[snappyHexMesh] snappyHexMesh Tutorials, further information
Old   October 16, 2013, 06:59
Default snappyHexMesh Tutorials, further information
phil
gelbebanane is on a distinguished road
Hi there,
I am new to CFD modelling and mesh generating. I am currently working on understanding snappyHexMesh and how it works.
Finally i managed to complete the "cavity" and "motorbike" tutorial. But now i want to get more information about sHM.
Is there any database where i can find more information about how to write a SHMDict and which parameter does what. I already read through the Users Guide but descriptions are not enough for a deeper understanding in how i have to configure sHM for own test cases etc.
Meanwhile i will expand my knowledge about OpenFoam configuration.
Cheers
Phil
hope i could explan my point properly
Already read through:
https://sites.google.com/site/snappywiki/
http://www.openfoam.org/docs/user/
http://cfdcomputing.com/documents/snappyhexmesh.htm
openfoamwiki.net/images/f/f0/Final-AndrewJacksonSlidesOFW7.pdf
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2013/
gelbebanane is offline   Reply With Quote
Old   October 22, 2013, 09:16
Artur's Avatar
Artur
Artur will become famous soon enough
Hi Phil,
I'm afraid there is no "central" database of OpenFOAM resources. The ones you posted seem to be the ones most people would point you to I think. Similarly, there is no ideal snappyMeshDict for all cases. The way I do it is try to find a similar object or case in the tutorials and work from there (e.g. Wigley hull for ship hulls, propeller for propellers, etc.). Depending on what you're meshing, there is usually quite a lot of info in this forum specific to each kind of simulations and you can often go through other people's dictionaries which you might also find helpful.
Hope my answer was not too vague, good luck with your work.
A
Artur is offline   Reply With Quote
Store "hidden" information in CFX mesh file mmoelle1 CFX 7 June 7, 2018 19:04
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 11:55
[snappyHexMesh] Error in SnappyHexMesh gooya_kabir OpenFOAM Meshing & Mesh Conversion 2 October 23, 2013 04:41
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
