[Salome] 2d mesh by salome
Like Tree3Likes
  • 1 Post By gschaider
  • 1 Post By startingWithCFD
Old   May 16, 2009, 10:33
Default 2d mesh by salome
Nugroho Adi
mahaputra is on a distinguished road
Dear All
does anybody know, how to make a 2d mesh in Salome and can be recognized by OpenFOAM ?
many thanks
mahaputra is offline   Reply With Quote
Old   May 19, 2009, 18:17
Assistant Moderator
Bernhard Gschaider
I assume that the converter (ideasUnvToFoam) fails. Probably (haven't checked) it doesn't support 2D-Meshes. The easiest thing (unless you want to rewrite the convert) is to extrude in Salome the mesh to a 3D-mesh that is 1 layer thick and export that. Just the thing the convert would do to get a Foamish 2D-mesh
Bernhard
nimasam likes this.
Old   May 20, 2009, 00:37
Nugroho Adi
Bernhard
Thanks Bernhard
so, could you please suggest me, some option to make a 2D mesh (exclude using blockMeshDict or any commercial software) ?
by the way, out of the topic, i have a problem related to dieselFoam, please spend a while your time to see my case in : http://www.cfd-online.com/Forums/ope...tml#post216606
i really need some suggestion and help
Thousand Thanks
Nugroho Adi S
Old   December 12, 2013, 14:45
Nima Samkhaniani
nimasam is on a distinguished road
Dear Bernard
i follow this suggestion, now it can be converted with ideasUnvToFoam, but it returns patches as default faces and it can not recognize patches, do you have any idea how i can keep patches name in conversion from salome
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   December 12, 2013, 17:25
Assistant Moderator
Bernhard Gschaider
Originally Posted by nimasam View Post
Dear Bernard
Have you named the patches in Salome?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 13, 2013, 02:10
Nima Samkhaniani
well, my steps in salome:
1- create 2D sketch
2-create face
3-explod face to edges
4-creates groups
5- mesh face (2D mesh)
6- extrude it
it fails to recognize my groups
then i changed my approach,
1- create 2D sketch
2-create face
3- extrude face to create volume
4- explode volume
6- create groups
7- create mesh
3D project with 2D-1D netgen element
but OpenFOAM can not recognize the elements
any idea how i can create one cell thickness for 2D simulation in OpenFOAM with Salome and with known patches ?
Old   December 13, 2013, 05:06
Assistant Moderator
Bernhard Gschaider
1- create 2D sketch
2-create face
4-creates groups
6- extrude it
1- create 2D sketch
2-create face
4- explode volume
6- create groups
7- create mesh
If I remember it correctly you've got to create mesh groups or so (not sure of the nomenclature, don't want to start Salome and it is done in one of the basic tutorials on Salome anyway) from the geometry groups.
Old   December 13, 2013, 11:11
startingWithCFD is on a distinguished road
Geometry module
1) create 2D sketch
2) create face
3) extrude face to create volume
4) use propagate on the extrusion (operations -> blocks -> propagate) to create groups ("compounds") of edges that have the same discretization
5) create face groups
Mesh module
6) create mesh for the extrusion
7) create a sub-mesh for the extrusion at the compound containing edges you want to discretize with only one interval. Algorithm: wire discretization. New hypothesis: nb. of segments = 1
8) compute the mesh
hsmao likes this.
startingWithCFD is offline   Reply With Quote
Old   December 13, 2013, 11:13
Sorry, forgot these last steps:
9) Right click on mesh, create group, face, group on geometry. Geometrical object: direct geometry selection and choose the groups on the geometry.
10) Right click on the mesh and export to UNV
That's all folks!
hsmao likes this.
Old   June 11, 2014, 14:38
Hann Mao
hsmao is on a distinguished road
Originally Posted by startingWithCFD View Post
Geometry module
1) create 2D sketch
2) create face
Mesh module
8) compute the mesh
Thanks! This worked perfectly.
hsmao is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Salome cgns format mesh to SU2 JPBLourenco SU2 19 November 18, 2019 02:11
[Other] conformed FSI mesh for unstructured fluid region ashish.svm OpenFOAM Meshing & Mesh Conversion 10 August 2, 2019 08:40
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
Converting Salome hybrid mesh to OpenFOAM Arnoldinho OpenFOAM 4 March 28, 2012 10:24
