[Other] Dynamic meshing for Lobe supercharger
Old   September 18, 2013, 00:41
Default Dynamic meshing for Lobe supercharger
Vishal
inf.vish is on a distinguished road
I am new to the concept of moving meshes. I would like to simulate flow in a lobe supercharger with two lobes. I am unable to understand how to approach the problem of mesh deformation when the lobes rotate.
I have found one thesis explaining gear pumps at this thread - http://www.cfd-online.com/Forums/ope...gear-pump.html
But the process involves remeshing which will take up huge processing power.
My question is, is there any way other than remeshing at intervals to solve the problem?
Or is it possible to remesh only a part of the deformed mesh?
inf.vish is offline   Reply With Quote
Old   September 18, 2013, 01:19
Neelesh Bhandari
neeljet is on a distinguished road
Hi vishal,
I'm doing a similar problem, lobe pump used in food industries. I was wondering do you got any success in remeshing technique given in gear pump thesis? I'm not able to get this Dynamic mesh routine of Openfoam? I'll be a great if give me some thread.
Regards,
Neelesh
neeljet is offline   Reply With Quote
Old   September 18, 2013, 01:38
Vishal
Originally Posted by neeljet View Post
Hi vishal,
Regards,
Neelesh
Hi Neelesh,
I have yet to simulate and test the procedure given in the gear pump thesis. If you do not have constraints on cost of processing then you can try to replicate the procedure in the gear pump thesis.
I am trying to find out how ANSYS CFX is performing the deforming mesh simulation for a lobe compressor and whether it is deforming the mesh in the first place. I think ANSYS CFX is using immersed boundary method which is currently not available in OpenFOAM but is available in OpenFOAM extended. I am not able to understand the process of immersed boundary method explained in some OpenFOAM workshop. If immersed boundary is possible in OpenFOAM then the problem of remeshing is completely eliminated.
Dynamic Meshing of Simple 2D Geometry harman79 FLUENT 2 January 17, 2018 06:07
UDF for dynamic meshing? prasaddeole FLUENT 2 October 6, 2014 11:55
Error using dynamic meshing : 'Null cells detected' Jiang FLUENT 0 June 26, 2013 08:30
Dynamic meshing - UDF Jiang Fluent UDF and Scheme Programming 1 June 20, 2013 10:18
negative cell volume during dynamic meshing Tamjid FLUENT 1 September 5, 2011 02:33
