[CAD formats] create an STL file
Old   April 24, 2013, 23:59
Default create an STL file
Pj.
Luca
Pj. is on a distinguished road
Hi everybody,
it's an easy question, but i couldn't find an answer on the forum:
i need to create and stl file (for snappyHex) of a rectangular parallelepiped keeping the surfaces separated to allow force coeffs to gives me the force coefficient of each face.
I'm able to use AutoCAD, but when i create the stl it asks me to use a volume, so all the faces got "merged" in one surface.
Is there a way to do this with AutoCAD? Or have I to use another program? In case, can you tell me an easy one to use?
Thank you very much
Pj. is offline   Reply With Quote
Old   April 25, 2013, 02:58
Pablo Higuera
Phicau is on a distinguished road
Hi
for such a simple case you can do it by hand or set up a script. Find here the stl file for 2 faces:
solid face1
facet normal -0.000000 0.0 1.000000
   outer loop
      vertex 0.000000 1.000000 0.500000
      vertex 0.000000 -1.000000 0.500000
      vertex 10.000000 -1.000000 0.500000
   endloop
endfacet
   outer loop
      vertex 10.000000 1.000000 0.500000
   endloop
endfacet
endsolid face1
solid face2
   outer loop
      vertex 0.000000 1.000000 -0.500000
      vertex 0.000000 -1.000000 -0.500000
      vertex 10.000000 -1.000000 -0.500000
   endloop
endfacet
   outer loop
      vertex 10.000000 1.000000 -0.500000
   endloop
endfacet
endsolid face2
Best,
Pablo
Phicau is offline   Reply With Quote
Old   April 25, 2013, 04:51
Pj.
Luca
Thank you very much. For this first phase I'll try to do what you say.
For more complex cases (that i'll have to face later) instead, how can i do?
Old   April 25, 2013, 06:12
Default CAD software for generating STLs
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
It has to be a solid, not just a collection of edges. Its been a while since I've used AutoCAD, but I think by default you just get a collection of edges. You can do solids with AutoCAD, but Inventor (also Autodesk), solidworks, etc, are made for solids modeling. There are many open source and free options for solids modeling CAD software, here are some (from this thread):In the case of many of these packages, you make the solid, then create a mesh from that solid, then export that mesh as a ASCII-STL.
JR22 is offline   Reply With Quote
snappyhexmesh, stl
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
