[Commercial meshers] fluent patch type periodic not recognised although no periodics are defined |
November 22, 2012, 08:54 |
Hello there
i have a little problem while converting a mesh, created with gridgen with the fluentMeshToFoam command. i want to simulate a 2D convergent-divergent axisymmetric nozzle. therefore i first created just one half of the 2D model. So i have 4 boundaries, one wall in the shape of the nozzle, one symmetrie plane as the axis, inlet and outlet. when i want to convert that mesh file everything works just fine the way it should. but when i want to convert the meshfile for the whole 2D nozzle openfoam complains about periodic patches. but i dont have any periodic or symmetry boundarys, just the upper and lower nozzle wall, inlet and outlet. thats why i am a little bit confused about the error and not really shure about what to do. i do know that during the lexing he mentions an periodic patch, but i don't know why, because the only boundary conditions set in gridgen are wall, velocity-inlet and pressure-outlet. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading header: "exported from Gridgen 15.10R1" Dimension of grid: 2 Number of points: 1798 number of faces: 3507 Number of cells: 1710 Reading points Other readCellGroupData: 2 1 6ae 1 3 Reading uniform cells Read zone1:2 name:fluid patchTypeID:fluid Reading zone data Embedded blocks in comment or unknown: ( Found end of section in unknown ,Reading uniform faces Read zone1:3 name:interior-3 patchTypeID:interior Reading zone data Embedded blocks in comment or unknown: ( Found end of section in unknown ,Reading uniform faces Read zone1:4 nameeriodic-4 patchTypeIDeriodic Reading zone data Embedded blocks in comment or unknown: ( Found end of section in unknown ,Reading uniform faces Read zone1:5 name:shadow-5 patchTypeID:shadow Reading zone data Embedded blocks in comment or unknown: ( Found end of section in unknown: ,Reading uniform faces Read zone1:6 name:velocity-inlet-6 patchTypeID:velocity-inlet Reading zone data Embedded blocks in comment or unknown: ( Found end of section in unknown: ,Reading uniform faces Read zone1:7 nameressure-outlet-7 patchTypeIDressure-outlet Reading zone data Embedded blocks in comment or unknown: ( Found end of section in unknown 8 (1 8 4 5Embedded blocks in comment or unknown: ( Found end of section in unknown: 8 (1 2 4 5Embedded blocks in comment or unknown: ( Found end of section in unknown: 8 (1 9 4 5Embedded blocks in comment or unknown: ( Found end of section in unknown 8 (1 26 4 5 FINISHED LEXING dimension of grid: 2 Grid is 2-D. Extruding in z-direction by: 0.0223607 Creating shapes for 2-D cells Building patch-less mesh...--> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 619 Found 3594 undefined faces in mesh; adding to default patch. done. Building boundary and internal patches. Creating patch 0 for zone: 3 start: 1 end: 3333 type: interior name: interior-3 Creating patch 1 for zone: 4 start: 3334 end: 3390 type: periodic name: periodic-4 --> FOAM FATAL ERROR: fluent patch type periodic not recognised. From function fluentToFoam::main(int argc, char*argv[ ]) in file fluentMeshToFoam.L at line 1344. FOAM aborting hopefully someone has a clue how to solve my problem. thanks a lot! Bando |
reactingMultiphaseEulerFoam | tonnykz | OpenFOAM Running, Solving & CFD | 2 | June 15, 2020 02:09 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
