OpenFOAM-1.7.0 for CentOS/RHEL/SL 5.x 64bit released
Like Tree1Likes
Old   June 30, 2010, 06:25
Default OpenFOAM-1.7.0 for CentOS/RHEL/SL 5.x 64bit released
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi all
Just finished compiling/uploading 1.7.0 for CentOS/RHEL/SL 5.x 64bit based OS'es.
As usual it can be found here
Best
Linnemann
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 1, 2010, 14:04
Alberto Passalacqua
Thank you!
Alberto Passalacqua
Old   July 2, 2010, 03:47
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
Hi Niels,
Any chance of making a 32 bit version?
rgds
Bjorn
bhh is offline   Reply With Quote
Old   July 2, 2010, 05:43
linnemann's Avatar
Niels Nielsen
Hi Bjorn
I don't use 32bit and I do not know how many CFD guys really use 32bit.
So I will have my focus on 64bit, but the manual instructions on the wiki page should apply to 32bit as well just strip the x86_64 from the yum packages.
To compile 1.7.0 you need to do the following.
as root
yum install gcc gcc-c++ bison ncurses-devel tix glibc-devel flex flex-devel zlib-devel libXt-devel
As user
cd $HOME
mkdir OpenFOAM
wget http://downloads.sourceforge.net/foam/ThirdParty-1.7.0.gtgz?use_mirror=mesh
wget http://downloads.sourceforge.net/foam/OpenFOAM-1.7.0.gtgz?use_mirror=mesh
cd OpenFOAM
tar -xvf ../ThirdParty-1.7.0.gtgz
tar -xvf ../OpenFOAM-1.7.0.gtgz
put this line in your .bashrc and source it
alias OF17=". $HOME/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc"
. $HOME/.bashrc
Now the command OF17 should load the OpenFOAM environment
Then you need a couple of dependencies to compile gcc-4.4.4
mkdir $HOME/build
cd $HOME/build
GMP---
wget ftp://ftp.gmplib.org/pub/gmp-5.0.1/gmp-5.0.1.tar.bz2
tar -xvf gmp-5.0.1.tar.bz2
cd gmp-5.0.1
OF17
./configure --prefix=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/gmp-5.0.1
make -j2 (for two cpu cores, 4 if you have 4 cores)
make install
MPFR---
cd $HOME/build
wget http://ftp.gnu.org/gnu/mpfr/mpfr-2.4.2.tar.gz
tar -xvf mpfr-2.4.2.tar.gz
cd mpfr-2.4.2
OF17
./configure --prefix=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/mpfr-2.4.2 --with-gmp=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/gmp-5.0.1
make -j2
make install
GCC---
cd $HOME/build
wget http://ftp.gnu.org/gnu/gcc/gcc-4.4.4/gcc-4.4.4.tar.gz
tar -xvf gcc-4.4.4.tar.gz
cd gcc-4.4.4
mkdir build (important to compile gcc out of source)
cd build
OF17
../configure --prefix=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/gcc-4.4.4 --with-gmp=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/gmp-5.0.1 --with-mpfr=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/mpfr-2.4.2
make -j2
make install
Now you should be able to go into the ThirdParty-1.7.0 folder and issue
OF17
./Allwmake
and the same for OpenFOAM.
You will have to figure paraview out for yourself since I don't compile it in the ThirdParty folder.
Hope this will get you somewhere.
jiaojiao likes this.
Linnemann
Old   July 2, 2010, 07:26
bhh
Bjorn H. Hjertager
Hi, Niels
I got stuck after the command:
I got the error given in the attached screenshot. Any clue about what went wrong?
rgds
Bjorn
Old   July 2, 2010, 07:35
bhh
Bjorn H. Hjertager
Hi again,
Sorry, the above error came after the "make j2" command line
rgds
Bjorn
Old   July 2, 2010, 07:42
linnemann's Avatar
Niels Nielsen
Hi
It seems gcc cant find mpfr according to this
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=35577
Did you remember to run OF17 before configuring else the path for gmp and mpfr cant be found
You could try with the full path instead of
use
--with-gmp=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/gmp-5.0.1 --with-mpfr=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/mpfr-2.4.2
Or add gmp and mpfr to your LD_LIBRARY_PATH
Linnemann
Old   July 2, 2010, 08:08
bhh
Bjorn H. Hjertager
I tried your suggestion but the same error occurred.
rgds
Bjorn
Old   July 2, 2010, 08:16
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Hi Bjorn,
Hope you are well
I had the same problem when using gcc 4.1.2.
