Linux version 2.6.27.22
By the way, what is Rocks distribution?
Old   November 25, 2009, 05:30
xinguang cui
OS should be Debian 4.0 "etch"
Old   November 25, 2009, 05:50
xinguang cui
There are other questions. Please give me an answer.
How did you set up the openfoam?
Did you install them in every node or only in one node?
Did you only set up in the root account or in th user account?
Old   November 27, 2009, 02:51
Markus Rehm
markusrehm is on a distinguished road
Hello Flying,
it is not easy to give general answers because it depends very much on you environment. For example, how are the nodes connected to the master and how is the storage attached?
So you should first install OpenFoam as a user in the home-space. Once this runs well you can make it available for all users in a system directory.
Regards, Markus.
markusrehm is offline   Reply With Quote
Old   November 27, 2009, 03:00
xinguang cui
Hello Markus:
Thanks so much for your reply. I will keep to try it.
Best wishes!
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
OpenFOAM Install problem masb OpenFOAM 3 May 25, 2009 11:32
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
How to run Openfoam in a cluster after I install it xiuying OpenFOAM Installation 5 May 5, 2008 12:54
