Install OpenFoam 1.6-ext
Old   June 1, 2011, 03:28
Default Install OpenFoam 1.6-ext
Yasser Amini
aminiyasser is on a distinguished road
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh
Using openmpi-1.4.3 from the ThirdParty package: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/etc/openmpi-1.4.3.sh
Using system installed OpenMPI:
OPENMPI_BIN_DIR : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/bin
OPENMPI_LIB_DIR : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib
OPENMPI_INCLUDE_DIR : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include
OPENMPI_COMPILE_FLAGS : -I/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include -pthread
OPENMPI_LINK_FLAGS : -pthread -L/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
MPI_HOME : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt
MPI_ARCH_PATH : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt
OPAL_PREFIX : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt
PINC : -I/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include -pthread
PLIBS : -pthread -L/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt/etc/mesquite-2.1.2.sh
MESQUITE_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64GccDPOpt/etc/metis-5.0pre2.sh
METIS_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64GccDPOpt
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64GccDPOpt/etc/ParMetis-3.1.1.sh
PARMETIS_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64GccDPOpt
PARMGRIDGEN_DIR is initialized to:
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64GccDPOpt/etc/libccmio-2.6.1.sh
LIBCCMIO_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64GccDPOpt
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64GccDPOpt/etc/scotch-5.1.10b.sh
SCOTCH_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64GccDPOpt
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.3/platforms/linux64GccDPOpt/etc/cmake-2.8.3.sh
CMAKE_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.3/platforms/linux64GccDPOpt
PYTHON_DIR is initialized to:
QT_DIR is initialized to:
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/etc/ParaView-3.8.1.sh
PARAVIEW_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh
aminiyasser@lap:~$
aminiyasser is offline   Reply With Quote
Old   June 1, 2011, 03:53
lindstroem is on a distinguished road
Have you compiled the ThirdParty files first? There is a folder "ThirdParty" - enter it an run AllMake
Hope it helps
lindstroem is offline   Reply With Quote
Old   June 1, 2011, 04:14
Default Dear lindstroem
Yasser Amini
Hope it helps
yes I run ./AllMake in ThirdParty and successfully install paraview
also some of my solver is worked but the icoFsiFoam not worked
Old   June 1, 2011, 04:31
Originally Posted by aminiyasser View Post
but the ./Allwmake in openFoam-1.6-ext folder is not execute in these command and therefor the solvers not compiled when I Run ./Allwmake in openFoam-1.6-ext folder I encounter error
But how can some solvers run, when you haven't compiled them? Are you sure you don't use the OF1.7.1 solvers? if AllMake is not executable - make it executalbe:
chmod +x AllMake But actually it should already be executable... Sorry, dont know whats wrong.
Old   June 1, 2011, 08:01
Yasser Amini
are you install openFoam 1.6-ext ? if yes please tell me step by step of your install procedure
can you run the icoFsiFoam tutorial ?
I want install 1.6-ext again what command should be used for clean openfoam 1.6-ext and its solvers
Old   June 1, 2011, 08:26
I have 1.6-ext running but the icoFsiFoam is obviously not part of this package. It needs to be installed afterwards by hand:
http://www.cfd-online.com/Forums/ope...cofsifoam.html
So you have to download the sources and build them. There are several guides how to install of1.6-ext online so i dont need to rewrite it again. If you have problems post the error messages then it is easier to help you.
Old   June 1, 2011, 09:10
Yasser Amini
Dear lindstroem
icoFsiFoam is a solver of 1.6-ext and exist in stressAnalysis
the path of tutorial of icoFsiFoam is :
OpenFOAM-1.6-ext/tutorials/stressAnalysis/icoFsiFoam/
Old   June 1, 2011, 09:47
Jesse
bigcarrot23 is on a distinguished road
If u wanna uninstall it, Firstly you should delete one command line related to settings.sh in .bashrc. You can use "rm -rf" command to delete it completely after that.
bigcarrot23 is offline   Reply With Quote
Old   June 1, 2011, 10:01
Yasser Amini
I delete this line in .bashrc
. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
and then execute " rm -rf "
but the openFoam 1.6-ext not removed !!!!!!!!!
