[Other] Problem with changed MixerVesselAMI2D tutorial
Old   August 23, 2012, 04:19
Default Problem with changed MixerVesselAMI2D tutorial
Alexander A
A.A. is on a distinguished road
I imorted another mesh in the MixerVesselAMI2D tutorial.
The mesh has a cube as rotor. I only changed the mesh and created the files in the set dirctory and also the cellZones file.
when I run the case it only creates a 0.1 time folder and then crashes. In the log.pimpleDyMFoma it looks like the calculation went through. What could be the reason?
On the attached picture you can see the mesh before it crashes. Why is the pressure so wrong?
Regards,
Alex
A.A. is offline   Reply With Quote
2D NACA 6412 Tutorial Extrusion Problem siw Pointwise & Gridgen 10 June 11, 2014 13:27
Problems to recreate mixerVesselAMI2D Tutorial with imported Mesh from Pointwise carstenf OpenFOAM Pre-Processing 1 April 8, 2014 17:25
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
newbie problem with cavity tutorial miki OpenFOAM Running, Solving & CFD 8 September 2, 2012 15:22
Problem with the Fan tutorial widedMed OpenFOAM 3 March 29, 2011 04:35