I switched to openfoam-1.7.0 and started to compile gcc-4.4.4 with
the system compiler and could not get it to work so before switching
environment from 1.6 to 1.7, compile gcc-4.4.4 with
the compiler from openfoam-1.6.x, which was gcc-4.3.3 for me.
Then no problemo.
N
niklas is offline   Reply With Quote
Old   July 2, 2010, 08:38
bhh
Bjorn H. Hjertager
Hi Niklas & Niels,
I am not that good in linux commands, so I probably need a detailed cookbook recipe to get OF1.7 to work. Niels did a good job in doing so, but I got stuck. Niklas you also probably give good advise, but I am not able to use it (becuase of my lack of knowledge in linux).
rgds
Bjorn
Old   July 2, 2010, 08:49
niklas's Avatar
Niklas Nordin
what does it say if you type
gcc -v
Old   July 2, 2010, 08:56
bhh
Bjorn H. Hjertager
Niklas,
the Attached screenshot show the result after gcc -v. This is however after I changed to 1.6.x
Bjorn
Old   July 2, 2010, 10:04
niklas's Avatar
Niklas Nordin
right,
but Im guessing that you didnt use that version when compiling gcc-4.4.4.
However, if you stay in the 1.6.x environment you can compile gcc-4.4.4
with gcc-4.3.3 and that will probably work better
using
../configure --prefix=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/$WM_ARCH$WM_COMPILER_ARCH/gcc-4.4.4 --with-gmp=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/$WM_ARCH$WM_COMPILER_ARCH/gmp-5.0.1 --with-mpfr=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/$WM_ARCH$WM_COMPILER_ARCH/mpfr-2.4.2
make
make install
...assuming that the enviroment variables WM_ARCH and WM_COMPILER_ARCH are the same
in 1.7.0 and 1.6.x and that your installation is under $HOME/OpenFOAM
N
Old   July 5, 2010, 03:14
bhh
Bjorn H. Hjertager
When I executed the command you propose I get the response:
bash: ../configure: No such file or directory
Any clue what might be wrong?
Bjorn
Old   July 5, 2010, 03:40
niklas's Avatar
Niklas Nordin
go to the gcc-4.4.4 directory and create a dir called...for instance build with 'mkdir build'
'cd build' and execute the command from there
you should not run the configure script in the gcc-4.4.4 directory
Old   July 5, 2010, 04:39
bhh
Bjorn H. Hjertager
Niklas,
I feel stupid: in ThirdParty-1.6.x there is no gcc-4.4.4 only gcc-4.3.3. As I indicated in an earlier post I am not well adapted to linux commands.
Bjorn
Old   July 5, 2010, 06:41
niklas's Avatar
Niklas Nordin
The gcc-4.4.4 should reside in the ThirdParty-1.7.0 directory.
Just 'cd ~/OpenFOAM/ThirdParty-1.7.0' while still in the 1.6.3 environment.
Old   July 5, 2010, 08:28
bhh
Bjorn H. Hjertager
Niklas,
In OpenFOAM-1.7.0 there is no gcc folder, only:
Allwmake bin doc README ReleaseNotes-1.7 src tutorials
applications COPYING etc README.html ReleaseNotes-1.7.html test wmake
Bjorn
Old   July 5, 2010, 08:41
bhh
Bjorn H. Hjertager
Niklas
I meant to say that in OpenFOAM ThirdParty-1.7.0 thre is no gcc flder, only:
[user@OpenFOAM ThirdParty-1.7.0]$ ls
Allclean makeParaView paraview-3.8.0 platforms wmakeFiles
Allwmake metis-5.0pre2 ParMetis-3.1 scotch_5.1
AllwmakeLibccmio openmpi-1.4.1 ParMGridGen-1.0 tools
Bjorn
Old   July 5, 2010, 08:45
bhh
Bjorn H. Hjertager
NIklas,
I found the gcc-4.4.4 under /home/user/OpenFOAM/ThirdParty-1.7.0/platforms/linux/gcc-4.4.4
But there were no files present. This is what I got when executing the command
Bjorn
OpenFOAM 1.7.0 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 1 May 26, 2011 03:09
OpenFOAM 1.7.0 on OpenSUSE 11.1 Bufacchi OpenFOAM Installation 8 August 6, 2010 09:57
OpenFOAM Version 1.4.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 August 3, 2007 07:31
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 18:06
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 05:33
