[Other] plot3DToFoam: converting backstep grids from NASA's website
Old   November 4, 2013, 06:39
Default plot3DToFoam: converting backstep grids from NASA's website
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to convert some Plot3D meshes into the OpenFOAM format. What I am doing is to download some meshes from, for example,
HTML Code:
http://turbmodels.larc.nasa.gov/backstep_grids.html
and to convert them using
plot3dToFoam name-of-the-mesh
But I get this error:
zampini@pc-zampini:~/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test$ plot3dToFoam  backstep5_1levdn.p2dfmt
|  \\    /   O peration     | Version:  2.2.0                                 |
Build  : 2.2.0
Exec   : plot3dToFoam backstep5_1levdn.p2dfmt
Date   : Nov 04 2013
Time   : 12:30:12
Host   : "pc-zampini"
PID    : 22448
Case   : /home/zampini/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test
nProcs : 1
Create time
Reading 4 blocks
block 0 nx:257 ny:257 nz:97
block 1 nx:257 ny:385 nz:449
--> FOAM FATAL IO ERROR:
wrong token type - expected int, found on line 4 the doubleScalar -130
file: backstep5_1levdn.p2dfmt at line 4.
    From function operator>>(Istream&, int&)
    in file primitives/ints/int/intIO.C at line 68.
FOAM exiting
or this one:
zampini@pc-zampini:~/Documenti/PhD/corsi/physicsAndNumericalModellingOfTurbulentFlows/test$ plot3dToFoam backstep5_0levdn.p2dfmt
Build  : 2.2.0
Exec   : plot3dToFoam backstep5_0levdn.p2dfmt
Date   : Nov 04 2013
Time   : 12:25:43
Host   : "pc-zampini"
PID    : 22264
nProcs : 1
Create time
Reading 4 blocks
block 0 nx:513 ny:513 nz:193
block 1 nx:513 ny:769 nz:897
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Annullato
Could anyone help, please?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   December 18, 2014, 16:04
Mateus Peixoto
adoledin is on a distinguished road
Hi Samuele,
Did you solve the problem?
adoledin is offline   Reply With Quote
Old   January 2, 2015, 16:51
Samuele Z
Dear Adoledin,
indeed, what I did was to generate a new mesh similar to the one available in the link I post in my first message.
Sorry!
Purpose and Map of this forum Tobi OpenFOAM Community Contributions 0 September 19, 2017 05:52
NASA's grids not working on SU2 gittagawa SU2 4 August 12, 2017 19:41
How to get su2 meshes from NASA's plot3D/cgns grids OVS SU2 4 February 29, 2016 12:07
Does the grids topology matters? Anna Tian Main CFD Forum 11 August 19, 2014 02:20
