[blockMesh] mesh causing problems with convergence |
Rep Power: 14 ![]() |
I'm having problems with my mesh causing divergence. I'm trying to replicate the results in this PDF here but the mesh I've created has issues are causing simpleFoam to diverge. For some reason, the solution is only diverging at higher angles of attack.
I've put together a set of pictures showing the problem and my geometry. They are located here. For some reason, all along the join between the four hex blocks, the solution diverges. The most extreme example is the portion pictured in the album. I'm not sure if the non-ortho faces that checkMesh finds are the source of the problem. There are some right at the wingtip, where the most extreme divergence is, but the divergence continues all the way out, but there are no non-ortho faces that far out. I'm hoping that one of you can tell me how to fix the problem without having to re-do the whole blockMesh file. Or, if you say that's not possible, to give me recommendations on how to make this geometry without causing bad cells and faces in the mesh. I'd like any suggestions to keep in mind that I will be changing things like airfoils and aspect ratio, so it should be automation friendly. Thank you for you help. I've attached my blockMesh file and this is my checkMesh file Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : checkMesh Date : Sep 22 2012 Time : 13:54:28 Host : "Heterodyne" PID : 2781 Case : /home/tetragramm/OpenFOAM/0012 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 4040101 faces: 12040000 internal faces: 11920000 cells: 4000000 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 3960000 prisms: 40000 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology movingWall 40000 40001 ok (non-closed singly connected) fixedWalls 40000 40001 ok (non-closed singly connected) symmetricWall 40000 40400 ok (non-closed singly connected) allAround 0 0 ok (empty) Checking geometry... Overall domain bounding box (-2.59808 -2.84808 0) (2.59808 2.34808 3) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.07313e-15 -5.50671e-15 5.79448e-15) OK. Max cell openness = 1.74778e-15 OK. Max aspect ratio = 149.528 OK. Minumum face area = 4.19645e-07. Maximum face area = 0.00338268. Face area magnitudes OK. Min volume = 1.46671e-09. Max volume = 7.5958e-05. Total volume = 30.7017. Cell volumes OK. Mesh non-orthogonality Max: 86.9482 average: 28.9597 *Number of severely non-orthogonal faces: 24795. Non-orthogonality check OK. <<Writing 24795 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. ***Max skewness = 11.086, 9003 highly skew faces detected which may impair the quality of the results <<Writing 9003 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 19:55 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
