[mesh manipulation] splitting boundary patch into several patches
Old   March 27, 2013, 04:33
Default splitting boundary patch into several patches
Andreas Wendy
A.Wendy is on a distinguished road
Hi everybody,
is there a posibility after running snappyhexmesh etc. a boundary patch in for example 6 pieces along one direction?
the problem is the following:
i splitted a blade in 6 different stl files. the geometry is allways the same but at the region where 2 parts are connected the layer mesh looks very bad. so i want to mesh it as a single patch and splitt it afterwarts into several patches. so that i can extract forces along the blade.
is there a possibility?
best wishes
Andy
A.Wendy is offline   Reply With Quote
Old   April 2, 2013, 08:06
Andreas Wendy
nobody an idea?
Old   April 2, 2013, 08:41
haakon will become famous soon enough
Have you seen the new feature in version 2.2 that allows you to do approximately what you want, i.e. write forces in "bins" along a specific direction?
See the release notes: http://www.openfoam.org/version2.2.0...processing.php
haakon is offline   Reply With Quote
Old   April 3, 2013, 01:46
Andreas Wendy
hi,
i have to work with OpenFOAM 1.6 extend. Do you know if i can calculate the Forces after finisching the computation?
Old   April 3, 2013, 02:23
In the case of using 1.6-ext I have no ideas (other than splitting the boundary patch as you suggested). Sorry.
(Perhaps you can take this piece of code back into 1.6-ext? I guess this part is pretty similar).
Old   April 15, 2013, 01:50
Akshay Kumar
Akshay is on a distinguished road
Hi AW!
Since you have those individual STL's, you could use them to create a faceSet( use topoSet). This faceSet can then be used to create patches using createPatch and you could call your force functions to calculate on these patches. This might work.
Cheers!
Akshay
Akshay is offline   Reply With Quote
Old   April 15, 2013, 01:59
Akshay Kumar
Or...
You could use 'sample' utility. This works on STLs. But i doubt if the extend version has the 'SampledtriSurfaceMesh' type. But I believe you could setup the 2.1 'sample' code in your environment.
Cheers
Akshay
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 07:56
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
