[snappyHexMesh] Jagged Edges
Old   April 5, 2013, 17:12
Default Jagged Edges
Eric Robertson
msuaeronautics is on a distinguished road
I am in the process of figuring out the ins and outs of snappyHexMesh. I have generated a generic delta wing model in a CAD program and exported the model in STL format. Using the motorBike tutorial as a guide, I set up my snappyHexMesh dict and ran it for this particular model.
The result as well as the dictionary file are attached.
Now, what exactly, within the dictionary file, controls or would help stop these jagged edges from being generated? I am using OpenFOAM 2.0.0.
msuaeronautics is offline   Reply With Quote
Old   April 9, 2013, 02:40
Akshay Kumar
Akshay is on a distinguished road
Hey
This issue has been existing for quite sometime. Since your simulation needs to be precise(external flow), i'll not suggest you to fix the eMesh file and try to refine the edge mesh. Instead, I'll ask you to try and align the blockMesh with this jagged edge. This might mess with the other edges but give it a shot.
Or
You could try running the latest 2.2.0 , the guys might have resolved this issue.
Akshay
Akshay is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 09:12
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
