install openfoam in fedora
Like Tree1Likes
Old   February 23, 2010, 17:07
Thumbs up install openfoam in fedora
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
please i use fedora 12 and i want to install openfoam for my first time.
how can i install it ?
is fedora (bash or ksh) or (csh or csh)
to install gcc-4.3.3 read me file told me to
Install the compiler in:
$WM_PROJECT_INST_DIR/ThirdParty/gcc-<GCC_VERSION>/platforms/$WM_ARCH$WM_COMPILER_ARCH/
and change the gcc version number in $WM_PROJECT_DIR/etc/settings.sh and
$WM_PROJECT_DIR/etc/settings.csh appropriately and finally update the
environment variables as in section 3.
i don't understand this
1- what is $wm
2- where the compiler
Ahmed Khattab is offline   Reply With Quote
Old   February 24, 2010, 05:47
Gijsbert Wierink
gwierink is on a distinguished road
Hi Ahmed,
OpenFOAM can happily run on Fedora, no worries.
Download the right (i.e. 32 or 64 bit) packages from OpenCFD. If you don't know whether you have 32 or 64 bit linux, open up a terminal and type
uname -m
When you see "x86_64" it is 64 bit, when you see something like "i686" it is 32 bit.
Then, make a directory called "OpenFOAM" in your home directory
mkdir OpenFOAM
Put the downloaded files in the OpenFOAM directory and unpack them with
tar xzf OpenFOAM-1.6.General.gtgz
and so on for the other three files as well. It is important you unpack the packages labelled "General" first.
Now open up ".bashrc" in the home directory with
gedit ~/.bashrc
(don't forget the dot (".") before "bashrc") and add the line (again, don't forget the dot (".") at the beginning):
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc
Finally, update the shell by (note the dots again)
. $HOME/.bashrc
That should do the trick. You can check the installation with
foamInstallationTest
Fedora uses a bash shell.
ThirdParty should come with a gcc compiler, but if you have the possibility it is better to build your own compiler. "$WM_PROJECT_INST_DIR" is the ~/OpenFOAM directory you created in the beginning. So, suppose you install gcc-4.3.3 on a 64 bit linux machine, then
is
~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/
("~" means your home directory, your case perhaps /home/ahmed/). So that's the path you can put your new gcc in. Then, you need the make OpenFOAM aware of this by making sure that in the file $WM_PROJECT_DIR/etc/settings.sh the right version of gcc is exported. In settings.sh (on line 121 (I think )) it reads something like
export WM_COMPILER_DIR=$WM_THIRD_PARTY_DIR/gcc-4.3.1/platforms/$WM_ARCH$WM_COMPILER_ARCH/gcc-4.3.1
Now, make sure that the version numbers (above "4.3.1") are the right numbers (i.e. change them to "4.3.3", if that is what you're using). Again, just do
gedit $WM_PROJECT_DIR/etc/settings.sh
fix the line and save. In Fedora you don't need to change settings.csh.
1- what is $wm
I guess the above should explain that.
It should live in $HOME/OpenFOAM/ThirdParty. The latest version you can get from the GCC website.
Hope this helps you on your way a bit!
Regards, Gijs
gwierink is offline   Reply With Quote
Old   February 27, 2010, 03:23
maysmech's Avatar
maysmech is on a distinguished road
Dear gwierink
Thank you very very much for your useful guides.
one question is that i couldn't install on home dir because of permission denied error so i install it on home/user dir. is that make problem later?
maysmech is offline   Reply With Quote
Old   February 27, 2010, 08:55
Gijsbert Wierink
Hi maysmech,
You're very welcome, glad I could be of any help!
That's not a problem, nor strange . "$HOME" means "/home/maysmech" (if your user account is called "maysmech"). If you install OpenFOAM in "/home/" you're basically making a user called "OpenFOAM" where probably only root has write permission. In other words, you did the right thing by putting OF in your user directory . Happy foaming!
Regards, Gijs
Old   February 27, 2010, 12:21
maysmech's Avatar
thanks
i install it and when doing 1st tutorial, writing paraFoam this message is seen.
paraFoam -case $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
created temporary 'cavity.OpenFOAM'
/home/maysam/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/paraview-real: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory
i installed all 5 files in OpenFOAM website so why i cant see mesh at parafoam as written in tutorial pdf?
Old   February 27, 2010, 13:45
Gijsbert Wierink
Hmm, have a look at this thread and this thread. There people had the same/similar problem and soft linked libssl.so.9.8 by
ln -s /usr/lib64/libssl.so.0.9.8k /usr/lib64/libssl.so.0.9.8
and/or
ln -s /lib64/libssl.so.0.9.8b /lib64/libssl.so.0.9.8
ln -s /lib64/libcrypto.so.0.9.8b /lib64/libcrypto.so.0.9.8
ln -s /usr/lib64/elfutils/libebl_x86_64-0.125.so /lib64/libelf.so.0
Regards, Gijs
Old   February 27, 2010, 14:09
maysmech's Avatar
i used readme of openfoam site http://www.openfoam.com/docs/README.php#README
  • cd $WM_THIRD_PARTY_DIR
  • rm -rf paraview-3.6.1/platforms
  • makeParaView
The PV3FoamReader module is an OpenFOAM utility that can be compiled in the usual manner as follows:
  • cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
  • ./Allwclean
  • ./Allwmake
now my error changes to:
/home/maysam/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: line 129: paraview: command not found
Old   February 27, 2010, 14:23
Gijsbert Wierink
/home/maysmech/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: line 129: paraview: command not found
Right, did you export the path to ParaView in .bashrc?
