please i use fedora 12 and i want to install openfoam for my first time.
how can i install it ? is fedora (bash or ksh) or (csh or csh) to install gcc-4.3.3 read me file told me to Install the compiler in: $WM_PROJECT_INST_DIR/ThirdParty/gcc-<GCC_VERSION>/platforms/$WM_ARCH$WM_COMPILER_ARCH/ and change the gcc version number in $WM_PROJECT_DIR/etc/settings.sh and $WM_PROJECT_DIR/etc/settings.csh appropriately and finally update the environment variables as in section 3. i don't understand this 1- what is $wm 2- where the compiler ![]() |
#2 | ||||||
Gijsbert Wierink
Rep Power: 18 ![]() |
Hi Ahmed,
OpenFOAM can happily run on Fedora, no worries. Quote:
uname -m Then, make a directory called "OpenFOAM" in your home directory Code:
mkdir OpenFOAM Code:
tar xzf OpenFOAM-1.6.General.gtgz Now open up ".bashrc" in the home directory with Code:
gedit ~/.bashrc Code:
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc Code:
. $HOME/.bashrc Code:
foamInstallationTest Quote:
$WM_PROJECT_INST_DIR/ThirdParty/gcc-<GCC_VERSION>/platforms/$WM_ARCH$WM_COMPILER_ARCH/ Code:
~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/ ![]() Code:
export WM_COMPILER_DIR=$WM_THIRD_PARTY_DIR/gcc-4.3.1/platforms/$WM_ARCH$WM_COMPILER_ARCH/gcc-4.3.1 Code:
gedit $WM_PROJECT_DIR/etc/settings.sh Quote:
![]() Hope this helps you on your way a bit!
Regards, Gijs |
Dear gwierink
Thank you very very much for your useful guides. one question is that i couldn't install on home dir because of permission denied error so i install it on home/user dir. is that make problem later? |
#4 | |
Gijsbert Wierink
Hi maysmech,
You're very welcome, glad I could be of any help! Quote:
Regards, Gijs |
thanks
i install it and when doing 1st tutorial, writing paraFoam this message is seen. paraFoam -case $FOAM_RUN/tutorials/incompressible/icoFoam/cavity created temporary 'cavity.OpenFOAM' /home/maysam/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/paraview-real: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory i installed all 5 files in OpenFOAM website so why i cant see mesh at parafoam as written in tutorial pdf? Last edited by maysmech; February 27, 2010 at 14:58. |
Gijsbert Wierink
Hmm, have a look at this thread and this thread. There people had the same/similar problem and soft linked libssl.so.9.8 by
ln -s /usr/lib64/libssl.so.0.9.8k /usr/lib64/libssl.so.0.9.8 Code:
ln -s /lib64/libssl.so.0.9.8b /lib64/libssl.so.0.9.8 ln -s /lib64/libcrypto.so.0.9.8b /lib64/libcrypto.so.0.9.8 ln -s /usr/lib64/elfutils/libebl_x86_64-0.125.so /lib64/libelf.so.0
Regards, Gijs |
i used readme of openfoam site http://www.openfoam.com/docs/README.php#README
now my error changes to: /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: line 129: paraview: command not found Last edited by maysmech; February 27, 2010 at 14:57. |
#8 | |
Gijsbert Wierink
gedit $HOME/.bashrc & Code:
PATH= <path_to_paraview>:$PATH export PATH Code:
PATH=/home/gijsbert/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/bin:$PATH export PATH ![]() Code:
. $HOME/.bashrc
Regards, Gijs |
#10 |
Gijsbert Wierink
No worries, glad to help, you're welcome
Regards, Gijs |
#12 | |
![]() Quote:
[maysam@maysam cavity]$ . $HOME/.bashrc bash: id: No such file or directory bash: id: No such file or directory bash: grep: No such file or directory bash: uname: command not found bash: cat: command not found /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 82: sed: command not found /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 82: sed: command not found /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 82: sed: No such file or directory /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 82: sed: No such file or directory /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 100: sed: command not found /home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 100: sed: command not found bash: /home/maysam/OpenFOAM/ThirdParty-1.6/ParaView3.6.1-cvs/platforms/linux64Gcc/bin: No such file or directory bash: gedit: No such file or directory ![]() |
#13 | |
Gijsbert Wierink
. $HOME/.bashrc
Regards, Gijs |
#14 |
typing gedit $HOME/.bashrc the editiable .bashrc doesn't open and output is
bash: gedit: No such file or directory i restart my system maybe it be solve but now i can not enter to fedora. i don't know what should i do. Last edited by maysmech; February 27, 2010 at 15:21. |
#15 |
Gijsbert Wierink
No gedit
![]() Code:
vi $HOME/.bashrc Code:
. $HOME/.bashrc
Regards, Gijs |
#16 |
my problems increase exponentially
![]() after restarting fedora i can't log in (after typing password nothing happen) now i use windows i think i should re install fedora and OpenFOAM and ... i am worry this situation cause losing important data after doing some works on openfoam ![]() |
#17 |
Gijsbert Wierink
Ai, that's nasty
Regards, Gijs |
#18 |
hi again
i reinstall fedora and OpenFOAM. typing paraFoam leads to previouse error. i read this http://www.openfoam.com/docs/README.php#README and my version of qt is 3.3.8b so i install a 35MB file that was there: ftp://ftp.trolltech.com/qt/source/qt...-4.3.5.tar.bz2 i put and execute that and after that now my version is still previous. what should i do? ![]() |
#19 |
Gijsbert Wierink
After you have compiled Qt-4.3.5 successfully, you need to make the shell aware of it. This is done by adding the path to the (new) qmake executable to your .bashrc file. In my case the compiled qmake lives in /home/gijsbert/tmp/qt-x11-opensource-src-4.3.5/bin, so I add the following: Code:
PATH=/home/gijsbert/tmp/qt-x11-opensource-src-4.3.5/bin:$PATH export PATH Code:
. $HOME/.bashrc
Regards, Gijs |
fedora, install, openfoam |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 14:43 |
install openfoam 1.6 on opensuse 11.0 | andresbh | OpenFOAM Installation | 8 | September 30, 2009 00:48 |
Installation of OpenFOAM on Fedora 11 | jits_aps90 | OpenFOAM Installation | 0 | August 20, 2009 02:23 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
