June 10, 2011, 03:41 |
Compiling OpenFOAM on hpc-fe.gbar.dtu.dk
Kasper Kærgaard
Rep Power: 16 |
Hi All.
I have successfully compiled OpenFOAM-1.7.1 on the DTU cluster hpc-fe.gbar.dtu.dk. Follow the normal instructions for compiling openfoam, but pay attention to the following: The default gcc version on the cluster is too old to use (most of openfoam compiles, but some libraries will fail), so you must configure openfoam to use gcc44 and g++44 instead of gcc and g++. In OpenFOAM-1.7.1/etc/bashrc change the value of WM_CC and WM_CXX to gcc44 and g++44, respectively. Further you must edit the two files, c and c++ in OpenFOAM-1.7.1/wmake/rules/linux64Gcc/, to change any occurrences of "gcc" and "g++" into "gcc44" and "g++44". This information was found at: http://consultancy.edvoncken.net/ind...lding_OpenFOAM Furthermore you must configure openfoam to use the system mpi instead of the one that ships with OpenFOAM. First tell openfoam to use the system mpi: in OpenFOAM-1.7.1/etc/bashrc set the variable WM_MPLIB to SYSTEMOPENMPI. The line you should edit ends up looking like this: : ${WM_MPLIB:=SYSTEMOPENMPI}; export WM_MPLIB Next tell openfoam where to find the system MPI. In etc/settings.sh right after these two lines: SYSTEMOPENMPI) # use the system installed openmpi, get library directory via mpicc mpi_version=openmpi-system add these two lines: export MPI_HOME=/opt/SUNWhpc/HPC8.2.1c/gnu/ export MPI_ARCH_PATH=/opt/SUNWhpc/HPC8.2.1c/gnu/ In order to use the system mpi you must call: module load mpi at the beginning of your session, i.e. either interactive session, or in your run file. My run file to submit to the que looks like this (this I have inherited from NGJ): #! /bin/sh # <SUN Grid Engine> # ======================= # standard start options, standardized job-name/output #$ -S /bin/sh -cwd -j yes -N test1 -o log.run$JOB_ID # ======================= # </SUN Grid Engine> # <environ> # --------------------------------------------------------------------------- # : ${SGE_ROOT:=/opt/sge/sge6_2u5/} # : ${SGE_CELL:=default} # for i in $SGE_ROOT/$SGE_CELL/site/environ; do [ -f $i ] && echo "source $i" && . $i; done # PATH=$HOME/bin:/home/ngja/OpenFOAM/ThirdParty/cmake-2.6.4/build/bin/:$PATH FOAM_SIGFPE=1 #Halts on Nan/Floating Point Exceptions module load mpi . $HOME/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc # --------------------------------------------------------------------------- # </environ> APPLICATION=waveFoam17 WHICH_APP=`echo $APPLICATION | cut -f1 -d" "`; WHICH_APP=`which $WHICH_APP`; caseName=${PWD##*/} jobName=$caseName # avoid generic names case "$jobName" in foam | OpenFOAM ) jobName=$(dirname $PWD) jobName=$(basename $jobName) ;; esac cat<<PRINT (**) job $jobName (**) pwd ${PWD/$HOME/~} (II) job_id $JOB_ID (II) queue ${QUEUE:-NULL} (II) host ${HOSTNAME:-NULL} (II) slots ${NSLOTS:-1} (II) foam ${WM_PROJECT_VERSION} (II) App ${WHICH_APP/$HOME/~} # parallel/serial if [ "$NSLOTS" -gt 1 ]; then mpirun=mpirun case "$PE" in ompi) echo "(II) mpi $PE-${OPENMPI_VERSION}" # openmpi parameters ## mpirun="$mpirun --mca mpi_yield_when_idle 1" ;; esac mpirun="$mpirun --mca btl_openib_verbose 1 --mca btl ^tcp ${APPLICATION} -parallel" echo "(II) mpirun /usr/mpi/gcc/openmpi-1.4.1/bin/mpirun" echo "(II) cmd $mpirun" exec $mpirun else echo "(II) cmd ${APPLICATION}" ${APPLICATION} fi Kind regards Kasper Kærgaard |
June 16, 2011, 01:33 |
Balkrishna Patankar
Rep Power: 17 |
Hi ,
I am using OpenFOAM on an Intel cluster . I compiled it successfully with the openfoam openmpi however it gave the following error on running a case : Code:
cn052.2077ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2077PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) -------------------------------------------------------------------------- PSM was unable to open an endpoint. Please make sure that the network link is active on the node and the hardware is functioning. Error: PSM Could not find an InfiniPath Unit -------------------------------------------------------------------------- cn052.2081ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2081PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2079ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2079PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2078ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2078PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2084ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2084PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2083ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2083PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2088ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2088PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2080ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2080PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2086ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2086PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2087ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2087PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2085ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2085PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) cn052.2082ipath_wait_for_device: The /dev/ipath device failed to appear after 30.0 seconds: Connection timed out cn052.2082PSM Could not find an InfiniPath Unit on device /dev/ipath (30s elapsed) (err=21) -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): PML add procs failed --> Returned "Error" (-1) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2077] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2079] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2082] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2083] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2080] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2081] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 2077 on node cn052 exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [cn052:02074] 23 more processes have sent help message help-mtl-psm.txt / unable to open endpoint [cn052:02074] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages [cn052:02074] 7 more processes have sent help message help-mpi-runtime / mpi_init:startup:internal-failure *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2088] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [cn052:2087] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! On changing $WM_MPLIB in etc/bashrc in the openfoam folder and adding the two lines etc/settings.sh as follows : Code:
In etc/bashrc ${WM_MPLIB:=SYSTEMOPENMPI}; //etc/bashrc In etc/settings.sh export MPI_HOME=$I_MPI_ROOT export MPI_ARCH_PATH=$I_MPI_ROOT Code:
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' collect2: ld returned 1 exit status Code:
module load mpi Could u help me out in sorting the above problems ? Thanks , Balkrishna . |
Help Compiling OpenFOAM 1.6 on SGI Altix Machine | deji | OpenFOAM | 11 | February 16, 2011 11:10 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
OpenFOAM benchmarks for HPC | tomislav_maric | OpenFOAM Running, Solving & CFD | 0 | April 21, 2010 17:39 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix | mbeaudoin | OpenFOAM Installation | 2 | April 28, 2006 08:54 |
