August 30, 2010, 09:23 |
nfs file stale handle
Fabian Braennstroem
Rep Power: 19 |
on my cluster I have frequently problems with nfs... I get an error like: Stale NFS file handle This happens mostly during write out of an simulation or other access to the files (e.g. mapFields). Unfortunately, the simple procedures explained here (http://www.cyberciti.biz/tips/nfs-st...-solution.html) are not working always... so according to the statement of Daemeon from January 29, 2009: "When you force unmount/remount and still get the error, you have some program that is probably (?) not following proper file handle semantics about closing files.", there might be a problem in openfoam!? This happens with 1.5-dev,1.6.x and 1.7.x. The cluster has OpenSUSE 11.2 installed. The workstation is running with opensuse 11.1 and ubuntu lucid, which share the data directories using nfs. Does anyone have similar problems and could have an advice, what I could check or adjust (maybe there are some nfs settings making it a bit more 'stable')!? Regards! Fabian |
August 30, 2010, 09:35 |
Anton Kidess
Rep Power: 30 |
I don't think this is an OpenFOAM problem. I've only ever had problems with stale file handles eg. if I move a directory in one ssh session while it's currently the pwd in another session. Are you the administrator of the cluster? Maybe someone is changing something while you are working?
August 31, 2010, 04:21 |
Fabian Braennstroem
Rep Power: 19 |
thanks for your reply! I think so as well, that OpenFOAM is not the reason for this. Do you have a hint, what I am doing wrong in the setup of the cluster? Maybe the installed kernel 2.6.31.8-0.1 is the bad guy or needs some adjustments!? Or does there exist something different than nfs to share directories among machines? Would be nice, if you can help! Fabian |
August 31, 2010, 04:32 |
Anton Kidess
Rep Power: 30 |
I'm sorry, I never set NFS up myself, so I can't really help with that. Hopefully someone more experienced in setting up a cluster stumbles on this thread. Another idea is taking the question to another forum with more network specialists, eg. http://serverfault.com/
- Anton |
September 2, 2010, 01:15 |
Fabian Braennstroem
Rep Power: 19 |
Thanks, I will check the other forum...
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
