OF 1.7.1 on Fedora 13
Old   November 15, 2010, 00:56
Achin is on a distinguished road
Hi
Thanks every one. I installed OpenFoam successfully. I used GIT Repository. It has got many bugs fixed including the missing patch of LINKEXE.
Thanks a lot.
Regards
Abhinav
Achin is offline   Reply With Quote
Old   March 29, 2011, 22:15
ruma
ruma is on a distinguished road
Hi ,
I am trying to build source for OpenFOAM, but have problem. I kept the files /usr/local/OpenFOAM-1.7.1/ and also thirdparty under /usr/local/Thirdparty-1.7.1/
I hve fedora 13 OS. How would I source in my .bashrc file
.$HOME/OpenFOAM-1.7.1/etc/bashrc is the correct way?
then ./Allwmake . I need help
sorry achin. it shud be /etc a typo mistake
ruma is offline   Reply With Quote
Old   March 29, 2011, 22:56
Hi
It's not ets but it's etc. So it is . $HOME/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc
after adding this line in your $HOME/.bashrc file, type . $HOME/.bashrc in terminal window.
I guess . $HOME/.bashrc sets the variables for all sessions.
Regards
Originally Posted by ruma View Post
Hi ,
.$HOME/OpenFOAM-1.7.1/ets/bashrc is the correct way?
Old   March 30, 2011, 04:36
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Hi ,
Ok, but I would keep it in your $HOME directory.
No, because OpenFOAM is installed in /usr/local/, so you need to point it there.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   March 31, 2011, 20:48
Post
  #25
ruma
Originally Posted by Achin View Post
Hi
Thanks a lot.
Regards
Abhinav
Hi, did u install on fedora 13? i got lots of error. main/usr/bin/ld: cannot find -ldl/home/ruma/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so
collect2: ld returned 1 exit status
make[2]: *** [/home/ruma/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/rhoCentralDyMFoam] Error 1
make[1]: *** [rhoCentralFoam] Error 2
how did you do? pls tell us.
Old   March 31, 2011, 23:32
Hi
There are certain dependencies that u must have before u try to build it. Here is a yum command, try it out first and make sure that every thing is there, needed for openfoam.
yum install gcc gcc-c++ binutils-devel flex git-core wget cmake qt4-devel python-devel readline-devel bison
I installed in fedora 13 and I used GIT repository as source building has got some unfixed bugs which were giving me errors quite similar to your errors, for me the errors were for a different application. Hence I was not able to properly install using source. So try GIT.
you may be getting error because of not installed binutils thus above command should help you. Another is a LINKEXE patch missing in certain files which is fixed in the GIT repository.
Regards
Old   March 31, 2011, 23:53
ruma
Hi Achin,
I did already did it. Still I got error. I used git repository. it's libPstream.so problem.
Error compiling 1.6.x on Fedora 12 vnpenguin OpenFOAM Installation 7 July 24, 2012 14:52
OpenCFD release OpenFOAMŪ version 1.7.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2010 11:40
Fedora 10 OpenFOAM15 philippose OpenFOAM Installation 7 February 18, 2009 04:37
STAR-CD 3.268in Fedora 8 Thomas Stockheim Siemens 3 April 28, 2008 03:43
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 11:05