gedit $HOME/.bashrc &
and add
PATH= <path_to_paraview>:$PATH
export PATH
where <path_to_paraview> is your path to ParaView. In my case it is
PATH=/home/gijsbert/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/bin:$PATH
export PATH
but at the moment I'm on a machine that only has 1.5-dev installed, so I can't check it at the moment . Have a look where paraview lives on your system and add the right path. Then, don't forget to update the shell with
. $HOME/.bashrc
Regards, Gijs
Old   February 27, 2010, 14:25
Thumbs up thank you
ahmed
really i thank you for your reply and being patient with me.
thank you
Old   February 27, 2010, 14:29
Gijsbert Wierink
No worries, glad to help, you're welcome . I also started as a beginner .
Regards, Gijs
Old   February 27, 2010, 14:32
maysmech's Avatar
i find directories to paraview directory but not more because not same as your format!
/home/maysmech/OpenFOAM/ThirdParty-1.6/ParaView3.6.1
Old   February 27, 2010, 14:55
maysmech's Avatar
i changed the .bashrc (gedit $HOME/.bashrc &) to
PATH=/home/maysam/OpenFOAM/ThirdParty-1.6/ParaView3.6.1-cvs/platforms/linux64Gcc/bin:$PATH
export PATH
and updating causes this output:
[maysam@maysam cavity]$ . $HOME/.bashrc
bash: id: No such file or directory
bash: grep: No such file or directory
bash: uname: command not found
bash: cat: command not found
/home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 82: sed: command not found
/home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 82: sed: No such file or directory
/home/maysam/OpenFOAM/OpenFOAM-1.6/bin/foamCleanPath: line 100: sed: command not found
bash: /home/maysam/OpenFOAM/ThirdParty-1.6/ParaView3.6.1-cvs/platforms/linux64Gcc/bin: No such file or directory
now i type again gedit $HOME/.bashrc but the editiable .bashrc doesn't open and output is
bash: gedit: No such file or directory
Old   February 27, 2010, 14:59
Gijsbert Wierink
You have ParaView3.6.1, not 3.6.1-cvs, so remove the "-cvs" from the line you just added to .bashrc, save the file, do again
. $HOME/.bashrc
and see what happens ...
Regards, Gijs
Old   February 27, 2010, 15:03
maysmech's Avatar
typing gedit $HOME/.bashrc the editiable .bashrc doesn't open and output is
i restart my system maybe it be solve but now i can not enter to fedora. i don't know what should i do.
Old   February 27, 2010, 15:23
Gijsbert Wierink
No gedit ? Hmm, that's weird ... Let's try vi:
vi $HOME/.bashrc
Then, type "i" for "insert mode", fix the line, type "ESC" (the ESCAPE key), and save and exit by ":wq" (notice the ":"). Then, type again
. $HOME/.bashrc
Does that work?
Regards, Gijs
Old   February 27, 2010, 15:31
Exclamation
  #16
maysmech's Avatar
my problems increase exponentially
after restarting fedora i can't log in (after typing password nothing happen)
now i use windows
i think i should re install fedora and OpenFOAM and ...
i am worry this situation cause losing important data after doing some works on openfoam
Old   February 28, 2010, 00:42
Gijsbert Wierink
Ai, that's nasty . Sorry to hear that! If your linux patition is completely dead, maybe it's an idea to access the data using a Knoppix live CD (since Windows (probably) can't access the data). Burn a Knoppix Live CD, reboot, and under Knoppix copy your stuff to a USB stick. Good luck!
Regards, Gijs
Old   February 28, 2010, 11:12
Unhappy
  #18
maysmech's Avatar
hi again
i reinstall fedora and OpenFOAM.
typing paraFoam leads to previouse error.
i read this http://www.openfoam.com/docs/README.php#README
and my version of qt is 3.3.8b so i install a 35MB file that was there:
ftp://ftp.trolltech.com/qt/source/qt...-4.3.5.tar.bz2
i put and execute that and after that now my version is still previous.
what should i do?
Old   March 1, 2010, 02:18
Gijsbert Wierink
After you have compiled Qt-4.3.5 successfully, you need to make the shell aware of it. This is done by adding the path to the (new) qmake executable to your .bashrc file. In my case the compiled qmake lives in /home/gijsbert/tmp/qt-x11-opensource-src-4.3.5/bin, so I add the following:
PATH=/home/gijsbert/tmp/qt-x11-opensource-src-4.3.5/bin:$PATH
export PATH
So check out where your freshly compiled qmake lives and put your version of the above in your .bashrc. And of course you need to open a new terminal or reload the environment variables by
. $HOME/.bashrc
Regards, Gijs
Old   March 1, 2010, 09:34
Smile
  #20
maysmech's Avatar
my problem was solved.
i update my Qt version by typing this command on terminal.
su -c 'yum update qt'
Now paraView works.
thank you dear Gijsbert.
fedora, install, openfoam
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
Installation of OpenFOAM on Fedora 11 jits_aps90 OpenFOAM Installation 0 August 20, 2009 02:23
OpenFOAM Install problem masb OpenFOAM 3 May 25, 2009 11:32
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
