[snappyHexMesh] bumpy on the surface of 3D wing in addlayer step with snappyHexMesh
Old   October 16, 2013, 01:58
Post bumpy on the surface of 3D wing in addlayer step with snappyHexMesh
Kim sung hwan
Kim sung hwan is on a distinguished road
Dear cfd-users,
i have tried making external mesh by running snappyHexMesh for simulating a OneraM6 wing. but i meet a problem the addlayer processing in snappyHexMesh. Until snapping, i got reasonable snapping results on the wing surface.
however, after addlayer step, i found some bumps between upper and lower level of refinement level. when i got uniform cells near a surface using distance refinement, i could
resolve this problem. but it makes too many total cells so, it's not efficient.
I have tried many parametric study, but i can't find the solution about this issue.
I attached four screenshots and below there's my snappyHexMeshDict.
I would appreciate any help for solve this problem.
|       o          |                                                          |
|    o     o       | HelyxOS                                                  |
|   o   O   o      | Version: v1.0.3                                           |
|    o     o       | Web:     http://www.engys.com                            |
|       o          |                                                          |
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
    castellatedMesh true;
    snap true;
    addLayers true;
    geometry
        M6.stl
            type triSurfaceMesh;
            name M6;
        box1
            type searchableBox;
            min (-0.5 0.0 -0.5 );
            max (2.0 1.5 0.5 );
    castellatedMeshControls
        features
            file "M6.eMesh";
            level 8;
        refinementSurfaces
            M6
                regions
                level (7 8 );
        refinementRegions
            box1
                mode inside;
                levels (( 1E5 3 ));
        locationInMesh (3.0 3.0 1.0 );
        maxLocalCells 1000000;
        maxGlobalCells 2000000;
        minRefinementCells 0;
        nCellsBetweenLevels 5;
        resolveFeatureAngle 5;
        allowFreeStandingZoneFaces false;
    snapControls
        nSolveIter 300;
        nSmoothPatch 3;
        tolerance 1.0;
        nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap false;
        explicitFeatureSnap true;
        multiRegionFeatureSnap false;
    addLayersControls
        layers
            M6_ascii_io_exported_from_Pointwise
                nSurfaceLayers 2;
        relativeSizes false;
        expansionRatio 1.1;
        finalLayerThickness 2.0E-4;
        minThickness 1.0E-5;
        nGrow 0;
        featureAngle 60;
        slipFeatureAngle 30;
        nRelaxIter 3;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.8;
        maxThicknessToMedialRatio 0.3;
        minMedianAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 50;
        nRelaxedIter 20;
    meshQualityControls
        maxNonOrtho 65;
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        maxConcave 80;
        minFlatness 0.5;
        minVol 1.00E-13;
        minTetQuality -1e30;
        minArea -1;
        minTwist 0.02;
        minDeterminant 0.001;
        minFaceWeight 0.02;
        minVolRatio 0.01;
        minTriangleTwist -1;
        nSmoothScale 4;
        errorReduction 0.75;
    debug 0;
    mergeTolerance 1E-6;
Kim sung hwan is offline   Reply With Quote
Old   April 20, 2015, 23:06
Default Bumpy surfaces on snappyhexMesh
lav
Lavanya
lav is on a distinguished road
Has this problem been resolved? I have done 2 things to remove the protruded surfaces.
1. Make the "allowfreestandingZonefaces" as true in snappyHexMesh Dict
2. On moving to higher number of cells, I could still see the bumpy surfaces , so I went to increase the "minTetQuality " in the meshQualitycontrols .
I am not sure if this the right point of looking at the problem. Is there any another better way of doing this ?
lav is offline   Reply With Quote
Old   April 21, 2015, 03:51
Artur's Avatar
Artur
Artur will become famous soon enough
Have you tried playing around with the snapping distance tolerance parameter? I've found it to be quite crucial for getting good mesh on and very near the body surface. Sadly I've had problems in getting the quality I want with different refinement levels as was the case in the original post...
Can you comment on the effect of the changes you've made?
All the best,
A
Artur is offline   Reply With Quote
addlayer, bumpy, refinement level, snappyhexmesh 3d, wing
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Bumpy Wing with snappyHexMesh aeir1976 OpenFOAM Meshing & Mesh Conversion 9 June 20, 2012 05:30
