[Other] Pointwise -> OpenFOAM, Axisymmetric
Old   October 18, 2013, 18:40
Default Pointwise -> OpenFOAM, Axisymmetric
Nucleophobe is on a distinguished road
Hi all,
I am having a heck of a time exporting an axisymmetric Pointwise mesh to OpenFOAM that works. The solver always blows up!
The mesh is a simple wedge at the moment, stradling the x-y plane, with an angle of 5 degrees. I have an inlet and outlet specified, and a wall for the outer boundary (i.e. pipe flow).
I did a 2D case earlier, and everything worked fine. Can anyone tell me what's going on?
UPDATE:
I attached a tarball with two folders: 1) a case with an axisymmetric mesh made with the blockMesh utility, and 2) a case with an axisymmetric mesh made using Pointwise, and exported to OpenFOAM.
If the mesh is only a single wedge element, the solver converges in both cases. However, if I increase the cell density, the Pointwise mesh fails to solve. checkMesh reports both meshes are fine.
The crazy thing is the meshes look almost identical - I've compared the 'boundary', 'points', 'faces', 'neighbors', and 'owners' files, and both meshes seem to contain the same data, although in different order. Is that the problem?
output from simpleFoam:
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 8.3819755e-10, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.0086919029, Final residual = 3.9435673e-09, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
GAMG: Solving for p, Initial residual = 1, Final residual = 9.1574944e+13, No Iterations 25 <------Problem
GAMG: Solving for p, Initial residual = 0.99546584, Final residual = 5.8973809e+10, No Iterations 25...
Tldr, Pointwise OpenFOAM export has problems.
Thanks!
-Nuc
Nucleophobe is offline   Reply With Quote
Old   October 21, 2013, 11:57
Smile Solved!
I believe I found a solution!
I was using Pointwise 17.1r3. When performing CAE export, only 5 boundaries were exported: inlet, outlet, far, front, and back. (same problem with 17.1r2)
I made a new identical mesh in Pointwise 17.0r1. This time, performing CAE export resulted in 6 boundaries: inlet, outlet, far, front, back AND pole.
The mesh from the older version of Pointwise (17.0r1) works fine, so this must be a problem with 17.1rX.
Old   May 22, 2015, 05:19
alvaro
alvariten is on a distinguished road
Hi Ken,
I'm trying to export an axisymmetric mesh to OpenFOAM (with inlet, outlet, walls, wedge and axis). When I set the BC's type, I assign empty type to connectors which are the rotate axis. But to export, the patch 'axis' in the boundary file doesn't appear. How I have to set the BC's at wedge mesh correctly?
I'm using Pointwise v17.3R1.
Regards.
alvariten is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
[Commercial meshers] Native OpenFOAM interface in Pointwise cnsidero OpenFOAM Meshing & Mesh Conversion 41 May 20, 2012 18:30
Native OpenFOAM interface in Pointwise Chris Sideroff Main CFD Forum 0 January 16, 2009 12:37
