[mesh manipulation] polyDualMesh edges between patches
Like Tree3Likes
  • 3 Post By maninthemail
Old   May 22, 2012, 06:11
Default polyDualMesh edges between patches
Bill
maninthemail is on a distinguished road
I am trying to convert from a tetrahedral to a polyhedral mesh using the polyDualMesh utility. I cannot get cells on edges between patches to form correctly.
This post <http://www.cfd-online.com/Forums/openfoam-meshing-technical/61911-polyhedral-mesh-generation-2.html#post180946> is what the mesh should look like. The attached image is what my mesh looks like. Note that the cells on along the edges of the cubes have not been combined.
The original tet mesh was made in icem, using the delaunay meshing tool. It was converted to openfoam using fluent3DMeshToFoam, and the cellZone, faceZone, etc... files were deleted (necessary so that polyDualMesh doesn't treat all faces as boundaries). The command "polyDualMesh 60" was then used to get the mesh shown. Other feature angles do not solve the problem (I've tried quite a range). Is there something I'm missing?
maninthemail is offline   Reply With Quote
Old   May 22, 2012, 13:15
Bill
Never mind, I figured it. Running "combinePatchFaces 60" (or whatever feature angle) afterwards seems to sort the edges out.
dual, edge, mesh, poly, tetrahedral
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
[mesh manipulation] Sharp edge problem on concave patches using polyDualMesh without error keepfit OpenFOAM Meshing & Mesh Conversion 1 November 25, 2014 14:28
