Markus Weinmann
Rep Power: 17 ![]() |
Hi all,
I just compiled OF1.6.x using the intel compiler 11.1. The compilation worked fine and I can run jobs as usual. However, when I try to run the sample utility I always get the sigFpe Handler to complain! I have used the same sample file before for many time and I never got this error using the gcc compiler. I am really running out of ideas what could cause this problem. Has anyone seen this before Markus Here is the output: #0 Foam::error ![]() #1 Foam::sigFpe::sigFpeHandler(int) in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::triangleFuncs::intersectAxesBundle(Foam::Vec tor<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&, int, Foam::Field<Foam::Vector<double> > const&, double, Foam::Vector<double>&) in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #4 Foam::triangleFuncs::intersectBb(Foam::Vector<doub le> const&, Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::treeBoundBox const&) in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #5 Foam::treeDataFace ![]() #6 Foam::indexedOctree<Foam::treeDataFace>::divide(Fo am::List<int> const&, Foam::treeBoundBox const&, Foam::List<Foam::List<int> >&) const in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #7 Foam::indexedOctree<Foam::treeDataFace>::divide(Fo am::treeBoundBox const&, Foam:dynamicList<Foam::List<int>, 0u, 2u, 1u>&, int) const in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #8 Foam::indexedOctree<Foam::treeDataFace>::indexedOc tree(Foam::treeDataFace const&, Foam::treeBoundBox const&, int, double, double) in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #9 Foam::meshSearch::boundaryTree() const in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #10 Foam::meshSearch::intersection(Foam::Vector<double > const&, Foam::Vector<double> const&) const in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #11 Foam::meshSearch::intersections(Foam::Vector<doubl e> const&, Foam::Vector<double> const&) const in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libmeshTools.so" #12 Foam::faceOnlySet::calcSamples(Foam:dynamicList<Fo am::Vector<double>, 0u, 2u, 1u>&, Foam:dynamicList<int, 0u, 2u, 1u>&, Foam:dynamicList<int, 0u, 2u, 1u>&, Foam:dynamicList<int, 0u, 2u, 1u>&, Foam:dynamicList<double, 0u, 2u, 1u>&) const in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libsampling.so" #13 Foam::faceOnlySet::genSamples() in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libsampling.so" #14 Foam::faceOnlySet::faceOnlySet(Foam::word const&, Foam ![]() #15 Foam::faceOnlySet::faceOnlySet(Foam::word const&, Foam ![]() #16 Foam::midPointSet::midPointSet(Foam::word const&, Foam ![]() #17 Foam::sampledSet::addwordConstructorToTable<Foam:: midPointSet>::New(Foam::word const&, Foam ![]() #18 Foam::sampledSet::New(Foam::word const&, Foam ![]() #19 void Foam::PtrList<Foam::sampledSet>::read<Foam::sample dSet::iNew>(Foam::Istream&, Foam::sampledSet::iNew const&) in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libsampling.so" #20 Foam::sampledSets::read(Foam::dictionary const&) in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libsampling.so" #21 Foam::sampledSets::sampledSets(Foam::word const&, Foam ![]() #22 Foam::sampledSets::sampledSets(Foam::word const&, Foam ![]() #23 main in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/sample" #24 __libc_start_main in "/lib64/libc.so.6" #25 _start in "/home/mw405/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/sample" Floating point exception |
What operating system are you on?
I cant even get the intel compiler to install on Ubuntu 9.10 since the libstdc++5 library wont install. Im no expert here, but perhaps one of the more discrete libraries was missing when you compiled. I would run ./Allwmake again to a log file and search it for errors and warnings. Good Luck! |
Markus Weinmann
I tried to install it on a cluster which uses RH53.
I am now using the gcc compiler for which the sample utility works fine. It is a sad situation since my simulations were 10% faster using the intel compilers. Markus |
Rep Power: 16 ![]() |
Hi Markus,
I tried to compile OpenFOAM-1.6 with intel- 10.1.017 on a cluster which uses OpenSuse 10.1. My settings are as follows: 1) In "OpenFOAM/OpenFOAM-1.6/etc/bashrc": : ${WM_COMPILER:=Icc}; export WM_COMPILER 2)In "OpenFOAM/OpenFOAM-1.6/etc/settings.sh:# compilerInstall = OpenFOAM | System compilerInstall=System When I run Allwmake, the message show that g++ are needed. I am just wondering, when you compile OpenFOAM with intel 11.1, how did set up? What kind of mpi did you use, openmpi or intel-mpi? Thanks. Elliot |