Old   June 3, 2011, 17:53
Nima Samkhaniani
nimasam is on a distinguished road
where do u execute rm -rf?
rm : remove
r : recursive
f :with force!
so:
cd ~
rm -rf OpenFOAM
nimasam is offline   Reply With Quote
Old   June 4, 2011, 00:44
Default dear nima
  #11
Yasser Amini
rm : remove
r : recursive
f :with force!
so:
cd ~
rm -rf OpenFOAM
Dear nima
tanks for your answer
I have removed OpenFoam1.6-ext
are you install openFoam1.6-ext ?
Old   June 4, 2011, 10:21
Nima Samkhaniani
whats wrong with ur installation?
Old   June 6, 2011, 01:10
Default Daer Nima
  #13
Yasser Amini
Dear nima
my errors is displayed at the top of this page
Old   June 6, 2011, 04:41
I found the tutorial, it runs fine on my machine. What system are you running on?
Old   June 8, 2011, 00:50
Yasser Amini
my OS is Ubuntu 10.0.4.2
which tutorial ?
can you sen it to me ?
Old   June 8, 2011, 08:53
which tutorial ?
the icoFsiFoam tutorial..
Maybe you can try this tutorial for an installation of 1.6-ext.. otherwise git clone the sources try to build them and if it fails post error messages..
Originally Posted by wyldckat View Post
Greetings to all!
@rassilon: OK, I've got Ubuntu 10.10 as well and here is what I did:
  1. Added the repository as indicated in the wiki:
    sudo add-apt-repository ppa:cae-team/ppa
  2. Then went to the "Synaptic Package Manager", menu "Settings->Repositories".
  3. In the tab "Other Software", edited the entries for cae-team and changed from maverick to lucid.
  4. Closed the "Repositories" dialog.
  5. Pressed the "Reload" button on the top left in Synaptic.
  6. Wrote "openfoam" on the "Quick search" edit box and voilá, the versions provided by the CAE Team appeared.
  7. I chose the desired packages and installed without any problems!
Best regards and good luck!
Bruno
Old   May 27, 2012, 09:34
Default openFOAM-1.6-ext
  #17
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hello all
how can i install OpenFOAM-1.6-ext on Kubuntu while OF-1.5-dev installed automatically on this version of Linux?
i read some documention about this problem, but i could not success to install it. would you mind to tell me step by step that how do it?
tanx
______
Kind Regards
desert_1250 is offline   Reply With Quote
Old   May 29, 2012, 04:08
Elvis
elvis will become famous soon enough
you can have installed more than one installation coexisting side by side if you have the right .bashrc ;-)
alias startOF15dev='unset FOAM_INST_DIR;unset WM_PROJECT_USER_DIR;unset WM_THIRD_PARTY_DIR;source /usr/lib/OpenFOAM-1.5dev/etc/bashrc'
alias startOF16ext='unset FOAM_INST_DIR;unset WM_PROJECT_USER_DIR;unset WM_THIRD_PARTY_DIR;source /usr/lib/OpenFOAM-1.6-ext/etc/bashrc'
alias startOFwhateveryouwant='...'
please write the correct path after source => http://openfoamwiki.net/index.php/Installation
on the console you type startOF16ext or startOF15dev or startOFwhateveryouwant to use the specific OFversion you want
elvis is offline   Reply With Quote
Old   October 23, 2012, 11:56
fatemeh sadeghpour
fatemeh.sadeghpour is on a distinguished road
Dear nima
I have question?
cd ~
rm rs OpenFOAM or OpenFOAM-1.6-ext???
i want to uninstall 1.6 and then to install again, because it has wrong directory, i should install in openfoam 2.1.1 directory not run directory.
but i dont want to make mistake,for example not to remove openfoam 2.1.1
please help me
thanks
fatemeh.sadeghpour is offline   Reply With Quote
Old   October 23, 2012, 12:36
Nima Samkhaniani
Hi
How did you install your OpenFOAM?
from source, binary package or .deb package?
if you install it from source or binary package you can go to that directory and
remove it with
rm -rf
but if you install .deb package, you can easily uninstall it from synaptic package manager
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 00:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 04:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 09:04
