[snappyHexMesh] min y+ that can be gain with snappyHexMesh around airfoil
Old   April 9, 2013, 01:54
Unhappy min y+ that can be gain with snappyHexMesh around airfoil
s.m
saeideh mohamadi
s.m is on a distinguished road
i have a one element and a three element airfoil, and i wand use low Re turbulence models so i need yPlus < 50 for my mesh. i use snappyHexMesh.
my problem is to create a boundary layer with snappyHexMesh. How to control the number and thickness of the layers?
with what numbers in add layerControls we can reach to y+ < 50 ?
s.m is offline   Reply With Quote
Old   April 23, 2013, 10:57
HECKMANN Frédéric
fredo490 is on a distinguished road
First you have to "guess" the thickness of your first cell: http://www.cfd-online.com/Tools/yplus.php
You cannot calculate exactly what is the thickness needed because y+ depends of your solution. The link I gave you can however give you a good estimation.
I don't use snappyHexMesh but I can tell you that your first cell height must be of a close value from the estimation given by the link and the growth rate must be lower than 1.2.
Hope somebody can help you with Snappy
fredo490 is offline   Reply With Quote
Old   April 23, 2013, 18:00
bscphil's Avatar
Phillip
bscphil is on a distinguished road
Originally Posted by s.m View Post
Hey s.m,
when you use a so-called "low-Re" turbulence model the yPlus values are usually much lower in this assumption (y+ ~ 1) or (y+ < 5, with attention).
In snappyHexMesh you can control the number and thickness of the layers with:
addLayersControls
    relativeSizes true; // when set to false --> change thickness to absolute values
    layers
        myWall
            nSurfaceLayers 5;
    expansionRatio 1.0;
    finalLayerThickness 1.0;
    minThickness 0.1;
    nGrow 0;
    featureAngle 30;
    slipFeatureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 80;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
For more details look at: http://openfoamwiki.net/images/f/f0/Final-AndrewJacksonSlidesOFW7.pdf
For a good mesh you have to change the upper parameters, because this is only a example of usage...
hope i can help you? For more details post your case and entitle your problem with some code-examples and pictures...
bscphil is offline   Reply With Quote
Old   April 24, 2013, 04:58
Andreas Wendy
A.Wendy is on a distinguished road
hi,
like Frédéric said you can guess use the tool to calculate the thickness of the first wall layer. the final layer thickness in snappy hexmesh is the layer thickness wich is tha last layer (not the one at the wall) so you have to calculate final oundary layer depending on the expension ratio, number of layers and desired first layer thickness. yfinal = y*ratio^(n-1) (I think).
be sure to set relativeSize to false!
if you want to resolve your y+ should be smaller than 1 but at least below 5!
best wishes
Andreas
A.Wendy is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
