OpenFOAM-2.0.1 installation problem
Old   September 14, 2011, 07:02
Default OpenFOAM-2.0.1 installation problem
Ruben I. Mukhamadeev
benru is on a distinguished road
1. Fragment with fault from installation log:
make[1]: Entering directory `/home/ben/OpenFOAM/OpenFOAM-2.0.1/applications/solvers/stressAnalysis'
make[2]: Entering directory `/home/ben/OpenFOAM/OpenFOAM-2.0.1/applications/solvers/stressAnalysis/solidDisplacementFoam'
Making dependency list for source file tractionDisplacement/tractionDisplacementFvPatchVectorField.C
Making dependency list for source file solidDisplacementFoam.C
make[2]: Leaving directory `/home/ben/OpenFOAM/OpenFOAM-2.0.1/applications/solvers/stressAnalysis/solidDisplacementFoam'
SOURCE=tractionDisplacement/tractionDisplacementFvPatchVectorField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tractionDisplacementFvPatchVectorField.o
SOURCE=solidDisplacementFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/solidDisplacementFoam.o
readSolidDisplacementFoamControls.H: In function ‘int main(int, char**)’:
readSolidDisplacementFoamControls.H:3: warning: unused variable ‘nCorr’
readSolidDisplacementFoamControls.H:5: warning: unused variable ‘convergenceTolerance’
solidDisplacementFoam.C: In copy constructor ‘Foam::PtrList<T>::PtrList(const Foam::PtrList<T>&) [with T = Foam::Field<Foam::Vector<double> >]’:
solidDisplacementFoam.C:134: internal compiler error: Segmentation Fault.
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.4/README.Bugs> for instructions.
make[2]: *** [Make/linux64GccDPOpt/solidDisplacementFoam.o] Error 1
make[2]: Aim `/home/ben/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/solidDisplacementFoam' was not created due to errors.
make[1]: *** [solidDisplacementFoam] Error 2
make[2]: Entering directory `/home/ben/OpenFOAM/OpenFOAM-2.0.1/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
Making dependency list for source file tractionDisplacementCorrection/tractionDisplacementCorrectionFvPatchVectorField.C
Making dependency list for source file solidEquilibriumDisplacementFoam.C
make[2]: Leaving directory `/home/ben/OpenFOAM/OpenFOAM-2.0.1/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
SOURCE=tractionDisplacementCorrection/tractionDisplacementCorrectionFvPatchVectorField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o
SOURCE=solidEquilibriumDisplacementFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/solidEquilibriumDisplacementFoam.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-2.0.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o Make/linux64GccDPOpt/solidEquilibriumDisplacementFoam.o -L/home/ben/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib \
-lfiniteVolume -lOpenFOAM -ldl -lm -o /home/ben/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam
make[1]: Aim `application' was not created due to errors.
make[1]: Leaving directory `/home/ben/OpenFOAM/OpenFOAM-2.0.1/applications/solvers/stressAnalysis'
make: *** [stressAnalysis] Error 2
make: Aim `application' was not created due to errors.
2. OS: Debian 6.0.2
3. Computer: Intel Core2Duo 3GHz, mem 2Gb etc
4. Before it (a day ago) OF-2.0.1 was successfully installed on other computer (AMD64, dual core, mem 2Gb etc.) with the same OS (installed from the same disk by myself), without any troubles.
Could you offer simple path to solve problem ?
Thank you.
benru is offline   Reply With Quote
Old   September 14, 2011, 09:15
As I understood, it was technology fault (temporary memory or cach volume fault), so it was performed :
cd applications/solvers/stressAnalysis/solidDisplacementFoam
wclean
wmake
cd applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam
wclean
wmake
And solvers were created. After that
cd home/OpenFOAM/OpenFOAM-2.0.1
and ./Allwmake to continue procedure
OpenFoam 2.0.0 installation Jan_Peters OpenFOAM Installation 86 April 27, 2012 05:32
Openfoam installation problem jose soto OpenFOAM Installation 4 August 9, 2011 01:29
OpenFOAM 1.7.0 installation problem stevek OpenFOAM 14 December 1, 2010 15:30
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
Installation problem with GCC Norma McKee (Mckee) OpenFOAM Installation 10 March 4, 2007 07:09
